Bluetooth wasn’t working correctly and I went to restart it using the bluetooth icon on the panel, and when I turn it on, visually it says it’s on, but the icon on the panel is in constent loading and I can’t connect to or add new devices. I’ve tried restarting the services via commands but that didn’t seem to do anything.
Kernel: 5.17.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=0595d6c1-6f6f-403c-a5ad-535caa3cf6d4 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 wm: kwin_wayland vt: 2
Type: Desktop Mobo: ASRock model: B250M Performance
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: P2.30
date: 02/23/2018
RAM: total: 15.59 GiB used: 9.13 GiB (58.6%)
RAM Report:
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1153 high: 1200 min/max: 800/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 1200 3: 1200
4: 1200 5: 1200 6: 1200 7: 1128 8: 900 bogomips: 64026
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Display: wayland server: X .org v: 1.21.1.3 with: Xwayland v: 22.1.0
alternate: fbdev,vesa gpu: amdgpu d-rect: 3520x1980 display-ID: 0
Monitor-1: DVI-D-1 pos: bottom-r res: 1600x900 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,top-left res: 1920x1080 size: N/A
modes: N/A
OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.44.0
5.17.0-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 0c76:161e
class-ID: 0300
Device-4: Razer USA Barracuda X type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:3 chip-ID: 1532:0536
class-ID: 0300
Sound Server-1: ALSA v: k5.17.0-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.48 running: yes
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek 802.11ac NIC type: USB driver: N/A bus-ID: 1-8:5
chip-ID: 0bda:c811 class-ID: 0000 serial: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
IP v4: <filter> scope: global
driver: btusb v: 0.8 bus-ID: 1-7:18 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.73 TiB used: 453.67 GiB (16.2%)
model: WDS100T2B0C size: 931.51 GiB block-size: physical: 512 B
rev: 211210WD temp: 45.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 221.97 GiB (24.2%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 0595d6c1-6f6f-403c-a5ad-535caa3cf6d4
ID-2: /mnt/Extra raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 231.69 GiB (12.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Extra
uuid: 8394ae11-d7ef-465a-b554-6b01b841b781
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:161e class-ID: 0300
Device-2: 1-6:3 info: Razer USA Barracuda X type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1532:0536 class-ID: 0300
Device-3: 1-7:18 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-4: 1-8:5 info: Realtek 802.11ac NIC type: WiFi driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:c811
Hub-2: 1-11:6 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-11.3:8 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-3: 1-12:7 info: NEC HighSpeed Hub ports: 3 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0409:005a class-ID: 0900
Device-1: 1-12.3:9 info: SteelSeries ApS Merc Stealth type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 1038:0510 class-ID: 0300
Hub-4: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-5: 2-4:2 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 789
Processes: 300 Uptime: 14h 11m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1420
pacman: 1400 lib: 370 flatpak: 12 snap: 8 Shell: Zsh v: 5.8.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.14```
