My desktop wont shutdown
Hi,
Since i’ve upgraded to kernel 6.x my desktop will not shutdown. It worked correctly with kernel 5.x. I have tried everything: added in systemctl shutdown cmds to stop bluetooth, added flags in grub default usbcore.autosuspend=-1. Nothing works. It sometimes shutsdown, but i have not yet been able to figure out whats causing this, i’ve tried stopping bluetooth manually and removing headphones, sometimes it works, sometimes it doesnt, i’ve tried unmounting any external drives i have/encrypted partitions.
Any ideas what else i could try?
Thank you!
System logs?
Whenever I’ve had shutdown problems since systemd arrived, it’s always been due to a “stop job” not completing. The best thing to do is to make sure you’ve got your kernel messages displaying on-screen, so you can see what’s hanging during the shutdown process.
When you boot, wait until you see the GRUB menu, then select the kernel you want to boot (usually the one selected by default) and type “e”. This will allow you to make temporary changes to the kernel command line. You need to remove “quiet” and/or “splash”, then boot by hitting “b”.
You’ll now be faced with a big stream of output as your computer boots, until the GUI is loaded. But more importantly, you’ll get all that output as it shuts down (or fails to, perhaps) and with luck it should give you some useful information.
This edit is only a one-off; the next time you boot it’ll be back to normal.
I have removed quiet from the grub boot line. When i click on shutdown i can see all messages, it reaches target shutdown and no stop job is there, but the computer doesnt actually power down. Like the software part is working, but it doesnt send the signal to the hardware to completly shutdown.
Like dmesg? or journal?
Here are some of the logs:
[rog-desktop ~]# inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.18.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=82da9cde-4a3f-461c-b700-8826d12e2470 rw apparmor=1
    security=apparmor resume=UUID=7baed187-5907-4ce2-9127-4023d5d1561d
    udev.log_priority=3 usbcore.autosuspend=-1
  Console: pty pts/4 DM: GDM v: 49.2 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: G15CK v: 1.0 serial: <filter>
    uuid: b642fc77-2d20-be9f-a8a0-244bfe95b8b5 Firmware: UEFI
    vendor: American Megatrends v: G15CK.0707 date: 07/21/2020
  System RAM: total: 16 GiB available: 15.52 GiB used: 5.74 GiB (37.0%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM1 type: no module installed
  Device-2: ChannelA-DIMM2 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2933 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
    total: 64 manufacturer: Micron part-no: 8ATF1G64AZ-3G2J1 serial: <filter>
  Device-3: ChannelB-DIMM1 type: no module installed
  Device-4: ChannelB-DIMM2 type: DDR4 detail: synchronous size: 8 GiB
  Message: No PCI Slot data found.
  Info: model: Intel Core i7-10700KF socket: LGA1200 bits: 64 type: MT MCP
    arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
    process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 5
    microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB
    desc: 8x256 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 800 min/max: 800/5100 base/boost: 3762/8300 scaling:
    driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
    10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800 bogomips: 121596
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
    rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
    vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: ASUSTeK
    driver: nvidia v: 590.48.01 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DP-1,DVI-D-1 empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:21c4
    class-ID: 0300
  Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    tty: 211x53
  Monitor-1: DP-1 model: Dell E2216H serial: <filter> built: 2018
    res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
    x: 0.310 y: 0.620 blue: x: 0.153 y: 0.067 white: x: 0.314 y: 0.329
    size: 476x268mm (18.74x10.55") diag: 546mm (21.5") ratio: 16:9
    modes: 1920x1080, 1600x900, 1280x1024, 1152x864, 1024x768, 800x600,
    640x480
  Monitor-2: DVI-D-1 model: Dell E2214H serial: <filter> built: 2014
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
    640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
    inactive: wayland,x11,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 25.3.5-arch1.1
    note: console (EGL sourced) renderer: NVIDIA GeForce GTX 1660
    SUPER/PCIe/SSE2, llvmpipe (LLVM 21.1.6 256 bits)
  API: Vulkan v: 1.4.341 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1660 SUPER driver: nvidia v: 590.48.01 device-ID: 10de:21c4
    surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: nvidia-smi
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Comet Lake PCH-V cAVS vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
    chip-ID: 8086:a3f0 class-ID: 0403
  Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
    bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
  API: ALSA v: k6.18.12-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off tools: jack_control
  Server-3: PipeWire v: 1.4.10 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 17.0-98-gb096 status: active (root, process) with:
    tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Info: services: httpd, NetworkManager, systemd-timesyncd, wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:8 chip-ID: 8087:0029
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
  Device-1: zuluCrypt-1000-NAAN-.yelpconfig-2928310914 maj-min: 253:0
    type: LUKS dm: dm-0 size: 98 MiB
  Components:
  p-1: loop0 maj-min: 7:0 size: 100 MiB
  Local Storage: total: 953.87 GiB used: 467.31 GiB (49.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 27.9 C scheme: GPT
  ID-1: / raw-size: 530.74 GiB size: 521.34 GiB (98.23%)
    used: 467.3 GiB (89.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8
    maj-min: 259:8 label: N/A uuid: 82da9cde-4a3f-461c-b700-8826d12e2470
    used: 332 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p6
    maj-min: 259:6 label: N/A uuid: B33B-8942
  ID-3: /run/media/private/symtab/Private raw-size: 98 MiB
    size: 89.4 MiB (91.21%) used: 13.9 MiB (15.5%) fs: ext4 block-size: 1024 B
    dev: /dev/dm-0 maj-min: 253:0
    mapped: zuluCrypt-1000-NAAN-.yelpconfig-2928310914 label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: 7baed187-5907-4ce2-9127-4023d5d1561d
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 450 MiB fs: ntfs label: Recovery
    uuid: 34A6C3ECA6C3ACA4
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 99 MiB fs: vfat label: N/A
    uuid: 50C4-922B
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 389.25 GiB fs: ntfs label: N/A
    uuid: 7464CC2664CBE946
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 840 MiB fs: ntfs label: N/A
    uuid: 2688D2EC88D2BA0F
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-4:14 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-6:3 info: Elan Micro Gaming KB type: keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 04f3:152e class-ID: 0301
  Device-2: 1-8:4 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:1025 class-ID: 0301
    serial: <filter>
  Hub-3: 1-9:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-9.2:7 info: ASUSTek ITE Device(8910) type: keyboard
    driver: usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 0b05:1866 class-ID: 0301
  Device-2: 1-10:6 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Device-3: 1-12:8 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-4: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 33.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 2295 libs: 628 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0
    1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    3: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    4: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    5: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    6: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    7: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 436
  1: cpu: 100% command: ps pid: 44804 mem: 4.34 MiB (0.0%)
  2: cpu: 9.7% command: chromium pid: 43626 mem: 279.7 MiB (1.7%)
  3: cpu: 6.4% command: chromium pid: 15098 mem: 529.4 MiB (3.3%)
  4: cpu: 5.3% command: gnome-shell pid: 3172 mem: 509.0 MiB (3.2%)
  5: cpu: 5.1% command: chromium pid: 12669 mem: 426.9 MiB (2.6%)
  Memory top: 5 of 436
  1: mem: 632.9 MiB (3.9%) command: searchd pid: 16264 cpu: 0.0%
  2: mem: 541.6 MiB (3.4%) command: chromium pid: 12630 cpu: 2.5%
  3: mem: 529.4 MiB (3.3%) command: chromium pid: 15098 cpu: 6.4%
  4: mem: 509.0 MiB (3.2%) command: gnome-shell pid: 3172 cpu: 5.3%
  5: mem: 463.4 MiB (2.9%) command: Telegram pid: 3391 cpu: 0.1%
  Processes: 436 Power: uptime: 11h 11m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.16 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Bash (su) v: 5.3.9
    running-in: pty pts/4 inxi: 3.3.40
[rog-desktop ~]#
And journal:
Mar 11 21:02:07 rog-desktop rygel[20153]: Error sending SSDP packet to FF0E::C: Error sending message: Network is unreachable
Mar 11 21:03:32 rog-desktop gnome-shell[3110]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Mar 11 21:04:03 rog-desktop gnome-shell[3110]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Mar 11 21:08:43 rog-desktop localsearch-3[3401]: Could not ask extractor to update: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/org/freedesktop/Tracker3/Extract”
Mar 11 21:08:49 rog-desktop gnome-shell[3110]: JS ERROR: Error: Impossible to remove untracked message
                                               _removeMessage@resource:///org/gnome/shell/ui/messageList.js:1626:19
                                               _removePlayer@resource:///org/gnome/shell/ui/messageList.js:1800:14
                                               _setupMpris/<@resource:///org/gnome/shell/ui/messageList.js:1784:51
                                               _onNameOwnerChanged@resource:///org/gnome/shell/ui/mpris.js:247:22
                                               _callHandlers@resource:///org/gnome/gjs/modules/core/_signals.js:130:42
                                               _emit@resource:///org/gnome/gjs/modules/core/_signals.js:119:10
                                               _convertToNativeSignal@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:153:19
                                               @resource:///org/gnome/shell/ui/init.js:21:20
Mar 11 21:09:03 rog-desktop gdm[1038]: Gdm: Failed to list cached users: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Mar 11 21:09:03 rog-desktop localsearch-3[3401]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Mar 11 21:09:03 rog-desktop localsearch-3[3401]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Mar 11 21:09:03 rog-desktop localsearch-3[3401]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Mar 11 21:09:03 rog-desktop localsearch-3[3401]: Owner of volume monitor org.gtk.vfs.UDisks2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Mar 11 21:09:03 rog-desktop bluetoothd[880]: src/bearer.c:btd_bearer_disconnected() Unknown disconnection value: 21
Mar 11 21:09:03 rog-desktop bluetoothd[880]: src/device.c:device_disconnected() Unknown disconnection value: 21
Mar 11 21:09:03 rog-desktop systemd[1]: gdm.service: Failed with result 'exit-code'.
Mar 11 21:09:03 rog-desktop systemd[1]: gdm.service: Failed to enqueue OnFailure=plymouth-quit.service job, ignoring: Unit plymouth-quit.service not found.
Mar 11 21:09:03 rog-desktop bluetoothd[880]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Mar 11 21:09:03 rog-desktop systemd[1]: sys-devices-pci0000:00-0000:00:1f.3-sound-card0-controlC0.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for sound.target/start is destructive (systemd-poweroff.service has 'start' job queued, but 'stop' is included in transaction).
Mar 11 21:09:03 rog-desktop systemd[1]: sys-devices-pci0000:00-0000:00:01.0-0000:01:00.1-sound-card1-controlC1.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for sound.target/start is destructive (systemd-poweroff.service has 'start' job queued, but 'stop' is included in transaction).
Mar 11 21:09:03 rog-desktop systemd[1]: sys-devices-virtual-misc-rfkill.device: Failed to enqueue SYSTEMD_WANTS job, ignoring: Transaction for systemd-rfkill.socket/start is destructive (poweroff.target has 'start' job queued, but 'stop' is included in transaction).
Mar 11 21:09:03 rog-desktop pulseaudio[3420]: X11 I/O error handler called
Mar 11 21:09:03 rog-desktop pulseaudio[3420]: X11 I/O error exit handler called, preparing to tear down X11 modules
Mar 11 21:09:03 rog-desktop gnome-shell[3110]: Connection to xwayland lost
Mar 11 21:09:03 rog-desktop gnome-shell[3110]: Owner of volume monitor org.gtk.vfs.AfcVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Mar 11 21:09:03 rog-desktop gnome-shell[3110]: Owner of volume monitor org.gtk.vfs.GoaVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Mar 11 21:09:03 rog-desktop gnome-shell[3110]: Owner of volume monitor org.gtk.vfs.MTPVolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Mar 11 21:09:03 rog-desktop gnome-shell[3110]: Owner of volume monitor org.gtk.vfs.UDisks2VolumeMonitor disconnected from the bus; removing drives/volumes/mounts
Mar 11 21:09:04 rog-desktop gnome-shell[3110]: Could not release device '/dev/input/event25' (13,89): GDBus.Error:org.freedesktop.login1.DeviceNotTaken: Device not taken
Mar 11 21:09:04 rog-desktop gnome-shell[3110]: Error checking authorization for action id org.freedesktop.NetworkManager.network-control: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Mar 11 21:09:04 rog-desktop gnome-shell[3110]: Error checking authorization for action id org.freedesktop.bolt.enroll: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Mar 11 21:09:04 rog-desktop gnome-shell[3110]: Object St.Icon (0x562cb3da53a0), has been already disposed — impossible to set any property on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
                                               == Stack trace for context 0x562caf589320 ==
                                               #0   562caf6590a0 i   resource:///org/gnome/shell/ui/status/bluetooth.js:464 (dde27c33fb0 @ 183)
                                               #1   562caf659020 i   resource:///org/gnome/shell/ui/status/bluetooth.js:449 (dde27c33f60 @ 12)
                                               #2   562caf658f98 i   resource:///org/gnome/shell/ui/status/bluetooth.js:181 (dde27c33380 @ 28)
                                               #3   562caf658ef8 i   resource:///org/gnome/shell/ui/main.js:279 (13dd19d0c1f0 @ 119)
Mar 11 21:09:04 rog-desktop systemd[2918]: dbus-:1.2-org.gnome.Shell.Extensions.GSConnect@0.service: Failed with result 'exit-code'.
Mar 11 21:09:04 rog-desktop dbus-broker-launch[876]: Activation request for 'org.freedesktop.ColorManager' failed.
Mar 11 21:09:04 rog-desktop systemd[2918]: Dependency failed for Portal service (GNOME implementation).
Mar 11 21:09:04 rog-desktop dbus-broker-launch[876]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Mar 11 21:09:04 rog-desktop /usr/lib/xdg-desktop-portal[51651]: Failed to load RealtimeKit property: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.freedesktop.RealtimeKit1': activation request failed: unit is invalid
Mar 11 21:09:04 rog-desktop rygel[20153]: Error sending SSDP packet to FF0E::C: Error sending message: Network is unreachable
Mar 11 21:09:04 rog-desktop dbus-broker-launch[2936]: Activation request for 'org.freedesktop.impl.portal.desktop.gnome' failed.
Mar 11 21:09:04 rog-desktop dbus-broker-launch[876]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
[rog-desktop ~]#
And dmesg:
[rog-desktop ~]# dmesg
[    0.000000] Linux version 6.18.12-1-MANJARO (linux618@manjaro) (gcc (GCC) 15.2.1 20260209, GNU ld (GNU Binutils) 2.46) #1 SMP PREEMPT_DYNAMIC Mon, 16 Feb 2026 21:35:51 +0000
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=82da9cde-4a3f-461c-b700-8826d12e2470 rw apparmor=1 security=apparmor resume=UUID=7baed187-5907-4ce2-9127-4023d5d1561d udev.log_priority=3 usbcore.autosuspend=-1
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000005dfff] usable
[    0.000000] BIOS-e820: [mem 0x000000000005e000-0x000000000005efff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000005f000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000003fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040000000-0x00000000403fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040400000-0x000000007ecc0fff] usable
[    0.000000] BIOS-e820: [mem 0x000000007ecc1000-0x000000007ecc1fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000007ecc2000-0x000000007ece7fff] usable
[    0.000000] BIOS-e820: [mem 0x000000007ece8000-0x000000007ece8fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007ece9000-0x000000008b8f8fff] usable
[    0.000000] BIOS-e820: [mem 0x000000008b8f9000-0x000000008d78bfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008d78c000-0x000000008d8bbfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000008d8bc000-0x000000008dda8fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000008dda9000-0x000000008ed43fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000008ed44000-0x000000008effdfff] type 20
[    0.000000] BIOS-e820: [mem 0x000000008effe000-0x000000008effefff] usable
[    0.000000] BIOS-e820: [mem 0x000000008efff000-0x000000008fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000046effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] efi: EFI v2.7 by American Megatrends
[    0.000000] efi: ACPI=0x8d8bb000 ACPI 2.0=0x8d8bb014 TPMFinalLog=0x8dcf6000 SMBIOS=0x8ebb6000 SMBIOS 3.0=0x8ebb5000 MEMATTR=0x896ad018 ESRT=0x89c41c18
[    0.000000] efi: Remove mem83: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
[    0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
[    0.000000] efi: Not removing mem84: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[    0.000000] efi: Not removing mem85: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[    0.000000] efi: Not removing mem86: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[    0.000000] efi: Remove mem87: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[    0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[    0.000000] SMBIOS 3.2.0 present.
[    0.000000] DMI: ASUSTeK COMPUTER INC. ROG Strix G15CK_G15CK/G15CK, BIOS G15CK.0707 07/21/2020
[    0.000000] DMI: Memory slots populated: 2/4
[    0.000000] tsc: Detected 3800.000 MHz processor
[    0.000000] tsc: Detected 3799.900 MHz TSC
[    0.000633] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000635] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000643] last_pfn = 0x46f000 max_arch_pfn = 0x400000000
[    0.000646] MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
[    0.000648] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000947] last_pfn = 0x8efff max_arch_pfn = 0x400000000
[    0.006525] found SMP MP-table at [mem 0x000fce90-0x000fce9f]
[    0.006536] esrt: Reserving ESRT space from 0x0000000089c41c18 to 0x0000000089c41c50.
[    0.006541] e820: update [mem 0x89c41000-0x89c41fff] usable ==> reserved
[    0.006558] Using GB pages for direct mapping
[    0.007154] Secure boot could not be determined
[    0.007154] RAMDISK: [mem 0x28199000-0x300c3fff]
[    0.007260] ACPI: Early table checksum verification disabled
[    0.007261] ACPI: RSDP 0x000000008D8BB014 000024 (v02 _ASUS_)
[    0.007264] ACPI: XSDT 0x000000008D8BA728 0000CC (v01 _ASUS_ Desktop  01072009 AMI  01000013)
[    0.007269] ACPI: FACP 0x000000008D8B4000 000114 (v06 _ASUS_ Desktop  01072009 AMI  00010013)
[    0.007272] ACPI: DSDT 0x000000008D878000 03B56B (v02 _ASUS_ Desktop  01072009 INTL 20160527)
[    0.007275] ACPI: FACS 0x000000008DDA7000 000040
[    0.007277] ACPI: MCFG 0x000000008D8B9000 00003C (v01 _ASUS_ Desktop  01072009 MSFT 00000097)
[    0.007279] ACPI: SSDT 0x000000008D8B6000 0020AD (v02 CpuRef CpuSsdt  00003000 INTL 20160527)
[    0.007281] ACPI: SSDT 0x000000008D8B5000 000A52 (v02 PmRef  ItbmSci  00003000 INTL 20160527)
[    0.007283] ACPI: FIDT 0x000000008D877000 00009C (v01 _ASUS_ Desktop  01072009 AMI  00010013)
[    0.007285] ACPI: FPDT 0x000000008D859000 000044 (v01 _ASUS_ A M I    01072009 AMI  01000013)
[    0.007287] ACPI: SSDT 0x000000008D872000 0030AD (v02 SaSsdt SaSsdt   00003000 INTL 20160527)
[    0.007289] ACPI: SSDT 0x000000008D86F000 002703 (v02 Intel  PegSsdt  00001000 INTL 20160527)
[    0.007292] ACPI: HPET 0x000000008D86E000 000038 (v01 _ASUS_ Desktop  01072009 AMI  01000013)
[    0.007294] ACPI: SSDT 0x000000008D86C000 00147B (v02 _ASUS_ Ther_Rvp 00001000 INTL 20160527)
[    0.007296] ACPI: SSDT 0x000000008D868000 003740 (v02 INTEL  xh_cmvd4 00000000 INTL 20160527)
[    0.007298] ACPI: NHLT 0x000000008D867000 00002D (v00 _ASUS_ Desktop  01072009 AMI  01000013)
[    0.007300] ACPI: LPIT 0x000000008D865000 000094 (v01 _ASUS_ Desktop  01072009 AMI  01000013)
[    0.007302] ACPI: WSMT 0x000000008D864000 000028 (v01 _ASUS_ Desktop  01072009 AMI  01000013)
[    0.007304] ACPI: SSDT 0x000000008D861000 002720 (v02 _ASUS_ PtidDevc 00001000 INTL 20160527)
[    0.007306] ACPI: DBGP 0x000000008D860000 000034 (v01 _ASUS_ Desktop  01072009 AMI  01000013)
[    0.007308] ACPI: DBG2 0x000000008D85F000 000054 (v00 _ASUS_ Desktop  01072009 AMI  01000013)
[    0.007310] ACPI: SSDT 0x000000008D85D000 001B67 (v02 _ASUS_ UsbCTabl 00001000 INTL 20160527)
[    0.007312] ACPI: BGRT 0x000000008D85C000 000038 (v01 _ASUS_ Desktop  01072009 AMI  00010013)
[    0.007314] ACPI: TPM2 0x000000008D85B000 00004C (v04 _ASUS_ Desktop  00000001 AMI  00000000)
[    0.007316] ACPI: APIC 0x000000008D85A000 00012C (v04 _ASUS_ Desktop  01072009 AMI  00010013)
[    0.007318] ACPI: Reserving FACP table memory at [mem 0x8d8b4000-0x8d8b4113]
[    0.007319] ACPI: Reserving DSDT table memory at [mem 0x8d878000-0x8d8b356a]
[    0.007320] ACPI: Reserving FACS table memory at [mem 0x8dda7000-0x8dda703f]
[    0.007320] ACPI: Reserving MCFG table memory at [mem 0x8d8b9000-0x8d8b903b]
[    0.007321] ACPI: Reserving SSDT table memory at [mem 0x8d8b6000-0x8d8b80ac]
[    0.007322] ACPI: Reserving SSDT table memory at [mem 0x8d8b5000-0x8d8b5a51]
[    0.007322] ACPI: Reserving FIDT table memory at [mem 0x8d877000-0x8d87709b]
[    0.007323] ACPI: Reserving FPDT table memory at [mem 0x8d859000-0x8d859043]
[    0.007323] ACPI: Reserving SSDT table memory at [mem 0x8d872000-0x8d8750ac]
[    0.007324] ACPI: Reserving SSDT table memory at [mem 0x8d86f000-0x8d871702]
[    0.007325] ACPI: Reserving HPET table memory at [mem 0x8d86e000-0x8d86e037]
[    0.007325] ACPI: Reserving SSDT table memory at [mem 0x8d86c000-0x8d86d47a]
[    0.007326] ACPI: Reserving SSDT table memory at [mem 0x8d868000-0x8d86b73f]
[    0.007326] ACPI: Reserving NHLT table memory at [mem 0x8d867000-0x8d86702c]
[    0.007327] ACPI: Reserving LPIT table memory at [mem 0x8d865000-0x8d865093]
[    0.007328] ACPI: Reserving WSMT table memory at [mem 0x8d864000-0x8d864027]
[    0.007328] ACPI: Reserving SSDT table memory at [mem 0x8d861000-0x8d86371f]
[    0.007329] ACPI: Reserving DBGP table memory at [mem 0x8d860000-0x8d860033]
[    0.007329] ACPI: Reserving DBG2 table memory at [mem 0x8d85f000-0x8d85f053]
[    0.007330] ACPI: Reserving SSDT table memory at [mem 0x8d85d000-0x8d85eb66]
[    0.007331] ACPI: Reserving BGRT table memory at [mem 0x8d85c000-0x8d85c037]
[    0.007331] ACPI: Reserving TPM2 table memory at [mem 0x8d85b000-0x8d85b04b]
[    0.007332] ACPI: Reserving APIC table memory at [mem 0x8d85a000-0x8d85a12b]
[    0.007450] No NUMA configuration found
[    0.007450] Faking a node at [mem 0x0000000000000000-0x000000046effffff]
[    0.007458] NODE_DATA(0) allocated [mem 0x46efd5280-0x46effffff]
[    0.007659] Zone ranges:
[    0.007659]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.007661]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.007662]   Normal   [mem 0x0000000100000000-0x000000046effffff]
[    0.007663]   Device   empty
[    0.007664] Movable zone start for each node
[    0.007665] Early memory node ranges
[    0.007666]   node   0: [mem 0x0000000000001000-0x000000000005dfff]
[    0.007667]   node   0: [mem 0x000000000005f000-0x000000000009ffff]
[    0.007668]   node   0: [mem 0x0000000000100000-0x000000003fffffff]
[    0.007668]   node   0: [mem 0x0000000040400000-0x000000007ecc0fff]
[    0.007669]   node   0: [mem 0x000000007ecc2000-0x000000007ece7fff]
[    0.007670]   node   0: [mem 0x000000007ece9000-0x000000008b8f8fff]
[    0.007670]   node   0: [mem 0x000000008effe000-0x000000008effefff]
[    0.007671]   node   0: [mem 0x0000000100000000-0x000000046effffff]
[    0.007673] Initmem setup node 0 [mem 0x0000000000001000-0x000000046effffff]
[    0.007677] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.007679] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.007695] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.009852] On node 0, zone DMA32: 1024 pages in unavailable ranges
[    0.009854] On node 0, zone DMA32: 1 pages in unavailable ranges
[    0.010086] On node 0, zone DMA32: 1 pages in unavailable ranges
[    0.010168] On node 0, zone DMA32: 14085 pages in unavailable ranges
[    0.025376] On node 0, zone Normal: 4097 pages in unavailable ranges
[    0.025399] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.026000] ACPI: PM-Timer IO Port: 0x1808
[    0.026007] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.026009] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.026009] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.026010] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.026010] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.026011] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.026011] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.026012] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.026012] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.026013] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.026013] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.026014] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.026015] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.026015] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.026016] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.026016] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[    0.026043] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.026045] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.026046] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.026049] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.026050] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.026056] e820: update [mem 0x8667a000-0x866bffff] usable ==> reserved
[    0.026066] TSC deadline timer available
[    0.026070] CPU topo: Max. logical packages:   1
[    0.026071] CPU topo: Max. logical dies:       1
[    0.026071] CPU topo: Max. dies per package:   1
[    0.026075] CPU topo: Max. threads per core:   2
[    0.026076] CPU topo: Num. cores per package:     8
[    0.026076] CPU topo: Num. threads per package:  16
[    0.026077] CPU topo: Allowing 16 present CPUs plus 0 hotplug CPUs
[    0.026096] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.026097] PM: hibernation: Registered nosave memory: [mem 0x0005e000-0x0005efff]
[    0.026099] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.026100] PM: hibernation: Registered nosave memory: [mem 0x40000000-0x403fffff]
[    0.026102] PM: hibernation: Registered nosave memory: [mem 0x7ecc1000-0x7ecc1fff]
[    0.026103] PM: hibernation: Registered nosave memory: [mem 0x7ece8000-0x7ece8fff]
[    0.026105] PM: hibernation: Registered nosave memory: [mem 0x8667a000-0x866bffff]
[    0.026106] PM: hibernation: Registered nosave memory: [mem 0x89c41000-0x89c41fff]
[    0.026108] PM: hibernation: Registered nosave memory: [mem 0x8b8f9000-0x8effdfff]
[    0.026109] PM: hibernation: Registered nosave memory: [mem 0x8efff000-0xffffffff]
[    0.026110] [mem 0x90000000-0xfdffffff] available for PCI devices
[    0.026111] Booting paravirtualized kernel on bare hardware
[    0.026113] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.031850] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1
[    0.032294] percpu: Embedded 62 pages/cpu s217088 r8192 d28672 u262144
[    0.032301] pcpu-alloc: s217088 r8192 d28672 u262144 alloc=1*2097152
[    0.032303] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.032324] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64 root=UUID=82da9cde-4a3f-461c-b700-8826d12e2470 rw apparmor=1 security=apparmor resume=UUID=7baed187-5907-4ce2-9127-4023d5d1561d udev.log_priority=3 usbcore.autosuspend=-1
[    0.032405] random: crng init done
[    0.032406] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[    0.033482] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.034034] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.034193] software IO TLB: area num 16.
[    0.043020] Fallback order for Node 0: 0
[    0.043023] Built 1 zonelists, mobility grouping on.  Total pages: 4170902
[    0.043024] Policy zone: Normal
[    0.043198] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.073448] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.081492] ftrace: allocating 57192 entries in 224 pages
[    0.081493] ftrace: allocated 224 pages with 3 groups
[    0.081563] Dynamic Preempt: full
[    0.081622] rcu: Preemptible hierarchical RCU implementation.
[    0.081622] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=16.
[    0.081623] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.081624] 	Trampoline variant of Tasks RCU enabled.
[    0.081625] 	Rude variant of Tasks RCU enabled.
[    0.081625] 	Tracing variant of Tasks RCU enabled.
[    0.081625] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.081626] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[    0.081637] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[    0.081639] RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[    0.081640] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=16.
[    0.086436] NR_IRQS: 524544, nr_irqs: 2184, preallocated irqs: 16
[    0.086664] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.086881] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.086918] Console: colour dummy device 80x25
[    0.086920] printk: legacy console [tty0] enabled
[    0.086962] ACPI: Core revision 20250807
[    0.087132] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.087167] APIC: Switch to symmetric I/O mode setup
[    0.088367] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.092406] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6d8bf270d8d, max_idle_ns: 881590865083 ns
[    0.092411] Calibrating delay loop (skipped), value calculated using timer frequency.. 7599.80 BogoMIPS (lpj=3799900)
[    0.092428] x86/cpu: SGX disabled or unsupported by BIOS.
[    0.092434] CPU0: Thermal monitoring enabled (TM1)
[    0.092474] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.092475] Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
[    0.092478] process: using mwait in idle threads
[    0.092480] mitigations: Enabled attack vectors: user_kernel, user_user, guest_host, guest_guest, SMT mitigations: auto
[    0.092483] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.092484] SRBDS: Mitigation: Microcode
[    0.092486] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[    0.092486] RETBleed: Mitigation: Enhanced IBRS
[    0.092487] ITS: Mitigation: Aligned branch/return thunks
[    0.092488] MMIO Stale Data: Mitigation: Clear CPU buffers
[    0.092488] VMSCAPE: Mitigation: IBPB before exit to userspace
[    0.092489] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.092490] Spectre V2 : Spectre v2 / PBRSB-eIBRS: Retire a single CALL on VMEXIT
[    0.092491] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.092496] GDS: Mitigation: Microcode
[    0.092496] active return thunk: its_return_thunk
[    0.092499] Spectre V2 : Spectre BHI mitigation: SW BHB clearing on syscall and VM exit
[    0.092503] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.092505] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.092505] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.092506] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.092507] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.092507] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    0.092508] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.092510] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.092510] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.092511] x86/fpu: xstate_offset[9]:  960, xstate_sizes[9]:    8
[    0.092512] x86/fpu: Enabled xstate features 0x21f, context size is 968 bytes, using 'compacted' format.
[    0.093409] Freeing SMP alternatives memory: 56K
[    0.093409] pid_max: default: 32768 minimum: 301
[    0.093409] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
[    0.093409] landlock: Up and running.
[    0.093409] Yama: becoming mindful.
[    0.093409] LSM support for eBPF active
[    0.093409] AppArmor: AppArmor initialized
[    0.093409] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.093409] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.093409] smpboot: CPU0: Intel(R) Core(TM) i7-10700KF CPU @ 3.80GHz (family: 0x6, model: 0xa5, stepping: 0x5)
[    0.093409] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.093409] ... version:                   4
[    0.093409] ... bit width:                 48
[    0.093409] ... generic counters:          4
[    0.093409] ... generic bitmap:            000000000000000f
[    0.093409] ... fixed-purpose counters:    3
[    0.093409] ... fixed-purpose bitmap:      0000000000000007
[    0.093409] ... value mask:                0000ffffffffffff
[    0.093409] ... max period:                00007fffffffffff
[    0.093409] ... global_ctrl mask:          000000070000000f
[    0.093409] signal: max sigframe size: 3632
[    0.093409] Estimated ratio of average max frequency by base frequency (times 1024): 1293
[    0.094417] rcu: Hierarchical SRCU implementation.
[    0.094418] rcu: 	Max phase no-delay instances is 400.
[    0.094463] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[    0.096652] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.096742] smp: Bringing up secondary CPUs ...
[    0.096813] smpboot: x86: Booting SMP configuration:
[    0.096814] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
[    0.101416] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[    0.101473] smp: Brought up 1 node, 16 CPUs
[    0.101473] smpboot: Total of 16 processors activated (121596.80 BogoMIPS)
[    0.103516] Memory: 16111936K/16683608K available (20260K kernel code, 2955K rwdata, 16372K rodata, 4732K init, 4772K bss, 546148K reserved, 0K cma-reserved)
[    0.103839] devtmpfs: initialized
[    0.103839] x86/mm: Memory block size: 128MB
[    0.105108] ACPI: PM: Registering ACPI NVS region [mem 0x7ecc1000-0x7ecc1fff] (4096 bytes)
[    0.105108] ACPI: PM: Registering ACPI NVS region [mem 0x8d8bc000-0x8dda8fff] (5165056 bytes)
[    0.105108] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.105108] posixtimers hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.105108] futex hash table entries: 4096 (262144 bytes on 1 NUMA nodes, total 256 KiB, linear).
[    0.105108] pinctrl core: initialized pinctrl subsystem
[    0.105411] PM: RTC time: 07:03:01, date: 2026-03-12
[    0.105778] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.105996] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.106092] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.106187] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.106191] audit: initializing netlink subsys (disabled)
[    0.106197] audit: type=2000 audit(1773298981.013:1): state=initialized audit_enabled=0 res=1
[    0.106197] thermal_sys: Registered thermal governor 'fair_share'
[    0.106197] thermal_sys: Registered thermal governor 'bang_bang'
[    0.106197] thermal_sys: Registered thermal governor 'step_wise'
[    0.106197] thermal_sys: Registered thermal governor 'user_space'
[    0.106197] thermal_sys: Registered thermal governor 'power_allocator'
[    0.106197] cpuidle: using governor ladder
[    0.106197] cpuidle: using governor menu
[    0.106197] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.106197] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.106456] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.106466] PCI: Using configuration type 1 for base access
[    0.106560] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.107458] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.107460] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.107462] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.107463] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.108254] raid6: skipped pq benchmark and selected avx2x4
[    0.108254] raid6: using avx2x2 recovery algorithm
[    0.108254] fbcon: Taking over console
[    0.108254] ACPI: Added _OSI(Module Device)
[    0.108254] ACPI: Added _OSI(Processor Device)
[    0.108254] ACPI: Added _OSI(Processor Aggregator Device)
[    0.154499] ACPI: 9 ACPI AML tables successfully acquired and loaded
[    0.158808] ACPI: Dynamic OEM Table Load:
[    0.158814] ACPI: SSDT 0xFFFF8C8A42139000 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
[    0.159645] ACPI: Dynamic OEM Table Load:
[    0.159650] ACPI: SSDT 0xFFFF8C8A42137000 00070D (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
[    0.160504] ACPI: Dynamic OEM Table Load:
[    0.160507] ACPI: SSDT 0xFFFF8C8A41612E00 0000FC (v02 PmRef  Cpu0Psd  00003000 INTL 20160527)
[    0.161263] ACPI: Dynamic OEM Table Load:
[    0.161267] ACPI: SSDT 0xFFFF8C8A420F2C00 00016C (v02 PmRef  Cpu0Hwp  00003000 INTL 20160527)
[    0.162010] ACPI: Dynamic OEM Table Load:
[    0.162015] ACPI: SSDT 0xFFFF8C8A42144000 000BEA (v02 PmRef  HwpLvt   00003000 INTL 20160527)
[    0.163363] ACPI: Dynamic OEM Table Load:
[    0.163368] ACPI: SSDT 0xFFFF8C8A42134800 000778 (v02 PmRef  ApIst    00003000 INTL 20160527)
[    0.164263] ACPI: Dynamic OEM Table Load:
[    0.164267] ACPI: SSDT 0xFFFF8C8A42138000 0003D7 (v02 PmRef  ApHwp    00003000 INTL 20160527)
[    0.165134] ACPI: Dynamic OEM Table Load:
[    0.165139] ACPI: SSDT 0xFFFF8C8A42140000 000D22 (v02 PmRef  ApPsd    00003000 INTL 20160527)
[    0.166562] ACPI: Dynamic OEM Table Load:
[    0.166566] ACPI: SSDT 0xFFFF8C8A42138C00 0003CA (v02 PmRef  ApCst    00003000 INTL 20160527)
[    0.172638] ACPI: Interpreter enabled
[    0.172669] ACPI: PM: (supports S0 S3 S4 S5)
[    0.172671] ACPI: Using IOAPIC for interrupt routing
[    0.173665] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.173667] PCI: Using E820 reservations for host bridge windows
[    0.174506] ACPI: Enabled 8 GPEs in block 00 to 7F
[    0.179468] ACPI: \_SB_.PCI0.RP03.PXSX.WRST: New power resource
[    0.179537] ACPI: \_SB_.PCI0.RP03.PXSX.DRST: New power resource
[    0.188094] ACPI: \_SB_.PCI0.SAT0.VOL0.V0PR: New power resource
[    0.188262] ACPI: \_SB_.PCI0.SAT0.VOL1.V1PR: New power resource
[    0.188424] ACPI: \_SB_.PCI0.SAT0.VOL2.V2PR: New power resource
[    0.194529] ACPI: \_TZ_.FN00: New power resource
[    0.194590] ACPI: \_TZ_.FN01: New power resource
[    0.194647] ACPI: \_TZ_.FN02: New power resource
[    0.194703] ACPI: \_TZ_.FN03: New power resource
[    0.194762] ACPI: \_TZ_.FN04: New power resource
[    0.195170] ACPI: \PIN_: New power resource
[    0.195678] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.195684] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.195766] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    0.195911] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[    0.195913] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.196814] PCI host bridge to bus 0000:00
[    0.196818] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.196819] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.196821] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.196822] pci_bus 0000:00: root bus resource [mem 0x90000000-0xdfffffff window]
[    0.196823] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
[    0.196824] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[    0.196825] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.196893] pci 0000:00:00.0: [8086:9b43] type 00 class 0x060000 conventional PCI endpoint
[    0.196952] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400 PCIe Root Port
[    0.196961] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.196963] pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
[    0.196965] pci 0000:00:01.0:   bridge window [mem 0x91000000-0x920fffff]
[    0.196969] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb20fffff 64bit pref]
[    0.196990] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.197497] pci 0000:00:14.0: [8086:a3af] type 00 class 0x0c0330 conventional PCI endpoint
[    0.197556] pci 0000:00:14.0: BAR 0 [mem 0x4000010000-0x400001ffff 64bit]
[    0.197615] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.198551] pci 0000:00:15.0: [8086:a3e0] type 00 class 0x118000 conventional PCI endpoint
[    0.199063] pci 0000:00:15.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[    0.209648] pci 0000:00:15.1: [8086:a3e1] type 00 class 0x118000 conventional PCI endpoint
[    0.209704] pci 0000:00:15.1: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[    0.220665] pci 0000:00:16.0: [8086:a3ba] type 00 class 0x078000 conventional PCI endpoint
[    0.220721] pci 0000:00:16.0: BAR 0 [mem 0x4000025000-0x4000025fff 64bit]
[    0.220775] pci 0000:00:16.0: PME# supported from D3hot
[    0.221256] pci 0000:00:17.0: [8086:a382] type 00 class 0x010601 conventional PCI endpoint
[    0.221393] pci 0000:00:17.0: BAR 0 [mem 0x92424000-0x92425fff]
[    0.221397] pci 0000:00:17.0: BAR 1 [mem 0x92427000-0x924270ff]
[    0.221401] pci 0000:00:17.0: BAR 2 [io  0x4050-0x4057]
[    0.221404] pci 0000:00:17.0: BAR 3 [io  0x4040-0x4043]
[    0.221408] pci 0000:00:17.0: BAR 4 [io  0x4020-0x403f]
[    0.221411] pci 0000:00:17.0: BAR 5 [mem 0x92426000-0x924267ff]
[    0.221533] pci 0000:00:17.0: PME# supported from D3hot
[    0.221667] pci 0000:00:1b.0: [8086:a3e9] type 01 class 0x060400 PCIe Root Port
[    0.221705] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.221713] pci 0000:00:1b.0:   bridge window [mem 0x92300000-0x923fffff]
[    0.221815] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.222271] pci 0000:00:1c.0: [8086:a392] type 01 class 0x060400 PCIe Root Port
[    0.222310] pci 0000:00:1c.0: PCI bridge to [bus 03]
[    0.222318] pci 0000:00:1c.0:   bridge window [mem 0x92200000-0x922fffff]
[    0.222422] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.222869] pci 0000:00:1d.0: [8086:a398] type 01 class 0x060400 PCIe Root Port
[    0.222908] pci 0000:00:1d.0: PCI bridge to [bus 04]
[    0.222916] pci 0000:00:1d.0:   bridge window [mem 0x92100000-0x921fffff]
[    0.223018] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.223461] pci 0000:00:1f.0: [8086:a3c8] type 00 class 0x060100 conventional PCI endpoint
[    0.223768] pci 0000:00:1f.2: [8086:a3a1] type 00 class 0x058000 conventional PCI endpoint
[    0.223824] pci 0000:00:1f.2: BAR 0 [mem 0x92420000-0x92423fff]
[    0.224063] pci 0000:00:1f.3: [8086:a3f0] type 00 class 0x040300 conventional PCI endpoint
[    0.224123] pci 0000:00:1f.3: BAR 0 [mem 0x4000020000-0x4000023fff 64bit]
[    0.224130] pci 0000:00:1f.3: BAR 4 [mem 0x4000000000-0x400000ffff 64bit]
[    0.224178] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.225232] pci 0000:00:1f.4: [8086:a3a3] type 00 class 0x0c0500 conventional PCI endpoint
[    0.225362] pci 0000:00:1f.4: BAR 0 [mem 0x4000024000-0x40000240ff 64bit]
[    0.225373] pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
[    0.225639] pci 0000:00:1f.6: [8086:0d55] type 00 class 0x020000 conventional PCI endpoint
[    0.225697] pci 0000:00:1f.6: BAR 0 [mem 0x92400000-0x9241ffff]
[    0.225758] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.226019] pci 0000:01:00.0: [10de:21c4] type 00 class 0x030000 PCIe Legacy Endpoint
[    0.226046] pci 0000:01:00.0: BAR 0 [mem 0x91000000-0x91ffffff]
[    0.226049] pci 0000:01:00.0: BAR 1 [mem 0xa0000000-0xafffffff 64bit pref]
[    0.226052] pci 0000:01:00.0: BAR 3 [mem 0xb0000000-0xb1ffffff 64bit pref]
[    0.226054] pci 0000:01:00.0: BAR 5 [io  0x3000-0x307f]
[    0.226057] pci 0000:01:00.0: ROM [mem 0x92000000-0x9207ffff pref]
[    0.226078] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.226111] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    0.226174] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.226256] pci 0000:01:00.1: [10de:1aeb] type 00 class 0x040300 PCIe Endpoint
[    0.226283] pci 0000:01:00.1: BAR 0 [mem 0x92080000-0x92083fff]
[    0.226376] pci 0000:01:00.2: [10de:1aec] type 00 class 0x0c0330 PCIe Endpoint
[    0.226403] pci 0000:01:00.2: BAR 0 [mem 0xb2000000-0xb203ffff 64bit pref]
[    0.226406] pci 0000:01:00.2: BAR 3 [mem 0xb2040000-0xb204ffff 64bit pref]
[    0.226445] pci 0000:01:00.2: PME# supported from D0 D3hot D3cold
[    0.226523] pci 0000:01:00.3: [10de:1aed] type 00 class 0x0c8000 PCIe Endpoint
[    0.226549] pci 0000:01:00.3: BAR 0 [mem 0x92084000-0x92084fff]
[    0.226590] pci 0000:01:00.3: PME# supported from D0 D3hot D3cold
[    0.226654] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.226759] pci 0000:02:00.0: [1b21:3241] type 00 class 0x0c0330 PCIe Legacy Endpoint
[    0.226818] pci 0000:02:00.0: BAR 0 [mem 0x92300000-0x92307fff 64bit]
[    0.226835] pci 0000:02:00.0: enabling Extended Tags
[    0.226942] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.227158] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.227296] pci 0000:03:00.0: [8086:2723] type 00 class 0x028000 PCIe Endpoint
[    0.227360] pci 0000:03:00.0: BAR 0 [mem 0x92200000-0x92203fff 64bit]
[    0.227496] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    0.227832] pci 0000:00:1c.0: PCI bridge to [bus 03]
[    0.227957] pci 0000:04:00.0: [8086:f1a8] type 00 class 0x010802 PCIe Endpoint
[    0.228016] pci 0000:04:00.0: BAR 0 [mem 0x92100000-0x92103fff 64bit]
[    0.228346] pci 0000:00:1d.0: PCI bridge to [bus 04]
[    0.230794] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.230872] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[    0.230948] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.231022] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.231098] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.231173] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.231248] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.231322] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.235421] iommu: Default domain type: Translated
[    0.235421] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.235508] SCSI subsystem initialized
[    0.235513] libata version 3.00 loaded.
[    0.235513] ACPI: bus type USB registered
[    0.235513] usbcore: registered new interface driver usbfs
[    0.235513] usbcore: registered new interface driver hub
[    0.235513] usbcore: registered new device driver usb
[    0.235513] EDAC MC: Ver: 3.0.0
[    0.235561] efivars: Registered efivars operations
[    0.235583] NetLabel: Initializing
[    0.235584] NetLabel:  domain hash size = 128
[    0.235585] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.235595] NetLabel:  unlabeled traffic allowed by default
[    0.235598] mctp: management component transport protocol core
[    0.235599] NET: Registered PF_MCTP protocol family
[    0.235606] PCI: Using ACPI for IRQ routing
[    0.263097] PCI: pci_cache_line_size set to 64 bytes
[    0.263192] e820: reserve RAM buffer [mem 0x0005e000-0x0005ffff]
[    0.263194] e820: reserve RAM buffer [mem 0x7ecc1000-0x7fffffff]
[    0.263195] e820: reserve RAM buffer [mem 0x7ece8000-0x7fffffff]
[    0.263196] e820: reserve RAM buffer [mem 0x8667a000-0x87ffffff]
[    0.263196] e820: reserve RAM buffer [mem 0x89c41000-0x8bffffff]
[    0.263197] e820: reserve RAM buffer [mem 0x8b8f9000-0x8bffffff]
[    0.263198] e820: reserve RAM buffer [mem 0x8efff000-0x8fffffff]
[    0.263199] e820: reserve RAM buffer [mem 0x46f000000-0x46fffffff]
[    0.263426] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.263426] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.263426] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.263426] vgaarb: loaded
[    0.263571] Monitor-Mwait will be used to enter C-1 state
[    0.263571] Monitor-Mwait will be used to enter C-2 state
[    0.263571] Monitor-Mwait will be used to enter C-3 state
[    0.264568] clocksource: Switched to clocksource tsc-early
[    0.264913] VFS: Disk quotas dquot_6.6.0
[    0.264925] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.265087] AppArmor: AppArmor Filesystem Enabled
[    0.265110] pnp: PnP ACPI init
[    0.265171] system 00:00: [mem 0x40000000-0x403fffff] has been reserved
[    0.265328] system 00:01: [io  0x0290-0x029f] has been reserved
[    0.265626] pnp 00:02: [dma 0 disabled]
[    0.265737] system 00:03: [io  0x0680-0x069f] has been reserved
[    0.265843] system 00:04: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.265845] system 00:04: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.265847] system 00:04: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.265848] system 00:04: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.265850] system 00:04: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.265851] system 00:04: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.265852] system 00:04: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.265853] system 00:04: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.265855] system 00:04: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.265856] system 00:04: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.266108] system 00:05: [io  0x2000-0x20fe] has been reserved
[    0.266337] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.266340] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.266341] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.266342] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[    0.266343] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.266345] system 00:06: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.266346] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.266347] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.266645] system 00:07: [mem 0xfe038000-0xfe038fff] has been reserved
[    0.267033] pnp: PnP ACPI: found 8 devices
[    0.272441] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.272485] NET: Registered PF_INET protocol family
[    0.272593] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.283505] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.283522] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.283556] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.283742] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.283922] TCP: Hash tables configured (established 131072 bind 65536)
[    0.283979] MPTCP token hash table entries: 16384 (order: 7, 393216 bytes, linear)
[    0.284032] UDP hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.284094] UDP-Lite hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.284158] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.284163] NET: Registered PF_XDP protocol family
[    0.284173] pci 0000:00:15.0: BAR 0 [mem 0x4000026000-0x4000026fff 64bit]: assigned
[    0.284187] pci 0000:00:15.1: BAR 0 [mem 0x4000027000-0x4000027fff 64bit]: assigned
[    0.284200] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.284201] pci 0000:00:01.0:   bridge window [io  0x3000-0x3fff]
[    0.284203] pci 0000:00:01.0:   bridge window [mem 0x91000000-0x920fffff]
[    0.284205] pci 0000:00:01.0:   bridge window [mem 0xa0000000-0xb20fffff 64bit pref]
[    0.284208] pci 0000:00:1b.0: PCI bridge to [bus 02]
[    0.284213] pci 0000:00:1b.0:   bridge window [mem 0x92300000-0x923fffff]
[    0.284223] pci 0000:00:1c.0: PCI bridge to [bus 03]
[    0.284228] pci 0000:00:1c.0:   bridge window [mem 0x92200000-0x922fffff]
[    0.284238] pci 0000:00:1d.0: PCI bridge to [bus 04]
[    0.284243] pci 0000:00:1d.0:   bridge window [mem 0x92100000-0x921fffff]
[    0.284253] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.284254] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.284255] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.284257] pci_bus 0000:00: resource 7 [mem 0x90000000-0xdfffffff window]
[    0.284257] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
[    0.284259] pci_bus 0000:00: resource 9 [mem 0xfc800000-0xfe7fffff window]
[    0.284260] pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
[    0.284261] pci_bus 0000:01: resource 1 [mem 0x91000000-0x920fffff]
[    0.284261] pci_bus 0000:01: resource 2 [mem 0xa0000000-0xb20fffff 64bit pref]
[    0.284263] pci_bus 0000:02: resource 1 [mem 0x92300000-0x923fffff]
[    0.284264] pci_bus 0000:03: resource 1 [mem 0x92200000-0x922fffff]
[    0.284265] pci_bus 0000:04: resource 1 [mem 0x92100000-0x921fffff]
[    0.284449] pci 0000:01:00.1: extending delay after power-on from D3hot to 20 msec
[    0.284469] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.284516] pci 0000:01:00.2: D0 power state depends on 0000:01:00.0
[    0.284736] pci 0000:01:00.3: D0 power state depends on 0000:01:00.0
[    0.284934] PCI: CLS 64 bytes, default 64
[    0.284973] pci 0000:00:1f.1: [8086:a3a0] type 00 class 0x058000 conventional PCI endpoint
[    0.285108] pci 0000:00:1f.1: BAR 0 [mem 0xfd000000-0xfdffffff 64bit]
[    0.285219] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.285220] software IO TLB: mapped [mem 0x00000000822d8000-0x00000000862d8000] (64MB)
[    0.285275] platform rtc_cmos: registered platform RTC device (no PNP device found)
[    0.285279] Trying to unpack rootfs image as initramfs...
[    0.304652] Initialise system trusted keyrings
[    0.304660] Key type blacklist registered
[    0.304761] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[    0.304990] fuse: init (API version 7.45)
[    0.305341] integrity: Platform Keyring initialized
[    0.305343] integrity: Machine keyring initialized
[    0.314393] xor: automatically using best checksumming function   avx
[    0.314396] Key type asymmetric registered
[    0.314397] Asymmetric key parser 'x509' registered
[    0.314417] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.314526] io scheduler mq-deadline registered
[    0.314527] io scheduler kyber registered
[    0.314539] io scheduler bfq registered
[    0.316149] ledtrig-cpu: registered to indicate activity on CPUs
[    0.316433] pcieport 0000:00:1b.0: AER: enabled with IRQ 121
[    0.316822] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[    0.317148] pcieport 0000:00:1d.0: AER: enabled with IRQ 123
[    0.317348] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    0.317367] ACPI: button: Sleep Button [SLPB]
[    0.317388] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.317400] ACPI: button: Power Button [PWRB]
[    0.317420] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.317459] ACPI: button: Power Button [PWRF]
[    0.320060] thermal LNXTHERM:00: registered as thermal_zone0
[    0.320061] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    0.320232] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.320596] 00:02: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.322536] hpet_acpi_add: no address or irqs in _CRS
[    0.322566] Non-volatile memory driver v1.3
[    0.322567] Linux agpgart interface v0.103
[    0.353536] Freeing initrd memory: 130220K
[    0.497209] ACPI: bus type drm_connector registered
[    0.499380] ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
[    0.499383] ahci 0000:00:17.0: 6/6 ports implemented (port mask 0x3f)
[    0.499385] ahci 0000:00:17.0: flags: 64bit ncq sntf pm led clo only pio slum part ems deso sadm sds apst
[    0.549265] scsi host0: ahci
[    0.549564] scsi host1: ahci
[    0.549812] scsi host2: ahci
[    0.550011] scsi host3: ahci
[    0.550174] scsi host4: ahci
[    0.550267] scsi host5: ahci
[    0.550295] ata1: SATA max UDMA/133 abar m2048@0x92426000 port 0x92426100 irq 124 lpm-pol 3
[    0.550299] ata2: SATA max UDMA/133 abar m2048@0x92426000 port 0x92426180 irq 124 lpm-pol 3
[    0.550303] ata3: SATA max UDMA/133 abar m2048@0x92426000 port 0x92426200 irq 124 lpm-pol 3
[    0.550307] ata4: SATA max UDMA/133 abar m2048@0x92426000 port 0x92426280 irq 124 lpm-pol 3
[    0.550311] ata5: SATA max UDMA/133 abar m2048@0x92426000 port 0x92426300 irq 124 lpm-pol 3
[    0.550314] ata6: SATA max UDMA/133 abar m2048@0x92426000 port 0x92426380 irq 124 lpm-pol 3
[    0.550433] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.550438] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    0.551589] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000109810
[    0.552065] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.552067] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.552070] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    0.552101] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[    0.552103] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.552104] usb usb1: Product: xHCI Host Controller
[    0.552105] usb usb1: Manufacturer: Linux 6.18.12-1-MANJARO xhci-hcd
[    0.552106] usb usb1: SerialNumber: 0000:00:14.0
[    0.552215] hub 1-0:1.0: USB hub found
[    0.552242] hub 1-0:1.0: 12 ports detected
[    0.554044] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[    0.554046] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.554047] usb usb2: Product: xHCI Host Controller
[    0.554048] usb usb2: Manufacturer: Linux 6.18.12-1-MANJARO xhci-hcd
[    0.554049] usb usb2: SerialNumber: 0000:00:14.0
[    0.554108] hub 2-0:1.0: USB hub found
[    0.554127] hub 2-0:1.0: 8 ports detected
[    0.555344] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    0.555347] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 3
[    0.555920] xhci_hcd 0000:01:00.2: hcc params 0x0180ff05 hci version 0x110 quirks 0x0000000000000010
[    0.556019] xhci_hcd 0000:01:00.2: xHCI Host Controller
[    0.556021] xhci_hcd 0000:01:00.2: new USB bus registered, assigned bus number 4
[    0.556022] xhci_hcd 0000:01:00.2: Host supports USB 3.1 Enhanced SuperSpeed
[    0.556056] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[    0.556058] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.556059] usb usb3: Product: xHCI Host Controller
[    0.556060] usb usb3: Manufacturer: Linux 6.18.12-1-MANJARO xhci-hcd
[    0.556061] usb usb3: SerialNumber: 0000:01:00.2
[    0.556190] hub 3-0:1.0: USB hub found
[    0.556198] hub 3-0:1.0: 2 ports detected
[    0.556396] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.556410] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[    0.556412] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.556413] usb usb4: Product: xHCI Host Controller
[    0.556414] usb usb4: Manufacturer: Linux 6.18.12-1-MANJARO xhci-hcd
[    0.556415] usb usb4: SerialNumber: 0000:01:00.2
[    0.556529] hub 4-0:1.0: USB hub found
[    0.556538] hub 4-0:1.0: 4 ports detected
[    0.556953] xhci_hcd 0000:02:00.0: xHCI Host Controller
[    0.556957] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 5
[    0.557227] pcieport 0000:00:1b.0: AER: Multiple Correctable error message received from 0000:00:1b.0
[    0.557234] pcieport 0000:00:1b.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[    0.557235] pcieport 0000:00:1b.0:   device [8086:a3e9] error status/mask=00000041/00002000
[    0.557237] pcieport 0000:00:1b.0:    [ 0] RxErr                  (First)
[    0.557238] pcieport 0000:00:1b.0:    [ 6] BadTLP
[    0.557239] pcieport 0000:00:1b.0: AER:   Error of this Agent is reported first
[    0.557248] xhci_hcd 0000:02:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[    0.557249] xhci_hcd 0000:02:00.0:   device [1b21:3241] error status/mask=00000001/00002000
[    0.557250] xhci_hcd 0000:02:00.0:    [ 0] RxErr                  (First)
[    0.612673] xhci_hcd 0000:02:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000010
[    0.612883] xhci_hcd 0000:02:00.0: xHCI Host Controller
[    0.612885] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 6
[    0.612887] xhci_hcd 0000:02:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[    0.612937] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
[    0.612938] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.612940] usb usb5: Product: xHCI Host Controller
[    0.612940] usb usb5: Manufacturer: Linux 6.18.12-1-MANJARO xhci-hcd
[    0.612941] usb usb5: SerialNumber: 0000:02:00.0
[    0.613034] hub 5-0:1.0: USB hub found
[    0.613040] hub 5-0:1.0: 1 port detected
[    0.613123] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.613136] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
[    0.613137] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.613138] usb usb6: Product: xHCI Host Controller
[    0.613139] usb usb6: Manufacturer: Linux 6.18.12-1-MANJARO xhci-hcd
[    0.613140] usb usb6: SerialNumber: 0000:02:00.0
[    0.613223] hub 6-0:1.0: USB hub found
[    0.613227] hub 6-0:1.0: 1 port detected
[    0.613323] usbcore: registered new interface driver usbserial_generic
[    0.613327] usbserial: USB Serial support registered for generic
[    0.613351] i8042: PNP: No PS/2 controller found.
[    0.613421] rtc_cmos rtc_cmos: RTC can wake from S4
[    0.614110] rtc_cmos rtc_cmos: registered as rtc0
[    0.614235] rtc_cmos rtc_cmos: setting system clock to 2026-03-12T07:03:02 UTC (1773298982)
[    0.614261] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[    0.614746] intel_pstate: Intel P-state driver initializing
[    0.615396] intel_pstate: HWP enabled
[    0.615461] Relocating firmware framebuffer to offset 0x0000000001000000[d] within [mem 0xb0000000-0xb1ffffff flags 0x14220c]
[    0.615556] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[    0.615557] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[    0.617169] Console: switching to colour frame buffer device 128x48
[    0.618542] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.618706] hid: raw HID events driver (C) Jiri Kosina
[    0.618728] usbcore: registered new interface driver usbhid
[    0.618729] usbhid: USB HID core driver
[    0.618786] drop_monitor: Initializing network drop monitor service
[    0.618860] NET: Registered PF_INET6 protocol family
[    0.619314] Segment Routing with IPv6
[    0.619316] RPL Segment Routing with IPv6
[    0.619323] In-situ OAM (IOAM) with IPv6
[    0.619337] NET: Registered PF_PACKET protocol family
[    0.620522] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.621015] microcode: Current revision: 0x00000100
[    0.621016] microcode: Updated early from: 0x000000c8
[    0.621593] IPI shorthand broadcast: enabled
[    0.622792] sched_clock: Marking stable (617000827, 5621259)->(659744231, -37122145)
[    0.623031] registered taskstats version 1
[    0.624206] Loading compiled-in X.509 certificates
[    0.627655] Loaded X.509 cert 'Build time autogenerated kernel key: 9837b74f86a727b821f967c72f9b6bd3718fd061'
[    0.629145] zswap: loaded using pool zstd
[    0.629201] Demotion targets for Node 0: null
[    0.629339] Key type .fscrypt registered
[    0.629339] Key type fscrypt-provisioning registered
[    0.629469] Btrfs loaded, zoned=yes, fsverity=yes
[    0.629482] Key type big_key registered
[    0.629483] AppArmor: AppArmor sha256 policy hashing enabled
[    0.629720] integrity: Loading X.509 certificate: UEFI:db
[    0.631466] integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
[    0.631467] integrity: Loading X.509 certificate: UEFI:db
[    0.631562] integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
[    0.631563] integrity: Loading X.509 certificate: UEFI:db
[    0.631572] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    0.631572] integrity: Loading X.509 certificate: UEFI:db
[    0.631579] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    0.631580] integrity: Loading X.509 certificate: UEFI:db
[    0.631703] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[    0.632309] PM:   Magic number: 2:137:66
[    0.632376] memory memory94: hash matches
[    0.633147] RAS: Correctable Errors collector initialized.
[    0.795779] usb 1-4: new high-speed USB device number 2 using xhci_hcd
[    0.856666] ata5: SATA link down (SStatus 4 SControl 300)
[    0.856729] ata4: SATA link down (SStatus 4 SControl 300)
[    0.856785] ata2: SATA link down (SStatus 4 SControl 300)
[    0.861945] ata6: SATA link down (SStatus 4 SControl 300)
[    0.862010] ata3: SATA link down (SStatus 4 SControl 300)
[    0.862066] ata1: SATA link down (SStatus 4 SControl 300)
[    0.862601] clk: Disabling unused clocks
[    0.862609] PM: genpd: Disabling unused power domains
[    0.867689] Freeing unused decrypted memory: 2028K
[    0.870078] Freeing unused kernel image (initmem) memory: 4732K
[    0.870138] Write protecting the kernel read-only data: 36864k
[    0.871221] Freeing unused kernel image (text/rodata gap) memory: 216K
[    0.871402] Freeing unused kernel image (rodata/data gap) memory: 12K
[    0.907676] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.907681] rodata_test: all tests were successful
[    0.907687] Run /init as init process
[    0.907688]   with arguments:
[    0.907690]     /init
[    0.907692]   with environment:
[    0.907693]     HOME=/
[    0.907694]     TERM=linux
[    0.919179] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[    0.919181] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    0.919182] usb 1-4: Product: USB 2.0 Hub
[    0.920071] hub 1-4:1.0: USB hub found
[    0.920171] hub 1-4:1.0: 4 ports detected
[    1.032673] usb 1-6: new low-speed USB device number 3 using xhci_hcd
[    1.063404] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[    1.063582] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    1.067123] intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
[    1.067420] idma64 idma64.1: Found Intel integrated DMA 64-bit
[    1.073497] Key type psk registered
[    1.081851] nvme 0000:04:00.0: platform quirk: setting simple suspend
[    1.081899] nvme nvme0: pci function 0000:04:00.0
[    1.090001] nvme nvme0: 8/0/0 default/read/poll queues
[    1.092834]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8
[    1.165010] usb 1-6: New USB device found, idVendor=04f3, idProduct=152e, bcdDevice=3f.29
[    1.165025] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.165031] usb 1-6: Product: Gaming KB
[    1.165036] usb 1-6: Manufacturer: Gaming KB
[    1.172200] input: Gaming KB Gaming KB as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:04F3:152E.0001/input/input3
[    1.196489] hid-generic 0003:04F3:152E.0001: input,hidraw0: USB HID v1.11 Keyboard [Gaming KB Gaming KB] on usb-0000:00:14.0-6/input0
[    1.204729] input: Gaming KB Gaming KB Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:04F3:152E.0002/input/input4
[    1.205014] input: Gaming KB Gaming KB System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:04F3:152E.0002/input/input5
[    1.205226] input: Gaming KB Gaming KB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:04F3:152E.0002/input/input6
[    1.205428] input: Gaming KB Gaming KB as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:04F3:152E.0002/input/input7
[    1.205857] hid-generic 0003:04F3:152E.0002: input,hiddev96,hidraw1: USB HID v1.11 Keyboard [Gaming KB Gaming KB] on usb-0000:00:14.0-6/input1
[    1.317915] usb 1-8: new full-speed USB device number 4 using xhci_hcd
[    1.339914] tsc: Refined TSC clocksource calibration: 3792.010 MHz
[    1.339939] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d51b950bb2, max_idle_ns: 881591049689 ns
[    1.340046] clocksource: Switched to clocksource tsc
[    1.465035] usb 1-8: New USB device found, idVendor=3151, idProduct=1025, bcdDevice= 0.02
[    1.465051] usb 1-8: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.465057] usb 1-8: Product: Wireless Device
[    1.465062] usb 1-8: Manufacturer: YICHIP
[    1.465067] usb 1-8: SerialNumber: b120300001
[    1.479646] hid-generic 0003:3151:1025.0003: hiddev97,hidraw2: USB HID v2.00 Device [YICHIP Wireless Device] on usb-0000:00:14.0-8/input0
[    1.498054] input: YICHIP Wireless Device Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:3151:1025.0004/input/input8
[    1.498380] input: YICHIP Wireless Device System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:3151:1025.0004/input/input9
[    1.549157] input: YICHIP Wireless Device Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.1/0003:3151:1025.0004/input/input10
[    1.549828] hid-generic 0003:3151:1025.0004: input,hiddev98,hidraw3: USB HID v2.00 Mouse [YICHIP Wireless Device] on usb-0000:00:14.0-8/input1
[    1.661925] usb 1-9: new high-speed USB device number 5 using xhci_hcd
[    1.787221] usb 1-9: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=60.60
[    1.787236] usb 1-9: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.787242] usb 1-9: Product: USB2.0 Hub
[    1.789819] hub 1-9:1.0: USB hub found
[    1.790212] hub 1-9:1.0: 4 ports detected
[    1.907911] usb 1-10: new full-speed USB device number 6 using xhci_hcd
[    2.033168] usb 1-10: config 1 has an invalid interface number: 2 but max is 1
[    2.033181] usb 1-10: config 1 has no interface number 1
[    2.034372] usb 1-10: New USB device found, idVendor=0b05, idProduct=1939, bcdDevice= 1.00
[    2.034374] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.034375] usb 1-10: Product: AURA LED Controller
[    2.034376] usb 1-10: Manufacturer: AsusTek Computer Inc.
[    2.034376] usb 1-10: SerialNumber: 9876543210
[    2.037345] hid-generic 0003:0B05:1939.0005: hiddev99,hidraw4: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:00:14.0-10/input2
[    2.093934] usb 1-9.2: new full-speed USB device number 7 using xhci_hcd
[    2.173139] usb 1-9.2: New USB device found, idVendor=0b05, idProduct=1866, bcdDevice= 0.03
[    2.173151] usb 1-9.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.173156] usb 1-9.2: Product: ITE Device(8910)
[    2.173159] usb 1-9.2: Manufacturer: ITE Tech. Inc.
[    2.181008] hid-generic 0003:0B05:1866.0006: hiddev100,hidraw5: USB HID v1.10 Device [ITE Tech. Inc. ITE Device(8910)] on usb-0000:00:14.0-9.2/input0
[    2.280939] usb 1-12: new full-speed USB device number 8 using xhci_hcd
[    2.406269] usb 1-12: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[    2.406285] usb 1-12: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.431888] asus_wmi: ASUS WMI generic driver loaded
[    2.434177] asus 0003:0B05:1866.0006: Fixing up Asus N-Key report descriptor
[    2.437792] asus 0003:0B05:1866.0006: hiddev100,hidraw5: USB HID v1.10 Device [ITE Tech. Inc. ITE Device(8910)] on usb-0000:00:14.0-9.2/input0
[    2.437794] asus 0003:0B05:1866.0006: Asus input not registered
[    2.437848] asus 0003:0B05:1866.0006: probe with driver asus failed with error -12
[    2.450643] PM: Image not found (code -22)
[    2.464648] EXT4-fs (nvme0n1p8): mounted filesystem 82da9cde-4a3f-461c-b700-8826d12e2470 r/w with ordered data mode. Quota mode: none.
[    2.619980] systemd[1]: systemd 259.1-1-manjaro running in system mode (+PAM +AUDIT -SELINUX +APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[    2.619985] systemd[1]: Detected architecture x86-64.
[    2.630383] systemd[1]: Hostname set to <rog-desktop>.
[    2.732014] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[    3.065723] systemd[1]: Queued start job for default target Graphical Interface.
[    3.077605] systemd[1]: Created slice Slice /system/dirmngr.
[    3.077868] systemd[1]: Created slice Slice /system/getty.
[    3.078086] systemd[1]: Created slice Slice /system/gpg-agent.
[    3.078304] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[    3.078522] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[    3.078748] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[    3.078961] systemd[1]: Created slice Slice /system/keyboxd.
[    3.079182] systemd[1]: Created slice Slice /system/modprobe.
[    3.079393] systemd[1]: Created slice Slice /system/systemd-fsck.
[    3.079549] systemd[1]: Created slice User and Session Slice.
[    3.079604] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.079657] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.079772] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.079808] systemd[1]: Expecting device /dev/disk/by-uuid/7baed187-5907-4ce2-9127-4023d5d1561d...
[    3.079834] systemd[1]: Expecting device /dev/disk/by-uuid/B33B-8942...
[    3.079857] systemd[1]: Reached target Local Encrypted Volumes.
[    3.079885] systemd[1]: Reached target Login Prompts.
[    3.079909] systemd[1]: Reached target Image Downloads.
[    3.079932] systemd[1]: Reached target Local Integrity Protected Volumes.
[    3.079964] systemd[1]: Reached target Remote File Systems.
[    3.079989] systemd[1]: Reached target Slice Units.
[    3.080014] systemd[1]: Reached target Mounting snaps.
[    3.080037] systemd[1]: Reached target Mounted snaps.
[    3.080072] systemd[1]: Reached target Local Verity Protected Volumes.
[    3.080133] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    3.080210] systemd[1]: Listening on LVM2 poll daemon socket.
[    3.080945] systemd[1]: Listening on Query the User Interactively for a Password.
[    3.081668] systemd[1]: Listening on Process Core Dump Socket.
[    3.082201] systemd[1]: Listening on Credential Encryption/Decryption.
[    3.082855] systemd[1]: Listening on Factory Reset Management.
[    3.082950] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.083127] systemd[1]: Listening on Journal Sockets.
[    3.084114] systemd[1]: Listening on Console Output Muting Service Socket.
[    3.084259] systemd[1]: TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
[    3.084270] systemd[1]: Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[    3.084804] systemd[1]: Listening on Disk Repartitioning Service Socket.
[    3.084972] systemd[1]: Listening on udev Control Socket.
[    3.085119] systemd[1]: Listening on udev Kernel Socket.
[    3.085269] systemd[1]: Listening on udev Varlink Socket.
[    3.086191] systemd[1]: Mounting Huge Pages File System...
[    3.086687] systemd[1]: Mounting POSIX Message Queue File System...
[    3.087177] systemd[1]: Mounting Kernel Debug File System...
[    3.087670] systemd[1]: Mounting Kernel Trace File System...
[    3.088217] systemd[1]: Starting Load AppArmor profiles...
[    3.088832] systemd[1]: Starting Create List of Static Device Nodes...
[    3.089338] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    3.089551] systemd[1]: Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[    3.090105] systemd[1]: Mounting Kernel Configuration File System...
[    3.090310] systemd[1]: Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[    3.090338] systemd[1]: Load Kernel Module fuse skipped, unmet condition check ConditionKernelModuleLoaded=!fuse
[    3.090901] systemd[1]: Mounting FUSE Control File System...
[    3.091129] systemd[1]: File System Check on Root Device skipped, unmet condition check ConditionPathIsReadWrite=!/
[    3.091162] systemd[1]: Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[    3.092283] systemd[1]: Starting Journal Service...
[    3.094404] systemd[1]: Starting Load Kernel Modules...
[    3.094939] systemd[1]: TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    3.094963] systemd[1]: TPM NvPCR Product ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
[    3.095485] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.095640] systemd[1]: Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    3.096154] systemd[1]: Starting Load udev Rules from Credentials...
[    3.096659] systemd[1]: Starting Coldplug All udev Devices...
[    3.098092] systemd[1]: Finished Create List of Static Device Nodes.
[    3.102924] systemd[1]: Mounted Huge Pages File System.
[    3.103132] systemd[1]: Mounted POSIX Message Queue File System.
[    3.103310] systemd[1]: Mounted Kernel Debug File System.
[    3.103475] systemd[1]: Mounted Kernel Trace File System.
[    3.103645] systemd[1]: Mounted Kernel Configuration File System.
[    3.103829] systemd[1]: Mounted FUSE Control File System.
[    3.104486] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    3.106656] systemd[1]: Finished Load udev Rules from Credentials.
[    3.107919] systemd-journald[388]: Collecting audit messages is disabled.
[    3.116749] EXT4-fs (nvme0n1p8): re-mounted 82da9cde-4a3f-461c-b700-8826d12e2470.
[    3.117399] systemd[1]: Finished Remount Root and Kernel File Systems.
[    3.118384] systemd[1]: Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
[    3.119134] systemd[1]: Starting Load/Save OS Random Seed...
[    3.119997] systemd[1]: TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
[    3.120017] systemd[1]: TPM PCR NvPCR Initialization Separator skipped, unmet condition check ConditionSecurity=measured-uki
[    3.121936] i2c_dev: i2c /dev entries driver
[    3.122967] loop: module loaded
[    3.134493] systemd[1]: Finished Load/Save OS Random Seed.
[    3.137650] device-mapper: uevent: version 1.0.3
[    3.137699] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[    3.145389] systemd[1]: Started Journal Service.
[    3.146872] audit: type=1400 audit(1773298985.031:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=426 comm="apparmor_parser"
[    3.146901] audit: type=1400 audit(1773298985.031:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=422 comm="apparmor_parser"
[    3.146918] audit: type=1400 audit(1773298985.031:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=417 comm="apparmor_parser"
[    3.146933] audit: type=1400 audit(1773298985.031:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=424 comm="apparmor_parser"
[    3.146953] audit: type=1400 audit(1773298985.031:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=425 comm="apparmor_parser"
[    3.146974] audit: type=1400 audit(1773298985.031:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="chromium" pid=431 comm="apparmor_parser"
[    3.146990] audit: type=1400 audit(1773298985.031:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="vscode" pid=432 comm="apparmor_parser"
[    3.147055] audit: type=1400 audit(1773298985.031:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=418 comm="apparmor_parser"
[    3.147059] audit: type=1400 audit(1773298985.031:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=420 comm="apparmor_parser"
[    3.180770] systemd-journald[388]: Received client request to flush runtime journal.
[    3.224936] kvm_amd: CPU 12 isn't AMD or Hygon
[    3.267663] vboxdrv: loading out-of-tree module taints kernel.
[    3.267668] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[    3.280451] vboxdrv: Found 16 processor cores/threads
[    3.344723] rtR0InitNative: g_pLnxInitMm=00000000ad265e0e
[    3.373636] vboxdrv: Found KVM hardware-virtualization symbols
[    3.373638] vboxdrv: TSC mode is Invariant, tentative frequency 3791999547 Hz
[    3.373640] vboxdrv: Successfully loaded version 7.2.6 r172322 (interface 0x00340002)
[    3.378384] VBoxNetAdp: Successfully started.
[    3.378927] VBoxNetFlt: Successfully started.
[    3.458907] nvidia: module license 'NVIDIA' taints kernel.
[    3.458909] Disabling lock debugging due to kernel taint
[    3.458913] nvidia: module license taints kernel.
[    3.601580] Adding 33554428k swap on /dev/nvme0n1p7.  Priority:-2 extents:1 across:33554428k SS
[    3.657810] input: PC Speaker as /devices/platform/pcspkr/input/input12
[    3.657865] asus_wmi: Initialization: 0x1
[    3.657914] asus_wmi: BIOS WMI version: 9.0
[    3.657948] asus_wmi: SFUN value: 0x21
[    3.657951] eeepc-wmi eeepc-wmi: Detected ATK, not ASUSWMI, use DSTS
[    3.661685] eeepc-wmi eeepc-wmi: Using throttle_thermal_policy for platform_profile support
[    3.662099] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[    3.663342] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input13
[    3.664310] asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
[    3.664431] asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
[    3.664555] asus_wmi: fan_curve_get_factory_default (0x00110032) failed: -19
[    3.669659] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[    3.692799] pps_core: LinuxPPS API ver. 1 registered
[    3.692801] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.692904] mousedev: PS/2 mouse device common for all mice
[    3.692954] Bluetooth: Core ver 2.22
[    3.692966] NET: Registered PF_BLUETOOTH protocol family
[    3.692967] Bluetooth: HCI device and connection manager initialized
[    3.692971] Bluetooth: HCI socket layer initialized
[    3.692972] Bluetooth: L2CAP socket layer initialized
[    3.692974] Bluetooth: SCO socket layer initialized
[    3.693453] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.693560] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.693660] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    3.700492] PTP clock support registered
[    3.700499] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    3.701150] asus_armoury: No matching power limits found for this system
[    3.702100] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    3.704854] i2c i2c-3: Successfully instantiated SPD at 0x51
[    3.705307] i2c i2c-3: Successfully instantiated SPD at 0x53
[    3.711781] iTCO_vendor_support: vendor-support=0
[    3.711879] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[    3.711881] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    3.711882] RAPL PMU: hw unit of domain package 2^-14 Joules
[    3.711884] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    3.711903] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[    3.716447] resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:04 [mem 0xfdb00000-0xfdffffff]
[    3.716450] caller get_primary_reg_base+0x4c/0xa0 [intel_pmc_core] mapping multiple BARs
[    3.716478] intel_pmc_core INT33A1:00:  initialized
[    3.718195] ee1004 3-0051: 512 byte EE1004-compliant SPD EEPROM, read-only
[    3.719670] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  590.48.01  Mon Dec  8 11:22:45 UTC 2025
[    3.719798] ee1004 3-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
[    3.719842] iwlwifi 0000:03:00.0: Detected crf-id 0x3617, cnv-id 0x100530 wfpm id 0x80000000
[    3.719858] iwlwifi 0000:03:00.0: PCI dev 2723/0084, rev=0x340, rfid=0x10a100
[    3.719860] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz
[    3.734675] ACPI: bus type thunderbolt registered
[    3.734920] e1000e: Intel(R) PRO/1000 Network Driver
[    3.734922] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.735178] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    3.737942] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[    3.738012] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    3.739230] usbcore: registered new interface driver btusb
[    3.739905] Bluetooth: hci0: Bootloader revision 0.3 build 0 week 24 2017
[    3.740908] Bluetooth: hci0: Device revision is 1
[    3.740911] Bluetooth: hci0: Secure boot is enabled
[    3.740912] Bluetooth: hci0: OTP lock is enabled
[    3.740912] Bluetooth: hci0: API lock is enabled
[    3.740913] Bluetooth: hci0: Debug lock is disabled
[    3.740914] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    3.746090] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[    3.750348] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  590.48.01  Mon Dec  8 12:50:27 UTC 2025
[    3.754072] iwlwifi 0000:03:00.0: loaded firmware version 77.f39cc7f9.0 cc-a0-77.ucode op_mode iwlmvm
[    3.768542] Bluetooth: hci0: Found device firmware: intel/ibt-20-1-3.sfi
[    3.768570] Bluetooth: hci0: Boot Address: 0x24800
[    3.768571] Bluetooth: hci0: Firmware Version: 193-33.24
[    3.798196] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    3.806821] intel_tcc_cooling: Programmable TCC Offset detected
[    3.810585] snd_hda_intel 0000:00:1f.3: Applying patch firmware 'hda-jack-retask.fw'
[    3.810712] snd_hda_intel 0000:01:00.1: Disabling MSI
[    3.810716] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    3.810720] snd_hda_intel 0000:01:00.1: Applying patch firmware 'hda-jack-retask.fw'
[    3.855807] snd_hda_codec_alc882 hdaudioC0D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[    3.855811] snd_hda_codec_alc882 hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.855812] snd_hda_codec_alc882 hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.855813] snd_hda_codec_alc882 hdaudioC0D0:    mono: mono_out=0x0
[    3.855814] snd_hda_codec_alc882 hdaudioC0D0:    dig-out=0x1e/0x0
[    3.855814] snd_hda_codec_alc882 hdaudioC0D0:    inputs:
[    3.855815] snd_hda_codec_alc882 hdaudioC0D0:      Rear Mic=0x18
[    3.855816] snd_hda_codec_alc882 hdaudioC0D0:      Mic=0x19
[    3.855817] snd_hda_codec_alc882 hdaudioC0D0:      Rear Mic=0x17
[    3.855818] snd_hda_codec_alc882 hdaudioC0D0:      Line=0x1a
[    3.865351] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[    3.865384] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[    3.865407] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[    3.865434] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[    3.869138] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[    3.869165] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[    3.869193] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[    3.869220] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input21
[    3.869250] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[    3.869270] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[    3.869300] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[    3.869328] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[    3.923073] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[    3.930149] intel_rapl_common: Found RAPL domain package
[    3.930150] intel_rapl_common: Found RAPL domain core
[    3.930151] intel_rapl_common: Found RAPL domain dram
[    3.990320] iwlwifi 0000:03:00.0: Detected RF HR B3, rfid=0x10a100
[    4.056693] iwlwifi 0000:03:00.0: base HW address: c8:e2:65:0e:a3:44
[    4.069893] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 24:4b:fe:95:b8:b5
[    4.069895] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[    4.069996] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[    4.077148] e1000e 0000:00:1f.6 enp0s31f6: renamed from eth0
[    4.077485] iwlwifi 0000:03:00.0 wlo1: renamed from wlan0
[    4.800128] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[    4.800132] ucsi_ccg 2-0008: i2c_transfer failed -110
[    4.800133] ucsi_ccg 2-0008: ucsi_ccg_init failed - -110
[    4.800138] ucsi_ccg 2-0008: probe with driver ucsi_ccg failed with error -110
[    4.917969] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
[    4.938720] Console: switching to colour dummy device 80x25
[    4.955807] nvidia 0000:01:00.0: vgaarb: deactivate vga console
[    5.009596] fbcon: nvidia-drmdrmfb (fb0) is primary device
[    5.208927] Console: switching to colour frame buffer device 240x67
[    5.225862] nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
[    5.356171] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.356173] Bluetooth: BNEP filters: protocol multicast
[    5.356175] Bluetooth: BNEP socket layer initialized
[    5.388770] Bluetooth: hci0: Waiting for firmware download to complete
[    5.388879] Bluetooth: hci0: Firmware loaded in 1582358 usecs
[    5.388896] Bluetooth: hci0: Waiting for device to boot
[    5.402907] Bluetooth: hci0: Device booted in 13688 usecs
[    5.404482] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-20-1-3.ddc
[    5.405915] Bluetooth: hci0: Applying Intel DDC parameters completed
[    5.406917] Bluetooth: hci0: Firmware revision 0.3 build 193 week 33 2024
[    5.408935] Bluetooth: hci0: HCI LE Coded PHY feature bit is set, but its usage is not supported.
[    5.449641] NET: Registered PF_QIPCRTR protocol family
[    5.463266] loop0: detected capacity change from 0 to 8
[    5.468023] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    5.473940] Bluetooth: MGMT ver 1.23
[    5.477606] NET: Registered PF_ALG protocol family
[    5.542435] kauditd_printk_skb: 161 callbacks suppressed
[    5.542436] audit: type=1400 audit(1773298987.426:172): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=1027 comm="apparmor_parser"
[    5.549199] audit: type=1400 audit(1773298987.433:173): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=1027 comm="apparmor_parser"
[    7.695047] rfkill: input handler disabled
[    7.761302] nvme nvme0: using unchecked data buffer
[    7.805471] block nvme0n1: No UUID available providing old NGUID
[    8.416240] e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[   10.502796] Bluetooth: RFCOMM TTY layer initialized
[   10.502802] Bluetooth: RFCOMM socket layer initialized
[   10.502803] Bluetooth: RFCOMM ver 1.11
[  134.307626] rfkill: input handler enabled
[  135.450250] rfkill: input handler disabled
[  136.264956] warning: `gnome-shell' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[  179.218405] loop0: detected capacity change from 0 to 204800
[  181.836940] Key type trusted registered
[  181.839598] Key type encrypted registered
[  181.856723] EXT4-fs (dm-0): mounted filesystem 60afbd7d-8b2c-4c3d-9a45-e76e966937a1 r/w with ordered data mode. Quota mode: none.
[  181.856729] ext4 filesystem being mounted at /run/media/private/symtab/Private supports timestamps until 2038-01-19 (0x7fffffff)
[ 4053.372607] input: Philips TAH4205 (AVRCP) as /devices/virtual/input/input26
[19198.423205] perf: interrupt took too long (2537 > 2500), lowering kernel.perf_event_max_sample_rate to 78000
[37669.179489] usb 1-4: USB disconnect, device number 2
[37669.423309] usb 1-4: new high-speed USB device number 9 using xhci_hcd
[37669.546510] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[37669.546525] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[37669.546532] usb 1-4: Product: USB 2.0 Hub
[37669.550344] hub 1-4:1.0: USB hub found
[37669.550399] hub 1-4:1.0: 4 ports detected
[39635.104551] usb 1-4: USB disconnect, device number 9
[39635.348509] usb 1-4: new high-speed USB device number 10 using xhci_hcd
[39635.662600] usb 1-4: device descriptor read/64, error -71
[39635.887820] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[39635.887836] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[39635.887842] usb 1-4: Product: USB 2.0 Hub
[39635.890270] hub 1-4:1.0: USB hub found
[39635.890331] hub 1-4:1.0: 4 ports detected
[39638.647543] usb 1-4: USB disconnect, device number 10
[39638.892527] usb 1-4: new high-speed USB device number 11 using xhci_hcd
[39639.015850] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[39639.015867] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[39639.015873] usb 1-4: Product: USB 2.0 Hub
[39639.018104] hub 1-4:1.0: USB hub found
[39639.018161] hub 1-4:1.0: 4 ports detected
[39648.334674] usb 1-4: USB disconnect, device number 11
[39648.578738] usb 1-4: new high-speed USB device number 12 using xhci_hcd
[39648.702042] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[39648.702057] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[39648.702064] usb 1-4: Product: USB 2.0 Hub
[39648.704383] hub 1-4:1.0: USB hub found
[39648.704440] hub 1-4:1.0: 4 ports detected
[39786.269286] usb 1-4: USB disconnect, device number 12
[39786.515120] usb 1-4: new high-speed USB device number 13 using xhci_hcd
[39786.638383] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[39786.638398] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[39786.638405] usb 1-4: Product: USB 2.0 Hub
[39786.640853] hub 1-4:1.0: USB hub found
[39786.640909] hub 1-4:1.0: 4 ports detected
[39840.373946] usb 1-4: USB disconnect, device number 13
[39840.617864] usb 1-4: new high-speed USB device number 14 using xhci_hcd
[39840.740889] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
[39840.740904] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[39840.740910] usb 1-4: Product: USB 2.0 Hub
[39840.743291] hub 1-4:1.0: USB hub found
[39840.743343] hub 1-4:1.0: 4 ports detected
[rog-desktop ~]#
At least that narrows it down.
