No I have not installed any proprietary drivers.
It is running with open source drivers.
And should I install the Manjaro minimal xfce edition? And now the psu doesn’t give any kind of sound like that, no problem with that.
yes run it in the terminal and copy it here…
very likely because of video drivers, and that you are running a 5.15 kernel on such an old system … so provide the output from the command
A faulty PSU does not necessarily make a sound. I had a faulty PSU causing random reboots, checking the rails with a meter I found the 12 V rail to fluctuate wildly but the 5 V rail was solid.
I even think there is a hardware issue. Because now I am observing that my computer is even getting freeze before it actually boots the operating system.
Another thought - if your system is getting on a bit, the thermal compound on the CPU could have dried out. You may need to remove the heat sink, clean off the old paste, apply new and re-seat the heat sink.
It’s just another possibility. I replaced the thermal paste on my old machine last year thinking that was the cause of the reboots - it wasn’t and that’s when I tested the PSU.
I would start by testing the PSU as it’s free (assuming you have a meter)
The voltages should be stable and pretty much either 12 V or 5 V depending on the rail you are probing. My 12 V rail fluctuated a lot while the 5 V side was perfectly stable.
