Hey, my clock is exactly 2 minutes and 5.2 seconds ahead. I tried rebooting but it made no change.
im not sure what type of info is usefull here but here is some general info.
KDE Plasma Version: 5.20.3
KDE Frameworks Version: 5.76.0
Qt Version: 5.15.2
Kernel Version: 5.9.11-3-MANJARO
OS Type: 64-bit
Processors: 4 × Intel® Core™ i7-5650U CPU @ 2.20GHz
Memory: 7.7 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 6000
Im on macbook air early 2015. i will be happy to give more info if requested. thank you
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/usr/lib/systemd/system/systemd-timesyncd.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:systemd-timesyncd.service(8)
update: my clock is now 2 minutes and 6.1 seconds ahead. im not sure why its going more ahead now
jaden
3 December 2020 21:37
5
Couldn’t you change the settings from system time to automatic?
im pretty sure i have that
Run the following:
sudo systemctl enable --now systemd-timesyncd
then
sudo timedatectl set-ntp true
Then, provide outputs of:
timedatectl status
timedatectl timesync-status
ddns
3 December 2020 22:57
8
Try in clock plasmoid ->right click -> ajust date and time -> set time automatically
~ >>> timedatectl status
Local time: Thu 2020-12-03 15:05:02 PST
Universal time: Thu 2020-12-03 23:05:02 UTC
RTC time: Thu 2020-12-03 23:05:02
Time zone: America/Los_Angeles (PST, -0800)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
~ >>> timedatectl timesync-status
Server: 3.121.254.221 (0.manjaro.pool.ntp.org)
Poll interval: 32s (min: 32s; max 34min 8s)
Leap: normal
Version: 4
Stratum: 2
Reference: C035676C
Precision: 1us (-21)
Root distance: 32.378ms (max: 5s)
Offset: -2min 5.860948s
Delay: 190.581ms
Jitter: 0
Packet count: 1
Frequency: +0.000ppm
thanks for the help so far my time is now exact. any more i need to do or where you the solution?
You should be good to go, now.
system
Closed
19 December 2020 00:03
11
