My Cintiq 13hd stopped displaying when I intsalled proper graphics drivers
Recently I installed my graphics driver on Linux for games and whatnot, a Nvidia 430xx series to be specific, and prior to the install my tablet displayed and mirrored the screen on my computer with the pressure sensitivity working and everything. now it just lights up in black and works but doesn't show my monitor. It's not the end of the world but I would like to see my Cintiq used as a monitor.
Feel free to ask for more information.
Here is some more information on computer:
System: Kernel: 5.2.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.2-x86_64 root=UUID=1fbd5885-6610-4c73-813d-9f37b5f15d42 rw
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: Xfce 4.14.1 tk: Gtk 3.24.12 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Gigabyte model: Z68X-UD3H-B3 serial: BIOS: Award v: F10 date: 10/12/2011
CPU: Topology: Quad Core model: Intel Core i7-2700K bits: 64 type: MT MCP arch: Sandy Bridge family: 6
model-id: 2A (42) stepping: 7 microcode: 2F L2 cache: 8192 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 55889
Speed: 1815 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 1622 2: 1673 3: 1623 4: 1660 5: 1610
6: 1660 7: 1625 8: 1616
Vulnerabilities: Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Gigabyte driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0122
Device-2: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia v: 430.40 bus ID: 01:00.0
chip ID: 10de:1401
Display: x11 server: X.Org 1.20.5 driver: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 430.40 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0fba
Device-3: Focusrite-Novation type: USB driver: snd-usb-audio bus ID: 1-1.5.2:10 chip ID: 1235:8205
Sound Server: ALSA v: k5.2.21-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: ee00 bus ID: 07:00.0 chip ID: 10ec:8168
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac:
Drives: Local Storage: total: 931.51 GiB used: 369.41 GiB (39.7%)
ID-1: /dev/sda vendor: Seagate model: ST1000DM003-1ER162 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: rev: CC46 scheme: MBR
Partition: ID-1: / raw size: 931.51 GiB size: 915.89 GiB (98.32%) used: 369.41 GiB (40.3%) fs: ext4
dev: /dev/sda1
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 54 C
Info: Processes: 232 Uptime: 9h 32m Memory: 7.71 GiB used: 4.13 GiB (53.6%) Init: systemd v: 242 Compilers:
gcc: 9.2.0 Shell: bash v: 5.0.11 running in: xfce4-terminal inxi: 3.0.36
Hello,
Does the Cintiq wok in a live environment or a different OS ? What have yo tested ?
Unless is a physical issue as i had with my Cintiq22HD. 5 capacitors got blown up on it and had to be replaced...
If your Cintiq works and only in XFCE you have this issue, then we are good to go and try a few things.
Same as mine, but now i have to point out something:
It shows only one connected display. Is the Cintiq the only display connected? Because if you have two, then the inxi should show them both, like this:
Display: x11 server: X.Org 1.20.5 driver: nvidia compositor: kwin_x11
           resolution: 1920x1080~60Hz, 1920x1080~60Hz
unless, as i pointed out, the cintiq is physically damaged.
yeah the Cintiq is not shown as connected in the display options but it still works. I have not tested it on any other PCS or OS but the only thing I did to the cintiq was install the one driver so I doubt it is damaged.
Do you think reinstalling anything would fix these issues?
The Stylus input works trough USB and can be functional while the display part of it is broken. Is that what you define as "it works" or is that you also see the desktop?
I'll ask again :slight_smile:
Boot from Live Media install and test. If it turns on the display part of it, then you are safe.
Alright, the problem was the HDMI input was in the wrong place. It worked prior to the install but I think that's because it wanted me to have it directly into the Nvidia.
Switching them around did fix it thank you.
