pavucontrol
change your audio device there
pavucontrol
command not found show.
sudo pacman -S pavucontrol
sudo pacman -S pulseaudio-bluetooth
pavucontrol
Then just change the audio device(to the bluetooth headphones) for an application I changed to to SRS-XB12 in my case.
aafsmarak
(My bluetooth not show any near devices - #16 by aafsmarak)
What bluetooth device are you connected to?
how to find correct working file?
Im connected to a speaker
You can now use blueman bluetooth manager to connect to devices.
There is a device id in the output of lsusb
BCM43142A0. You have to find the corresponding file in broadcom-bt-firmware/brcm
Ok. Thanks for my help aafsmarak.
