Must frequently re-add Bluetooth mouse to be detected, after update
I updated to Manjaro 25.0.0 earlier this week and since then, I’m having problems with my bluetooth mouse. Actually, two mouses (mice/meese?).
The mouse won’t connect. If I use my laptop’s touchpad to open bluetooth and click connect, it will attempt and then eventually flips back to ‘not connected’. Does this for both of my Logitech bluetooth mice. The only way I can get it to work is to click FORGET and then re-add the mouse.
Here’s the other odd part, it’ll work for a while. So if I lock my laptop and come back a couple of hours later, it’ll reconnect fine on its own. Overnight, never. Better part of the afternoon? Nope.
I have a bluetooth headset and that reconnects fine, so I’m not suspecting it’s an issue with the bluetooth stack itself. The bluetooth service shows no errors.
Prior to updating, it was working fine. I also upgraded to version 6.13.8 of the kernal, from 6.12.20-2, with no change.
Another oddity I just discovered this morning, which I haven’t spent time trying to troubleshoot, is that I can no longer print. My printer shows it’s ready, jobs are sitting there, it’s just that it’s not actually starting the print job. Again, odd and no idea why that would be. Again, prior to 25.0.0, it worked fine.
Any thoughts? Not sure where to start digging to try to understand why this is happening since my other bluetooth headset has no issues.
