Hello, hello. In the Manjaro Repo stable branch the Palette (Shortcut F9) is broken. No topics are visible, choosing to add a Palette is showing nothing and right click delivers round about nothing, except at most top area saying “single palette”
I don’t know if the AUR version is working, as i had a building error trying to build it, but the flatpak version is working.
Maybe a bug just in the Manjaro Version. Bcs in the flatpack and Windows version it’s working, so i don’t think it’s a MuseScore Bug. and Shift+F9 is really not ideal…
As semperlin mentioned this problem started with the latest update. Here’s the terminal output of running mscore in case it helps to diagnose the problem:
> $ mscore
> Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
> qrc:/qml/palettes/PaletteTree.qml:764:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> qrc:/qml/palettes/Palette.qml:766:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> qrc:/qml/palettes/PalettesWidgetHeader.qml:139:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> qrc:/qml/palettes/PalettesWidgetHeader.qml:131:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
> qrc:/qml/palettes/PaletteTree.qml:178: Error: Cannot assign to non-existent property "color"
> qrc:/qml/palettes/PaletteTree.qml:618:21: Unable to assign [undefined] to bool
> qrc:/qml/palettes/PaletteTree.qml:609:21: Unable to assign [undefined] to bool
> qrc:/qml/palettes/PaletteTree.qml:603:21: Unable to assign [undefined] to QString
> qrc:/qml/palettes/PaletteTree.qml:700:21: Unable to assign [undefined] to bool
> qrc:/qml/palettes/PaletteTree.qml:699:21: Unable to assign [undefined] to bool
> qrc:/qml/palettes/PaletteTree.qml:698:21: Unable to assign [undefined] to QString
> qrc:/qml/palettes/PaletteTree.qml:420:13: Unable to assign [undefined] to bool
> qrc:/qml/palettes/PaletteTree.qml:419:13: Unable to assign [undefined] to QSizeF
> qrc:/qml/palettes/PaletteTree.qml:375:13: Unable to assign [undefined] to bool
