Hi,
I recently switched to Manjaro and noticed that the hardware play/pause, rewind/skip keys don’t work in some specific apps like Spotify(flatpak) and browser too. It works fine in VLC though. It also used to work in Spotify on Kubuntu 20.04. Is there a way to mark and enable applications to accept media keys input or something like that so I can use them in Spotify again?
Would appreciate it a lot if anyone can help.
Here’s my inxi output if that’s helpful:
Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=9ed067f5-9fca-4ad0-80bc-f66bd1117794 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: Dell product: Vostro 14-3468 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 01CM9N v: A01 serial: <filter> UEFI: Dell v: 2.5.0
date: 04/19/2018
RAM: total: 3.71 GiB used: 3.38 GiB (91.0%)
Info: Dual Core model: Intel Core i3-7100U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
microcode: DE cache: L2: 3 MiB bogomips: 19200
Speed: 1100 MHz min/max: 600/2100 MHz Core speeds (MHz): 1: 1100 2: 1100
3: 1100 4: 1100
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0c45:6a05 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040
bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
vendor: Dell driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
bus-ID: 1-8:6 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 931.51 GiB used: 24.04 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: SDM2 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
dev-links: cdrom
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 24.03 GiB (2.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 9ed067f5-9fca-4ad0-80bc-f66bd1117794
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 3E5B-9919
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Xenta 2.4G Wireless Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 1d57:0008 class-ID: 0301
Device-2: 1-4:3 info: Validity Sensors VFS Fingerprint sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 138a:0010 class-ID: ff00 serial: <filter>
Device-3: 1-5:4 info: Microdia Integrated_Webcam_HD type: Video
Device-4: 1-6:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
Device-5: 1-8:6 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 45.0 C mobo: 44.0 C
Fan Speeds (RPM): cpu: 0
Processes: 195 Uptime: 13h 02m wakeups: 2 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: 1306 pacman: 1297 lib: 375
flatpak: 5 snap: 4 Shell: Bash v: 5.1.4 running-in: konsole inxi: 3.3.04 ```
