Multi monitors on two NVIDIAs
nvidia
#1
Hi.
I want to use three monitors on NVIDIA Quadro2000 and NVIDIA GeForce GTX750 Ti.
I installed hardwares, maybe they work but a monitor on GTX750 Ti not displayed.
$ lspci | grep VGA
0f:00.0 VGA compatible controller: NVIDIA Corporation GF106GL [Quadro 2000] (rev a1)
28:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 750 Ti] (rev a2)
X couldn’t start when wrote BusID "PCI:0f:00:0" on Device section in /etc/X11/mhwd/nvidia.conf.
It’s not effect that wrote /etc/X11/mhwd/nvidia.conf using Bare Mosaic with nvidia-settings, and sudo mhwd-gpu --setgl nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf.
I think they are enabled because ffmpeg encoding fps is higher than Quadro 2000 only.
Monitor on GTX750Ti is shown in nvidia-settings but disabled.
Options are “Disabled”, “New X screen” or “Enable Base Mosaic”.
How to display to three monitors on Quadro 2000 and GeForce GTX 750 Ti?
Thanks in advance.
#2
Additional infomations.
Standard setting’s /var/log/Xorg.0.log`
    [    13.852]
    X.Org X Server 1.17.4
    Release Date: 2015-10-28
    [    13.852] X Protocol Version 11, Revision 0
    [    13.852] Build Operating System: Linux 4.2.5-1-ARCH x86_64
    [    13.852] Current Operating System: Linux mint 4.6.2-1-MANJARO #1 SMP PREEMPT Wed Jun 8 11:00:08 UTC 2016 x86_64
    [    13.852] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6-x86_64 root=/dev/mapper/ManjaroVG-ManjaroRoot rw cryptdevice=/dev/disk/by-uuid/8621f425-b092-44b7-8fdc-79f05108c25a:cryptManjaro resume=UUID=57a79e64-4586-4345-905f-e5ef72c5b8de quiet splash nomodeset nokmsboot
    [    13.852] Build Date: 01 November 2015  10:36:50AM
    [    13.852]
    [    13.852] Current version of pixman: 0.34.0
    [    13.852]     Before reporting problems, check http://wiki.x.org
    [    13.852] Markers: (--) probed, (**) from config file, (==) default setting,
    [    13.852] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jul 17 05:50:05 2016
    [    13.856] (==) Using config directory: "/etc/X11/xorg.conf.d"
    [    13.856] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    [    13.860] (==) ServerLayout "Layout0"
    [    13.860] (**) |-->Screen "Screen0" (0)
    [    13.860] (**) |   |-->Monitor "Monitor0"
    [    13.862] (**) |   |-->Device "Device0"
    [    13.862] (**) |-->Input Device "Keyboard0"
    [    13.862] (**) |-->Input Device "Mouse0"
    [    13.862] (==) Automatically adding devices
    [    13.862] (==) Automatically enabling devices
    [    13.862] (==) Automatically adding GPU devices
    [    13.865] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
    [    13.865]     Entry deleted from font path.
    [    13.865]     (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
    [    13.865] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
    [    13.865]     (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
    [    13.865] (==) FontPath set to:
        /usr/share/fonts/misc/,
        /usr/share/fonts/TTF/,
        /usr/share/fonts/OTF/,
        /usr/share/fonts/Type1/
    [    13.865] (==) ModulePath set to "/usr/lib/xorg/modules"
    [    13.865] (**) Extension "Composite" is enabled
    [    13.865] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
    [    13.865] (WW) Disabling Keyboard0
    [    13.865] (WW) Disabling Mouse0
    [    13.865] (II) Loader magic: 0x817d60
    [    13.865] (II) Module ABI versions:
    [    13.865]     X.Org ANSI C Emulation: 0.4
    [    13.865]     X.Org Video Driver: 19.0
    [    13.865]     X.Org XInput driver : 21.1
    [    13.865]     X.Org Server Extension : 9.0
    [    13.866] (EE) systemd-logind: failed to get session: PID 720 does not belong to any known session
    [    13.868] (--) PCI:*(0:15:0:0) 10de:0dd8:103c:084a rev 161, Mem @ 0xe2000000/33554432, 0xc8000000/134217728, 0xc4000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
    [    13.868] (--) PCI: (0:40:0:0) 10de:1380:19da:1346 rev 162, Mem @ 0xe5000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
    [    13.868] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
    [    13.869] (II) LoadModule: "glx"
    [    13.876] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
    [    14.023] (II) Module glx: vendor="NVIDIA Corporation"
    [    14.023]     compiled for 4.0.2, module version = 1.0.0
    [    14.023]     Module class: X.Org Server Extension
    [    14.025] (II) NVIDIA GLX Module  364.19  Tue Apr 19 14:10:52 PDT 2016
    [    14.026] (II) LoadModule: "nvidia"
    [    14.027] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
    [    14.044] (II) Module nvidia: vendor="NVIDIA Corporation"
    [    14.044]     compiled for 4.0.2, module version = 1.0.0
    [    14.044]     Module class: X.Org Video Driver
    [    14.046] (II) NVIDIA dlloader X Driver  364.19  Tue Apr 19 13:48:55 PDT 2016
    [    14.046] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
    [    14.048] (++) using VT number 7
    [    14.255] (II) Loading sub module "fb"
    [    14.255] (II) LoadModule: "fb"
    [    14.257] (II) Loading /usr/lib/xorg/modules/libfb.so
    [    14.261] (II) Module fb: vendor="X.Org Foundation"
    [    14.261]     compiled for 1.17.4, module version = 1.0.0
    [    14.261]     ABI class: X.Org ANSI C Emulation, version 0.4
    [    14.261] (II) Loading sub module "wfb"
    [    14.261] (II) LoadModule: "wfb"
    [    14.261] (II) Loading /usr/lib/xorg/modules/libwfb.so
    [    14.265] (II) Module wfb: vendor="X.Org Foundation"
    [    14.265]     compiled for 1.17.4, module version = 1.0.0
    [    14.265]     ABI class: X.Org ANSI C Emulation, version 0.4
    [    14.265] (II) Loading sub module "ramdac"
    [    14.265] (II) LoadModule: "ramdac"
    [    14.265] (II) Module "ramdac" already built-in
    [    14.273] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
    [    14.273] (==) NVIDIA(0): RGB weight 888
    [    14.273] (==) NVIDIA(0): Default visual is TrueColor
    [    14.273] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
    [    14.276] (**) NVIDIA(0): Option "NoLogo" "1"
    [    14.276] (**) NVIDIA(0): Enabling 2D acceleration
    [    15.070] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:15:0:0
    [    15.070] (--) NVIDIA(0):     CRT-0
    [    15.070] (--) NVIDIA(0):     DFP-0 (boot)
    [    15.070] (--) NVIDIA(0):     DFP-1
    [    15.070] (--) NVIDIA(0):     DFP-2
    [    15.070] (--) NVIDIA(0):     DFP-3
    [    15.070] (--) NVIDIA(0):     DFP-4
    [    15.100] (--) NVIDIA(0): CRT-0: disconnected
    [    15.100] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
    [    15.159] (--) NVIDIA(0): Samsung S22B300 (DFP-0): connected
    [    15.159] (--) NVIDIA(0): Samsung S22B300 (DFP-0): Internal TMDS
    [    15.159] (--) NVIDIA(0): Samsung S22B300 (DFP-0): 330.0 MHz maximum pixel clock
    [    15.192] (--) NVIDIA(0): LG Electronics 22EN33 (DFP-1): connected
    [    15.192] (--) NVIDIA(0): LG Electronics 22EN33 (DFP-1): Internal TMDS
    [    15.192] (--) NVIDIA(0): LG Electronics 22EN33 (DFP-1): 165.0 MHz maximum pixel clock
    [    15.192] (--) NVIDIA(0): DFP-2: disconnected
    [    15.192] (--) NVIDIA(0): DFP-2: Internal TMDS
    [    15.192] (--) NVIDIA(0): DFP-2: 165.0 MHz maximum pixel clock
    [    15.192] (--) NVIDIA(0): DFP-3: disconnected
    [    15.192] (--) NVIDIA(0): DFP-3: Internal DisplayPort
    [    15.192] (--) NVIDIA(0): DFP-3: 480.0 MHz maximum pixel clock
    [    15.193] (--) NVIDIA(0):
    [    15.193] (--) NVIDIA(0): DFP-4: disconnected
    [    15.193] (--) NVIDIA(0): DFP-4: Internal DisplayPort
    [    15.193] (--) NVIDIA(0): DFP-4: 480.0 MHz maximum pixel clock
    [    15.193] (II) NVIDIA(0): NVIDIA GPU Quadro 2000 (GF106GL) at PCI:15:0:0 (GPU-0)
    [    15.193] (--) NVIDIA(0): Memory: 1048576 kBytes
    [    15.193] (--) NVIDIA(0): VideoBIOS: 70.06.31.02.02
    [    15.193] (II) NVIDIA(0): Detected PCI Express Link width: 16X
    [    15.193] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
    [    15.193] (**) NVIDIA(0):     device Samsung S22B300 (DFP-0) (Using EDID frequencies has
    [    15.193] (**) NVIDIA(0):     been enabled on all display devices.)
    [    15.195] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
    [    15.195] (**) NVIDIA(0):     device LG Electronics 22EN33 (DFP-1) (Using EDID
    [    15.195] (**) NVIDIA(0):     frequencies has been enabled on all display devices.)
    [    15.197] (==) NVIDIA(0):
    [    15.197] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
    [    15.197] (==) NVIDIA(0):     will be used as the requested mode.
    [    15.199] (II) NVIDIA(0): Validated MetaModes:
    [    15.199] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
    [    15.199] (II) NVIDIA(0): Virtual screen size determined to be 3840 x 1080
    [    15.209] (--) NVIDIA(0): DPI set to (101, 101); computed from "UseEdidDpi" X config
    [    15.209] (--) NVIDIA(0):     option
    [    15.209] (--) Depth 24 pixmap format is 32 bpp
    [    16.395] (--) NVIDIA(0): Valid display device(s) on GPU-1 at PCI:40:0:0
    [    16.395] (--) NVIDIA(0):     CRT-0
    [    16.395] (--) NVIDIA(0):     DFP-0
    [    16.395] (--) NVIDIA(0):     DFP-1 (boot)
    [    16.395] (--) NVIDIA(0):     DFP-2
    [    16.396] (--) NVIDIA(0):     DFP-3
    [    16.398] (--) NVIDIA(0): CRT-0: disconnected
    [    16.398] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
    [    16.401] (--) NVIDIA(0): DFP-0: disconnected
    [    16.401] (--) NVIDIA(0): DFP-0: Internal TMDS
    [    16.401] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
    [    16.413] (--) NVIDIA(0): LG Electronics 22EN43 (DFP-1): connected
    [    16.413] (--) NVIDIA(0): LG Electronics 22EN43 (DFP-1): Internal TMDS
    [    16.413] (--) NVIDIA(0): LG Electronics 22EN43 (DFP-1): 340.0 MHz maximum pixel clock
    [    16.413] (--) NVIDIA(0): DFP-2: disconnected
    [    16.413] (--) NVIDIA(0): DFP-2: Internal TMDS
    [    16.413] (--) NVIDIA(0): DFP-2: 165.0 MHz maximum pixel clock
    [    16.414] (--) NVIDIA(0):
    [    16.414] (--) NVIDIA(0): DFP-3: disconnected
    [    16.414] (--) NVIDIA(0): DFP-3: Internal DisplayPort
    [    16.414] (--) NVIDIA(0): DFP-3: 960.0 MHz maximum pixel clock
    [    16.511] (II) NVIDIA(GPU-1): NVIDIA GPU GeForce GTX 750 Ti (GM107-A) at PCI:40:0:0 (GPU-1)
    [    16.511] (--) NVIDIA(GPU-1): Memory: 2097152 kBytes
    [    16.511] (--) NVIDIA(GPU-1): VideoBIOS: 82.07.32.00.8e
    [    16.511] (II) NVIDIA(GPU-1): Detected PCI Express Link width: 16X
    [    16.515] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
    [    16.515] (II) NVIDIA:     access.
    [    16.519] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
    [    16.519] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
    [    16.520] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
    [    16.520] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
    [    16.520] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
    [    16.520] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
    [    16.520] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
    [    16.520] (II) NVIDIA(0):     Config Options in the README.
    [    16.541] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select,DFP-1:nvidia-auto-select"
    [    16.663] (==) NVIDIA(0): Disabling shared memory pixmaps
    [    16.663] (==) NVIDIA(0): Backing store enabled
    [    16.663] (==) NVIDIA(0): Silken mouse enabled
    [    16.685] (**) NVIDIA(0): DPMS enabled
    [    16.685] (II) Loading sub module "dri2"
    [    16.685] (II) LoadModule: "dri2"
    [    16.685] (II) Module "dri2" already built-in
    [    16.685] (II) NVIDIA(0): [DRI2] Setup complete
    [    16.685] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
    [    16.685] (--) RandR disabled
    [    16.691] (II) Initializing extension GLX
    [    16.691] (II) Indirect GLX disabled.
    [    16.826] (II) config/udev: Adding input device Power Button (/dev/input/event3)
    [    16.826] (**) Power Button: Applying InputClass "evdev keyboard catchall"
    [    16.826] (**) Power Button: Applying InputClass "system-keyboard"
    [    16.826] (**) Power Button: Applying InputClass "Keyboard Defaults"
    [    16.826] (II) LoadModule: "evdev"
    [    16.826] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
    [    16.834] (II) Module evdev: vendor="X.Org Foundation"
    [    16.834]     compiled for 1.17.4, module version = 2.10.3
    [    16.834]     Module class: X.Org XInput Driver
    [    16.834]     ABI class: X.Org XInput driver, version 21.1
    [    16.834] (II) Using input driver 'evdev' for 'Power Button'
    [    16.834] (**) Power Button: always reports core events
    [    16.834] (**) evdev: Power Button: Device: "/dev/input/event3"
    [    16.834] (--) evdev: Power Button: Vendor 0 Product 0x1
    [    16.834] (--) evdev: Power Button: Found keys
    [    16.834] (II) evdev: Power Button: Configuring as keyboard
    [    16.834] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input5/event3"
    [    16.834] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
    [    16.834] (**) Option "xkb_rules" "evdev"
    [    16.834] (**) Option "xkb_model" "pc105"
    [    16.834] (**) Option "xkb_layout" "jp,us"
    [    16.834] (**) Option "xkb_variant" ","
    [    16.834] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
    [    16.855] (II) config/udev: Adding input device Power Button (/dev/input/event2)
    [    16.855] (**) Power Button: Applying InputClass "evdev keyboard catchall"
    [    16.855] (**) Power Button: Applying InputClass "system-keyboard"
    [    16.855] (**) Power Button: Applying InputClass "Keyboard Defaults"
    [    16.855] (II) Using input driver 'evdev' for 'Power Button'
    [    16.855] (**) Power Button: always reports core events
    [    16.855] (**) evdev: Power Button: Device: "/dev/input/event2"
    [    16.855] (--) evdev: Power Button: Vendor 0 Product 0x1
    [    16.855] (--) evdev: Power Button: Found keys
    [    16.855] (II) evdev: Power Button: Configuring as keyboard
    [    16.855] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input4/event2"
    [    16.855] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
    [    16.855] (**) Option "xkb_rules" "evdev"
    [    16.855] (**) Option "xkb_model" "pc105"
    [    16.855] (**) Option "xkb_layout" "jp,us"
    [    16.855] (**) Option "xkb_variant" ","
    [    16.855] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
    [    16.856] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event15)
    [    16.856] (II) No input driver specified, ignoring this device.
    [    16.856] (II) This device may have been added with another device file.
    [    16.856] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event16)
    [    16.856] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event17)
    [    16.856] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event18)
    [    16.857] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event11)
    [    16.857] (II) No input driver specified, ignoring this device.
    [    16.857] (II) This device may have been added with another device file.
    [    16.857] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event12)
    [    16.857] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event13)
    [    16.857] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event14)
    [    16.857] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event7)
    [    16.857] (II) config/udev: Adding input device HDA Intel Line Out (/dev/input/event8)
    [    16.858] (II) No input driver specified, ignoring this device.
    [    16.858] (II) This device may have been added with another device file.
    [    16.858] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event9)
    [    16.858] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event4)
    [    16.858] (II) config/udev: Adding input device HDA Intel Front Mic (/dev/input/event5)
    [    16.858] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event6)
    [    16.859] (II) config/udev: Adding input device Unicomp Inc Ruffian6_x Kbrd v3_xx (/dev/input/event1)
    [    16.859] (**) Unicomp Inc Ruffian6_x Kbrd v3_xx: Applying InputClass "evdev keyboard catchall"
    [    16.859] (**) Unicomp Inc Ruffian6_x Kbrd v3_xx: Applying InputClass "system-keyboard"
    [    16.859] (**) Unicomp Inc Ruffian6_x Kbrd v3_xx: Applying InputClass "Keyboard Defaults"
    [    16.859] (II) Using input driver 'evdev' for 'Unicomp Inc Ruffian6_x Kbrd v3_xx'
    [    16.859] (**) Unicomp Inc Ruffian6_x Kbrd v3_xx: always reports core events
    [    16.859] (**) evdev: Unicomp Inc Ruffian6_x Kbrd v3_xx: Device: "/dev/input/event1"
    [    16.859] (--) evdev: Unicomp Inc Ruffian6_x Kbrd v3_xx: Vendor 0x17f6 Product 0x839
    [    16.859] (--) evdev: Unicomp Inc Ruffian6_x Kbrd v3_xx: Found keys
    [    16.859] (II) evdev: Unicomp Inc Ruffian6_x Kbrd v3_xx: Configuring as keyboard
    [    16.859] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb10/10-1/10-1:1.0/0003:17F6:0839.0003/input/input3/event1"
    [    16.859] (II) XINPUT: Adding extended input device "Unicomp Inc Ruffian6_x Kbrd v3_xx" (type: KEYBOARD, id 8)
    [    16.859] (**) Option "xkb_rules" "evdev"
    [    16.859] (**) Option "xkb_model" "pc105"
    [    16.859] (**) Option "xkb_layout" "jp,us"
    [    16.859] (**) Option "xkb_variant" ","
    [    16.859] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
    [    16.859] (II) config/udev: Adding input device ELECOM ELECOM UltimateLaser Mouse (/dev/input/event0)
    [    16.859] (**) ELECOM ELECOM UltimateLaser Mouse: Applying InputClass "evdev pointer catchall"
    [    16.859] (II) Using input driver 'evdev' for 'ELECOM ELECOM UltimateLaser Mouse'
    [    16.859] (**) ELECOM ELECOM UltimateLaser Mouse: always reports core events
    [    16.859] (**) evdev: ELECOM ELECOM UltimateLaser Mouse: Device: "/dev/input/event0"
    [    16.910] (--) evdev: ELECOM ELECOM UltimateLaser Mouse: Vendor 0x56e Product 0xd3
    [    16.910] (--) evdev: ELECOM ELECOM UltimateLaser Mouse: Found 12 mouse buttons
    [    16.910] (--) evdev: ELECOM ELECOM UltimateLaser Mouse: Found scroll wheel(s)
    [    16.910] (--) evdev: ELECOM ELECOM UltimateLaser Mouse: Found relative axes
    [    16.910] (--) evdev: ELECOM ELECOM UltimateLaser Mouse: Found x and y relative axes
    [    16.910] (II) evdev: ELECOM ELECOM UltimateLaser Mouse: Configuring as mouse
    [    16.910] (II) evdev: ELECOM ELECOM UltimateLaser Mouse: Adding scrollwheel support
    [    16.910] (**) evdev: ELECOM ELECOM UltimateLaser Mouse: YAxisMapping: buttons 4 and 5
    [    16.910] (**) evdev: ELECOM ELECOM UltimateLaser Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
    [    16.910] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb10/10-2/10-2:1.0/0003:056E:00D3.0001/input/input2/event0"
    [    16.910] (II) XINPUT: Adding extended input device "ELECOM ELECOM UltimateLaser Mouse" (type: MOUSE, id 9)
    [    16.910] (II) evdev: ELECOM ELECOM UltimateLaser Mouse: initialized for relative axes.
    [    16.910] (**) ELECOM ELECOM UltimateLaser Mouse: (accel) keeping acceleration scheme 1
    [    16.910] (**) ELECOM ELECOM UltimateLaser Mouse: (accel) acceleration profile 0
    [    16.910] (**) ELECOM ELECOM UltimateLaser Mouse: (accel) acceleration factor: 2.000
    [    16.910] (**) ELECOM ELECOM UltimateLaser Mouse: (accel) acceleration threshold: 4
    [    16.911] (II) config/udev: Adding input device ELECOM ELECOM UltimateLaser Mouse (/dev/input/mouse0)
    [    16.911] (II) No input driver specified, ignoring this device.
    [    16.911] (II) This device may have been added with another device file.
    [    16.911] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event10)
    [    16.911] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
    [    16.911] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
    [    16.911] (**) HP WMI hotkeys: Applying InputClass "Keyboard Defaults"
    [    16.911] (II) Using input driver 'evdev' for 'HP WMI hotkeys'
    [    16.911] (**) HP WMI hotkeys: always reports core events
    [    16.911] (**) evdev: HP WMI hotkeys: Device: "/dev/input/event10"
    [    16.911] (--) evdev: HP WMI hotkeys: Vendor 0 Product 0
    [    16.911] (--) evdev: HP WMI hotkeys: Found keys
    [    16.911] (II) evdev: HP WMI hotkeys: Configuring as keyboard
    [    16.911] (**) Option "config_info" "udev:/sys/devices/virtual/input/input13/event10"
    [    16.911] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 10)
    [    16.911] (**) Option "xkb_rules" "evdev"
    [    16.911] (**) Option "xkb_model" "pc105"
    [    16.911] (**) Option "xkb_layout" "jp,us"
    [    16.911] (**) Option "xkb_variant" ","
    [    16.911] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
nvidia-settings configuration.
    [    20.386]
    [    20.386] X Protocol Version 11, Revision 0
    [    20.386] Build Operating System: Linux 4.2.5-1-ARCH x86_64
    [    20.386] Current Operating System: Linux mint 4.6.2-1-MANJARO #1 SMP PREEMPT Wed Jun 8 11:00:08 UTC 2016 x86_64
    [    20.386] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6-x86_64 root=/dev/mapper/ManjaroVG-ManjaroRoot rw cryptdevice=/dev/disk/by-uuid/8621f425-b092-44b7-8fdc-79f05108c25a:cryptManjaro resume=UUID=57a79e64-4586-4345-905f-e5ef72c5b8de quiet splash nomodeset nokmsboot
    [    20.386] Build Date: 01 November 2015  10:36:50AM
    [    20.386]
    [    20.386] Current version of pixman: 0.34.0
    [    20.386]     Before reporting problems, check http://wiki.x.org
    [    20.386] Markers: (--) probed, (**) from config file, (==) default setting,
    [    20.386] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 16 12:02:14 2016
    [    20.390] (==) Using config directory: "/etc/X11/xorg.conf.d"
    [    20.390] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    [    20.393] (==) ServerLayout "Layout0"
    [    20.393] (**) |-->Screen "Screen0" (0)
    [    20.393] (**) |   |-->Monitor "Monitor0"
    [    20.396] (**) |   |-->Device "Device0"
    [    20.396] (**) |-->Input Device "Keyboard0"
    [    20.396] (**) |-->Input Device "Mouse0"
    [    20.396] (**) Option "Xinerama" "0"
    [    20.396] (==) Automatically adding devices
    [    20.396] (==) Automatically enabling devices
    [    20.396] (==) Automatically adding GPU devices
    [    20.401] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
    [    20.401]     Entry deleted from font path.
    [    20.401]     (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
    [    20.402] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
    [    20.402]     Entry deleted from font path.
    [    20.402]     (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
    [    20.402] (==) FontPath set to:
    [    20.402] (==) ModulePath set to "/usr/lib/xorg/modules"
    [    20.402] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
    [    20.402] (WW) Disabling Keyboard0
    [    20.402] (WW) Disabling Mouse0
    [    20.402] (II) Loader magic: 0x817d60
    [    20.402] (II) Module ABI versions:
    [    20.402]     X.Org ANSI C Emulation: 0.4
    [    20.402]     X.Org Video Driver: 19.0
    [    20.402]     X.Org XInput driver : 21.1
    [    20.402]     X.Org Server Extension : 9.0
    [    20.403] (EE) systemd-logind: failed to get session: PID 851 does not belong to any known session
    [    20.405] (--) PCI:*(0:15:0:0) 10de:0dd8:103c:084a rev 161, Mem @ 0xe2000000/33554432, 0xc8000000/134217728, 0xc4000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
    [    20.405] (--) PCI: (0:40:0:0) 10de:1380:19da:1346 rev 162, Mem @ 0xe5000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
    [    20.405] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
    [    20.406] (II) LoadModule: "glx"
    [    20.413] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
    [    20.557] (II) Module glx: vendor="NVIDIA Corporation"
    [    20.557]     compiled for 4.0.2, module version = 1.0.0
    [    20.557]     Module class: X.Org Server Extension
    [    20.559] (II) NVIDIA GLX Module  364.19  Tue Apr 19 14:10:52 PDT 2016
    [    20.570] (II) LoadModule: "nvidia"
    [    20.571] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
    [    20.588] (II) Module nvidia: vendor="NVIDIA Corporation"
    [    20.588]     compiled for 4.0.2, module version = 1.0.0
    [    20.588]     Module class: X.Org Video Driver
    [    20.590] (II) NVIDIA dlloader X Driver  364.19  Tue Apr 19 13:48:55 PDT 2016
    [    20.590] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
    [    20.591] (++) using VT number 7
    [    20.795] (II) Loading sub module "fb"
    [    20.795] (II) LoadModule: "fb"
    [    20.797] (II) Loading /usr/lib/xorg/modules/libfb.so
    [    20.800] (II) Module fb: vendor="X.Org Foundation"
    [    20.800]     compiled for 1.17.4, module version = 1.0.0
    [    20.800]     ABI class: X.Org ANSI C Emulation, version 0.4
    [    20.800] (II) Loading sub module "wfb"
    [    20.800] (II) LoadModule: "wfb"
    [    20.801] (II) Loading /usr/lib/xorg/modules/libwfb.so
    [    20.805] (II) Module wfb: vendor="X.Org Foundation"
    [    20.805]     compiled for 1.17.4, module version = 1.0.0
    [    20.805]     ABI class: X.Org ANSI C Emulation, version 0.4
    [    20.805] (II) Loading sub module "ramdac"
    [    20.805] (II) LoadModule: "ramdac"
    [    20.805] (II) Module "ramdac" already built-in
    [    20.812] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
    [    20.812] (==) NVIDIA(0): RGB weight 888
    [    20.812] (==) NVIDIA(0): Default visual is TrueColor
    [    20.812] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
    [    20.814] (**) NVIDIA(0): Option "Stereo" "0"
    [    20.814] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "DFP-0"
    [    20.814] (**) NVIDIA(0): Option "SLI" "off"
    [    20.814] (**) NVIDIA(0): Option "MultiGPU" "Off"
    [    20.814] (**) NVIDIA(0): Option "BaseMosaic" "on"
    [    20.814] (**) NVIDIA(0): Stereo disabled by request
    [    20.815] (**) NVIDIA(0): NVIDIA SLI disabled.
    [    20.815] (**) NVIDIA(0): NVIDIA Multi-GPU disabled.
    [    20.815] (**) NVIDIA(0): Option "MetaModes" "GPU-e85b6d81-cd8a-863c-9de4-f02b26aefc6e.DVI-I-1: nvidia-auto-select +0+0, GPU-e85b6d81-cd8a-863c-9de4-f02b26aefc6e.DP-0: nvidia-auto-select +1920+0, GPU-a26d8e50-e07f-4980-899e-201371772a1d.HDMI-0: nvidia-auto-select +3840+0"
    [    20.815] (**) NVIDIA(0): Enabling 2D acceleration
    [    22.573] (EE) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration.
    [    22.573] (EE) NVIDIA(GPU-0): Invalid Base Mosaic configuration 1 of 1:
    [    22.573] (EE) NVIDIA(GPU-0): GPUs:
    [    22.573] (EE) NVIDIA(GPU-0):     1) NVIDIA GPU at PCI:15:0:0
    [    22.573] (EE) NVIDIA(GPU-0):     2) NVIDIA GPU at PCI:40:0:0
    [    22.573] (EE) NVIDIA(GPU-0): Errors:
    [    22.573] (EE) NVIDIA(GPU-0):     - GPU PCI IDs do not match
    [    22.573] (WW) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration for the
    [    22.573] (WW) NVIDIA(GPU-0):     NVIDIA graphics device PCI:15:0:0. Please see Chapter 28:
    [    22.573] (WW) NVIDIA(GPU-0):     Configuring SLI and Multi-GPU FrameRendering in the README
    [    22.573] (WW) NVIDIA(GPU-0):     for troubleshooting suggestions.
0f:00:0
    [    56.257]
    [    56.257] X Protocol Version 11, Revision 0
    [    56.257] Build Operating System: Linux 4.2.5-1-ARCH x86_64
    [    56.257] Current Operating System: Linux mint 4.6.2-1-MANJARO #1 SMP PREEMPT Wed Jun 8 11:00:08 UTC 2016 x86_64
    [    56.257] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6-x86_64 root=/dev/mapper/ManjaroVG-ManjaroRoot rw cryptdevice=/dev/disk/by-uuid/8621f425-b092-44b7-8fdc-79f05108c25a:cryptManjaro resume=UUID=57a79e64-4586-4345-905f-e5ef72c5b8de quiet splash nomodeset nokmsboot
    [    56.257] Build Date: 01 November 2015  10:36:50AM
    [    56.257]
    [    56.257] Current version of pixman: 0.34.0
    [    56.257]     Before reporting problems, check http://wiki.x.org
    [    56.257] Markers: (--) probed, (**) from config file, (==) default setting,
    [    56.258] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 16 12:06:17 2016
    [    56.258] (==) Using config directory: "/etc/X11/xorg.conf.d"
    [    56.258] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    [    56.258] (==) ServerLayout "Layout0"
    [    56.258] (**) |-->Screen "Screen0" (0)
    [    56.258] (**) |   |-->Monitor "Monitor0"
    [    56.258] (**) |   |-->Device "Device0"
    [    56.258] (**) |-->Input Device "Keyboard0"
    [    56.258] (**) |-->Input Device "Mouse0"
    [    56.258] (**) Option "Xinerama" "0"
    [    56.258] (==) Automatically adding devices
    [    56.258] (==) Automatically enabling devices
    [    56.258] (==) Automatically adding GPU devices
    [    56.258] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
    [    56.258]     Entry deleted from font path.
    [    56.258]     (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
    [    56.258] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
    [    56.258]     (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
    [    56.258] (==) FontPath set to:
    [    56.258] (==) ModulePath set to "/usr/lib/xorg/modules"
    [    56.258] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
    [    56.258] (WW) Disabling Keyboard0
    [    56.258] (WW) Disabling Mouse0
    [    56.258] (II) Loader magic: 0x817d60
    [    56.258] (II) Module ABI versions:
    [    56.258]     X.Org ANSI C Emulation: 0.4
    [    56.258]     X.Org Video Driver: 19.0
    [    56.258]     X.Org XInput driver : 21.1
    [    56.258]     X.Org Server Extension : 9.0
    [    56.260] (EE) systemd-logind: failed to get session: PID 1001 does not belong to any known session
    [    56.262] (--) PCI:*(0:15:0:0) 10de:0dd8:103c:084a rev 161, Mem @ 0xe2000000/33554432, 0xc8000000/134217728, 0xc4000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
    [    56.262] (--) PCI: (0:40:0:0) 10de:1380:19da:1346 rev 162, Mem @ 0xe5000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
    [    56.262] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
    [    56.262] (II) LoadModule: "glx"
    [    56.263] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
    [    56.267] (II) Module glx: vendor="NVIDIA Corporation"
    [    56.267]     compiled for 4.0.2, module version = 1.0.0
    [    56.267]     Module class: X.Org Server Extension
    [    56.267] (II) NVIDIA GLX Module  364.19  Tue Apr 19 14:10:52 PDT 2016
    [    56.267] (II) LoadModule: "nvidia"
    [    56.267] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
    [    56.268] (II) Module nvidia: vendor="NVIDIA Corporation"
    [    56.268]     compiled for 4.0.2, module version = 1.0.0
    [    56.268]     Module class: X.Org Video Driver
    [    56.268] (II) NVIDIA dlloader X Driver  364.19  Tue Apr 19 13:48:55 PDT 2016
    [    56.268] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
    [    56.268] (++) using VT number 7
    [    56.268] (EE) No devices detected.
    [    56.268] (EE)
    Fatal server error:
    [    56.268] (EE) no screens found(EE)
    [    56.268] (EE)
    Please consult the The X.Org Foundation support
         at http://wiki.x.org
     for help.
    [    56.268] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
    [    56.268] (EE)
28:00:0
    [    20.932]
    [    20.933] X Protocol Version 11, Revision 0
    [    20.933] Build Operating System: Linux 4.2.5-1-ARCH x86_64
    [    20.933] Current Operating System: Linux mint 4.6.2-1-MANJARO #1 SMP PREEMPT Wed Jun 8 11:00:08 UTC 2016 x86_64
    [    20.933] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6-x86_64 root=/dev/mapper/ManjaroVG-ManjaroRoot rw cryptdevice=/dev/disk/by-uuid/8621f425-b092-44b7-8fdc-79f05108c25a:cryptManjaro resume=UUID=57a79e64-4586-4345-905f-e5ef72c5b8de quiet splash nomodeset nokmsboot
    [    20.933] Build Date: 01 November 2015  10:36:50AM
    [    20.933]
    [    20.933] Current version of pixman: 0.34.0
    [    20.933]     Before reporting problems, check http://wiki.x.org
    [    20.933] Markers: (--) probed, (**) from config file, (==) default setting,
    [    20.933] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 16 12:09:27 2016
    [    20.933] (==) Using config directory: "/etc/X11/xorg.conf.d"
    [    20.933] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
    [    20.933] (==) ServerLayout "Layout0"
    [    20.933] (**) |-->Screen "Screen0" (0)
    [    20.933] (**) |   |-->Monitor "Monitor0"
    [    20.934] (**) |   |-->Device "Device0"
    [    20.934] (**) |-->Input Device "Keyboard0"
    [    20.934] (**) |-->Input Device "Mouse0"
    [    20.934] (**) Option "Xinerama" "0"
    [    20.934] (==) Automatically adding devices
    [    20.934] (==) Automatically enabling devices
    [    20.934] (==) Automatically adding GPU devices
    [    20.934] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
    [    20.934]     Entry deleted from font path.
    [    20.934]     (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
    [    20.934] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
    [    20.934]     (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
    [    20.934] (==) FontPath set to:
    [    20.934] (==) ModulePath set to "/usr/lib/xorg/modules"
    [    20.934] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
    [    20.934] (WW) Disabling Keyboard0
    [    20.934] (WW) Disabling Mouse0
    [    20.934] (II) Loader magic: 0x817d60
    [    20.934] (II) Module ABI versions:
    [    20.934]     X.Org ANSI C Emulation: 0.4
    [    20.934]     X.Org Video Driver: 19.0
    [    20.934]     X.Org XInput driver : 21.1
    [    20.934]     X.Org Server Extension : 9.0
    [    20.935] (EE) systemd-logind: failed to get session: PID 995 does not belong to any known session
    [    20.937] (--) PCI:*(0:15:0:0) 10de:0dd8:103c:084a rev 161, Mem @ 0xe2000000/33554432, 0xc8000000/134217728, 0xc4000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
    [    20.937] (--) PCI: (0:40:0:0) 10de:1380:19da:1346 rev 162, Mem @ 0xe5000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
    [    20.937] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
    [    20.937] (II) LoadModule: "glx"
    [    20.937] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
    [    20.942] (II) Module glx: vendor="NVIDIA Corporation"
    [    20.942]     compiled for 4.0.2, module version = 1.0.0
    [    20.942]     Module class: X.Org Server Extension
    [    20.942] (II) NVIDIA GLX Module  364.19  Tue Apr 19 14:10:52 PDT 2016
    [    20.942] (II) LoadModule: "nvidia"
    [    20.942] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
    [    20.942] (II) Module nvidia: vendor="NVIDIA Corporation"
    [    20.942]     Module class: X.Org Video Driver
    [    20.942] (II) NVIDIA dlloader X Driver  364.19  Tue Apr 19 13:48:55 PDT 2016
    [    20.942] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
    [    20.942] (++) using VT number 7
    [    20.942] (EE) No devices detected.
    [    20.942] (EE)
    Fatal server error:
    [    20.942] (EE) no screens found(EE)
    [    20.942] (EE)
     for help.
    [    20.942] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
    [    20.942] (EE)
  • They aren’t connected with SLI cable.
  • They works well on Windows.
  • If swap cards, GeForce GTX750Ti can output three displays but cannot back from console after login.
#3
Maybe you can use base mosaic mode for it? https://wiki.archlinux.org/index.php/NVIDIA#Mosaic_mode
#4
Thank you for your reply.
I understood Base Mosaic is currently solution,
but nvidia-settins enabled Base Mosaic but it didn’t work thus error:
BusID is set “PCI:15:0:0”. This log differs from lspci.
$ lspci | grep VGA
BusID “0f:00:0” or “28:00:0” didn’t start X.
nvidia-settings creates this configuration.
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 364.19  (buildmeister@swio-display-x64-rhel04-11)  Tue Apr 19 15:21:13 PDT 2016
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Samsung S22B300"
    HorizSync       30.0 - 81.0
    VertRefresh     56.0 - 75.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "Quadro 2000"
    BusID          "PCI:15:0:0"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "GPU-e85b6d81-cd8a-863c-9de4-f02b26aefc6e.DVI-I-1: nvidia-auto-select +0+0, GPU-e85b6d81-cd8a-863c-9de4-f02b26aefc6e.DP-0: nvidia-auto-select +1920+0, GPU-a26d8e50-e07f-4980-899e-201371772a1d.HDMI-0: nvidia-auto-select +3840+0"
    Option         "SLI" "off"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
It not work if overwrote metamodes like “GPU-0.DFP-0”.
#5
Manjaro is not using the default /etc/X11/Xorg.conf, but /etc/X11/mhwd.d/nvidia.conf. So you need to let nvidia-xconfig know where to put in the file. So the command should be something like this:
Of course, change the GPUx, DFP-x, and resolution to match your configuration. Good luck :slight_smile:
#6
Thank you.
I tried
sudo nvidia-xconfig --xconfig=/etc/X11/mhwd.d/nvidia.conf --base-mosaic --metamodes="GPU-0.DFP-0: 1920x1080+0+0, GPU-0.DFP-1: 1920x1080+1920+0, GPU-1.DFP-1: 1920x1080+3840+0"
but I got same result GPU PCI IDs do not match.
[    17.413]
[    17.413] X Protocol Version 11, Revision 0
[    17.413] Build Operating System: Linux 4.2.5-1-ARCH x86_64
[    17.413] Current Operating System: Linux mint 4.6.2-1-MANJARO #1 SMP PREEMPT Wed Jun 8 11:00:08 UTC 2016 x86_64
[    17.413] Kernel command line: BOOT_IMAGE=/vmlinuz-4.6-x86_64 root=/dev/mapper/ManjaroVG-ManjaroRoot rw cryptdevice=/dev/disk/by-uuid/8621f425-b092-44b7-8fdc-79f05108c25a:cryptManjaro resume=UUID=57a79e64-4586-4345-905f-e5ef72c5b8de quiet splash nomodeset nokmsboot
[    17.413] Build Date: 01 November 2015  10:36:50AM
[    17.413]
[    17.413] Current version of pixman: 0.34.0
[    17.413]     Before reporting problems, check http://wiki.x.org
[    17.413] Markers: (--) probed, (**) from config file, (==) default setting,
[    17.413] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jul 17 16:07:27 2016
[    17.417] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    17.417] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    17.420] (==) ServerLayout "Layout0"
[    17.420] (**) |-->Screen "Screen0" (0)
[    17.420] (**) |   |-->Monitor "Monitor0"
[    17.422] (**) |   |-->Device "Device0"
[    17.422] (**) |-->Input Device "Keyboard0"
[    17.422] (**) |-->Input Device "Mouse0"
[    17.422] (==) Automatically adding devices
[    17.422] (==) Automatically enabling devices
[    17.422] (==) Automatically adding GPU devices
[    17.425] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[    17.425]     Entry deleted from font path.
[    17.425]     (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[    17.425] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[    17.425]     (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[    17.425] (==) FontPath set to:
[    17.425] (==) ModulePath set to "/usr/lib/xorg/modules"
[    17.425] (**) Extension "Composite" is enabled
[    17.425] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    17.425] (WW) Disabling Keyboard0
[    17.425] (WW) Disabling Mouse0
[    17.426] (II) Loader magic: 0x817d60
[    17.426] (II) Module ABI versions:
[    17.426]     X.Org ANSI C Emulation: 0.4
[    17.426]     X.Org Video Driver: 19.0
[    17.426]     X.Org XInput driver : 21.1
[    17.426]     X.Org Server Extension : 9.0
[    17.427] (EE) systemd-logind: failed to get session: PID 938 does not belong to any known session
[    17.429] (--) PCI:*(0:15:0:0) 10de:0dd8:103c:084a rev 161, Mem @ 0xe2000000/33554432, 0xc8000000/134217728, 0xc4000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
[    17.429] (--) PCI: (0:40:0:0) 10de:1380:19da:1346 rev 162, Mem @ 0xe5000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[    17.429] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    17.429] (II) LoadModule: "glx"
[    17.438] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    17.571] (II) Module glx: vendor="NVIDIA Corporation"
[    17.571]     compiled for 4.0.2, module version = 1.0.0
[    17.571]     Module class: X.Org Server Extension
[    17.573] (II) NVIDIA GLX Module  364.19  Tue Apr 19 14:10:52 PDT 2016
[    17.577] (II) LoadModule: "nvidia"
[    17.578] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    17.595] (II) Module nvidia: vendor="NVIDIA Corporation"
[    17.595]     compiled for 4.0.2, module version = 1.0.0
[    17.595]     Module class: X.Org Video Driver
[    17.597] (II) NVIDIA dlloader X Driver  364.19  Tue Apr 19 13:48:55 PDT 2016
[    17.597] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    17.598] (++) using VT number 7
[    17.800] (II) Loading sub module "fb"
[    17.800] (II) LoadModule: "fb"
[    17.802] (II) Loading /usr/lib/xorg/modules/libfb.so
[    17.806] (II) Module fb: vendor="X.Org Foundation"
[    17.806]     compiled for 1.17.4, module version = 1.0.0
[    17.806]     ABI class: X.Org ANSI C Emulation, version 0.4
[    17.806] (II) Loading sub module "wfb"
[    17.806] (II) LoadModule: "wfb"
[    17.806] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    17.811] (II) Module wfb: vendor="X.Org Foundation"
[    17.811]     compiled for 1.17.4, module version = 1.0.0
[    17.811]     ABI class: X.Org ANSI C Emulation, version 0.4
[    17.811] (II) Loading sub module "ramdac"
[    17.811] (II) LoadModule: "ramdac"
[    17.811] (II) Module "ramdac" already built-in
[    17.817] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    17.817] (==) NVIDIA(0): RGB weight 888
[    17.817] (==) NVIDIA(0): Default visual is TrueColor
[    17.817] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    17.819] (**) NVIDIA(0): Option "NoLogo" "1"
[    17.820] (**) NVIDIA(0): Option "BaseMosaic" "True"
[    17.820] (**) NVIDIA(0): Option "MetaModes" "GPU-0.DFP-0: 1920x1080+0+0, GPU-0.DFP-1: 1920x1080+1920+0, GPU-1.DFP-1: 1920x1080+3840+0"
[    17.820] (**) NVIDIA(0): Enabling 2D acceleration
[    19.599] (EE) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration.
[    19.599] (EE) NVIDIA(GPU-0): Invalid Base Mosaic configuration 1 of 1:
[    19.599] (EE) NVIDIA(GPU-0): GPUs:
[    19.599] (EE) NVIDIA(GPU-0):     1) NVIDIA GPU at PCI:15:0:0
[    19.599] (EE) NVIDIA(GPU-0):     2) NVIDIA GPU at PCI:40:0:0
[    19.599] (EE) NVIDIA(GPU-0): Errors:
[    19.599] (EE) NVIDIA(GPU-0):     - GPU PCI IDs do not match
[    19.599] (WW) NVIDIA(GPU-0): Failed to find a valid Base Mosaic configuration for the
[    19.599] (WW) NVIDIA(GPU-0):     NVIDIA graphics device PCI:15:0:0. Please see Chapter 28:
[    19.599] (WW) NVIDIA(GPU-0):     Configuring SLI and Multi-GPU FrameRendering in the README
[    19.599] (WW) NVIDIA(GPU-0):     for troubleshooting suggestions.
#7
Like I mentioned above, modify GPU-x, DFP-x to match your system configuration. You can look at my screenshot here to understand what you need to do :slight_smile:
#8
Yes, I understood it.
every monitors FHD(1920x1080) and they are put horizontal, so I think
is right setting (match with screenshot.)
I think EE on log says error is in device section rather than screen.
Maybe this problem likely
https://bbs.archlinux.org/viewtopic.php?id=199169
https://forums.geforce.com/default/topic/803936/using-two-different-graphics-cards-k2200-and-k620-under-linux
#9
Maybe, did you try making it into 2 screens? So X Screen 0 for your 750ti and X Screen 1 for your Q2000?
#10
No, I didn’t.
If don’t use Base Mosaic, Quadro2000 uses Screen 0, and GTX750Ti able to use new screen or disable.
but if enable Base Mosaic, GTX750Ti able to select disabled or join Screen 0.
If configurate GTX750Ti use Screen 1, X didn’t start.
#11
You already have 3 monitors shown there. Are you using 4 monitors? Because as far as I know, Nvidia base mosaic only supports maximum 3 monitors. Read the Note here: https://wiki.archlinux.org/index.php/NVIDIA#Base_Mosaic
#12
No.
Third monitor on GPU.1(GTX750Ti) not displayed because Base Mosaic wasn’t enabled with error.
Extract it:
nvidia-settings shows third monitor (22EN43) as disabled.
#13
But your screenshot before showing all 3 monitors on? I just Googled and found out that your PCI ID should match in order to use base mosaic (that means you need two identical cards/SLI). So you might want to try separate Screens or twinview instead of base mosaic.
#14
It’s modified on nvidia-settings window…
Third monitor was disabled on start nvidia-settings.
I tried to delete line about BusID and Base Mosaic, and turn on MultiGPU.
It errored GPU PCI IDs do not match same as Base Mosaic, so cannot enable two NVIDIA cards by any other technology (e.g. multi screen.)
[    22.295] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    22.295] (==) NVIDIA(0): RGB weight 888
[    22.295] (==) NVIDIA(0): Default visual is TrueColor
[    22.295] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    22.297] (**) NVIDIA(0): Option "NoLogo" "1"
[    22.297] (**) NVIDIA(0): Option "MultiGPU" "on"
[    22.297] (**) NVIDIA(0): NVIDIA Multi-GPU auto-select rendering option.
[    22.298] (**) NVIDIA(0): Enabling 2D acceleration
[    24.048] (EE) NVIDIA(GPU-0): Failed to find a valid Multi-GPU configuration.
[    24.048] (EE) NVIDIA(GPU-0): Invalid Multi-GPU configuration 1 of 1:
[    24.048] (EE) NVIDIA(GPU-0): GPUs:
[    24.048] (EE) NVIDIA(GPU-0):     1) NVIDIA GPU at PCI:15:0:0
[    24.048] (EE) NVIDIA(GPU-0):     2) NVIDIA GPU at PCI:40:0:0
[    24.048] (EE) NVIDIA(GPU-0): Errors:
[    24.048] (EE) NVIDIA(GPU-0):     - GPU PCI IDs do not match
[    24.048] (WW) NVIDIA(GPU-0): Failed to find a valid Multi-GPU configuration for the NVIDIA
[    24.048] (WW) NVIDIA(GPU-0):     graphics device PCI:15:0:0. Please see Chapter 28:
[    24.048] (WW) NVIDIA(GPU-0):     Configuring SLI and Multi-GPU FrameRendering in the README
[    24.048] (WW) NVIDIA(GPU-0):     for troubleshooting suggestions.
#15
same issue from me.
i have 2 monitors:
the first monitor is connect to the nvidia display card via displayport.
the 2nd monitor is connect to the first monitor via displayport 1.2 daisy chain / MST.
both monitors are enable / activated in the display settings and nvidia settings. But the screen is only shown in the first screen if I enable both screen.
if I disable the first screen, I can see the 2nd screen.
endup I have the workaround by adding this in .xprofile:
xset dpms force off; sleep 1; xset dps force on
#16
I added it to .xprofile, but didn’t work.
Two monitors on Quadro2000 were displayed but a monitor on GTX750Ti wasn’t displayed.
RandR didn’t see a monitor on GTX750Ti yet.
$ xrandr -q
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 477mm x 268mm
   1920x1080     60.00*+  50.00
   1680x1050     59.95
   1600x900      60.00
   1440x900      59.89
   1280x1024     75.02    60.02
   1280x800      59.81
   1280x720      60.00    50.00
   1152x864      75.00
   1024x768      75.03    70.07    60.00
   800x600       75.00    72.19    60.32    56.25
   720x576       50.00
   720x480       59.94
   640x480       75.00    72.81    59.94
DP-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 480mm x 270mm
   1920x1080     60.00*+
   1680x1050     59.95
   1600x900      60.00
   1440x900      59.89
   1400x1050     59.98
   1280x800      59.81
   1280x720      60.00
   1152x864      75.00
   1024x768      75.03    60.00
   800x600       75.00    60.32    56.25
   640x480       75.00    59.94
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
#17
Base mosaic is for SLI. I think that’s what causing it. Hope someone with the same configuration with you can help you with this as I don’t have 2 different GPU to test this out. :slight_smile:
#18
Humm… I saw Base Mosaic is non SLI system’s technology, SLI Mosaic is SLI system’s one.
http://nvidia.helpmax.net/en/workstation/mosaic-and-sli-mosaic/reference/mosaic-and-sli-mosaic-mode/
I found descriptions that mosaic technology is supported by only Quadro cards.
Possibility, it is causeing.
But it’s not acceptable.
Xinerama was able to like it, but now not able with nvidia driver.
https://wiki.archlinux.org/index.php/multihead#Xinerama
Is alternative way nothing?
I have one more question.
Suppose it cause GTX750Ti don’t support Base Mosaic, but GTX750Ti should support MultiGPU technology.
But I got same result as Base Mosaic when delete base mosaic configuration and add MultiGPU configuration…
#19
I found not quite solution.
  • Assign each screen to each monitor.
  • Enable Xinerama.
But it’s not cool.
  • Awful performance.
  • Blinking conky widget.
  • Very unstable.
If possible, I want to use Base Mosaic and MultiGPU.
#20
The latest Nvidia 367.35 changelog:
  • Removed the Base Mosaic configuration option from nvidia-settings on systems where the feature is not actually supported.
    And 367.35 is currently in testing repository of Manjaro. You can change your branch to testing by doing sudo pacman-mirrors -g -b testing and do sudo pacman -Syyu.
    Open up nvidia settings and see if you got that option to make sure base mosaic is really possible for your cards first. :slight_smile:
