HP Laserjet 1018 install nightmare
Hi all.
I am new to Manjaro (but have some Linux experience; mostly Mint/Ubuntu).
Since installing Manjaro a few weeks ago, I have had a nightmare trying to get my HP Laserjet 1018 (USB) installed. I’ve tried many things, and have probably broken some things along the way. I could really do with some help fixing my mess.
I’ve tried (unsuccessfully):
  • HP Printer Setup (GUI and command line)
  • CUPS web interface
  • system-config-printer
  • the proprietary HP driver
  • the foo2zjs driver
  • installing and uninstalling various combinations of software and drivers
I have occasionally been able to get something to print, but:
  • I frequently get a popup dialog telling me I need to install a driver (even though that’s literally what I’ve been trying to do for hours).
  • The printer frequently seems to lose its USB connection (and I have to try various things to refresh the connection, and even then I can’t seem to get it to print reliably).
  • I even had a problem the other day where 90GB of free disk space filled up in a matter of hours because CUPS was furiously writing something to one of the logs (access.log, I think). I deleted the log and rebooted, and it seems OK now, but that was certainly interesting.
  • BTW, the same printer worked reliably under Mint/Ubuntu for years.
Can somebody please help me get this set up correctly? I’d really appreciate your help!
(Note: At this point I don’t really know what I have installed correctly, and basically need to start from scratch.)
Thanks,
Greg
I feel your pain, I’m going through this with my HP 1006 every time i install any linux distro. I had quite good success with hp-setup in the past. hp-setup is also available in Manjaro.
https://developers.hp.com/hp-linux-imaging-and-printing/install/manual/hp_setup
good luck.
Thank you @Alchemix. I’ll give that another try.
BTW, I think I’ve finally worked out that the printer itself has gone bad. Couldn’t get it working on either an Ubuntu machine or a Windows machine. Placed an order for something new.
Hi, @gtorrance,
I think the problem could be solved reading the recipe I wrote on this post.
https://forum.manjaro.org/t/basic-linux-compatible-printer/28597/7
Hope it help, regards.
Thanks @j8a. I ended up buying a new Brother printer, and that one installed without any issue. (I think the previous one was damaged, and would never install correctly, no matter how much I tried.)
I appreciate your reply. Thanks.
