I accidently deleted EFI partition and I can not boot anymore. I tried to recover with this topic (Deleted efi partition - #3 by Bitmap), but when I want to run update-grub, I get an error
[manjaro ~]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda4]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
[manjaro /]# grub-install --recheck --no-rs-codes
Installing for x86_64-efi platform.
Installation finished. No error reported.
[manjaro /]# update-grub
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
done
done
[manjaro /]#
