Pacman is not updating : invalid or corrupted database (PGP signature)
Hallo all!
I am using PACMAN, usually successfully. A few days ago, while trying to update, I got this error:
Preparing…
Synchronizing package databases…
Error: sublime-text: signature from “Sublime HQ Pty Ltd support@sublimetext.com” is unknown trust
Refreshing sublime-text.db…
Error: sublime-text.db: sublime-text: signature from “Sublime HQ Pty Ltd support@sublimetext.com” is unknown trust
Failed to synchronize databases
Failed to prepare transaction:
I have tried the various helps (Syu, Syuu) but nothing works.
is it possible to remove this Sublime? Or, how can I get PACMAN to function again?
Any help is greatly appreciated!
Check Linux Package Manager Repositories and proceed again to add the GPG keys and update again.
Hi @neverfarts, and welcome!
I suspect this is applicable here:
:bangbang: Tip: :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Side note:
If your username is true, then you’ve got to be hella bloated and it’s not good. You should go see a doctor.
I am having the same issue as here, but this thread has no solution
Can you do it and reply about that, including relevant full terminal output.
how to do this? and, this sublime, if I remember correctly, didn’t come over pacman. how can I just remove it?
OK, so I think maybe this is what is happening. I am adding this comment in case anyone is also having issues with SUBLIME-TEXT preventing PACMAN from updating:
This URL is 404 not available:
Server = …
In the file:
/etc/pacman.conf
Double click it to edit with some editor
it is mentioned:
[sublime-text]
Server = …
If you put # before, so it is like this:
#[sublime-text]
server = …
PacMAN is updating again
I think this is the solution.
Not really as now you probably still have Sublime Text installed and it will not receive updates anymore. Remove also Sublime Text from the installed software now.
In the future don’t do things you don’t understand to your system. Only use the repositories to install packages and don’t follow blindly instructions from external sources if you don’t understand the consequences and how to maintain such external packages.
I would suggest you completely remove the modifications about Sublime Text in the pacman.conf file so it is like default.
how do i completely remove sublime-text?
please post the content of /etc/pacman.conf
Actually the last post is a solution, follow the link and update the GPG key. (unfortunately I can’t edit it to correct the typo)
This is a common problem when using the sublime text repo, you need to update the GPG key, as @omano has already pointed out…twice.
An alternative is to remove sublime text, remove the sublime text repo from pacman.conf and install from another source such as the AUR.
EDIT:
It looks like you’ve only removed part of the sublime text repo, so now you need to either
  1. Revert that change and update the GPG key.
or
  1. Make sure pacman.conf is in a proper state (ie finish commenting out/removing the repo, if you haven’t already), and install sublime from another source (assuming you want it, if not uninstall sublime-text).
Whatever you do, you should post the contents of your pacman.conf here so we can check it.
