Hello there,
I’m using a nvidia/intel laptop and i use mpv a lot for my personal usage
Since the laptop is new, i’m experiencing a super weird issue
No matter what gpu acceleration method i use (even with no gpu acceleration at all), it just drops frame, especially if I pause the video and play it after a few seconds
It’s very weird and I haven’t found any solutions so far (screenshot included)
System info:
Kernel: 5.17.15-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.17-x86_64
root=UUID=15d30e75-a107-45c5-88ca-c53c47c61d7c rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=59badd34-1362-4047-814d-ef3bee046382 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82K1 v: IdeaPad Gaming 3 15IHU6
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IHU6
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
UEFI: LENOVO v: H4CN22WW(V1.07) date: 11/18/2021
ID-1: BAT1 charge: 45.7 Wh (99.6%) condition: 45.9/45.0 Wh (102.1%)
volts: 13.2 min: 11.5 model: SMP L20M3PC2 type: Li-ion serial: <filter>
status: charging
Device-1: hidpp_battery_0
model: Logitech G304 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: discharging
RAM: total: 15.41 GiB used: 2.76 GiB (17.9%)
RAM Report:
Info: model: 11th Gen Intel Core i5-11300H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1034 high: 1208 min/max: 400/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 845 2: 950 3: 919 4: 1152
5: 1208 6: 1094 7: 1101 8: 1009 bogomips: 49784
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo
driver: nvidia v: 515.57 non-free: 515.xx+ status: current (as of 2022-06)
arch: Ampere process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3
speed: 8 GT/s lanes: 4 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 02:00.0 chip-ID: 10de:25a2 class-ID: 0302
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 5986:212b class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: modesetting gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0a81 built: 2021 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
Sound Server-1: ALSA v: k5.17.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-10:7 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 394.48 GiB (33.7%)
model: MZALQ256HBJD-00BL2 size: 238.47 GiB block-size: physical: 512 B
rev: 5L2QFXM7 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: LFM4 scheme: GPT
ID-1: / raw-size: 91.98 GiB size: 91.98 GiB (100.00%)
used: 25.78 GiB (28.0%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 15d30e75-a107-45c5-88ca-c53c47c61d7c
used: 612 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
label: NO_LABEL uuid: 8B6B-957E
ID-3: /home raw-size: 91.98 GiB size: 91.98 GiB (100.00%)
ID-4: /run/media/mtn/Lin raw-size: 456.5 GiB size: 456.48 GiB (100.00%)
used: 232.66 GiB (51.0%) fs: exfat dev: /dev/sda3 maj-min: 8:3 label: Lin
uuid: 6EFF-FD15
ID-5: /run/media/mtn/Win raw-size: 475 GiB size: 475 GiB (100.00%)
used: 77.83 GiB (16.4%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Win
uuid: BA60F0D860F09C77
ID-6: /run/media/mtn/Windows raw-size: 125.42 GiB
size: 125.42 GiB (100.00%) used: 58.22 GiB (46.4%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: Windows uuid: D290253790252387
ID-7: /var/cache raw-size: 91.98 GiB size: 91.98 GiB (100.00%)
ID-8: /var/log raw-size: 91.98 GiB size: 91.98 GiB (100.00%)
ID-1: swap-1 type: partition size: 20 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 59badd34-1362-4047-814d-ef3bee046382
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 2C1C-C34A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 478 MiB fs: ntfs label: N/A
uuid: 1A6026186025FB61
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c53f class-ID: 0300
Device-2: 1-2:3 info: Megawin Defender Gaming Keyboard type: Keyboard
power: 100mA chip-ID: 0e6a:02c0 class-ID: 0301
Device-3: 1-6:4 info: Acer Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:212b
class-ID: 0e02
Device-4: 1-7:5 info: Integrated Express ITE Device(8295)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:c963 class-ID: 0300
Device-5: 1-8:6 info: Integrated Express ITE Device(8176) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c966 class-ID: 0301
Device-6: 1-10:7 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 304 Uptime: 57m wakeups: 8 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1303 pacman: 1287 lib: 340 flatpak: 16 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19
