Should run either way
Try adding yourself to the video and tty group and reboot for it to take affect.
sudo usermod -a -G tty,video yourusername
Hi @Darksky,
Since was not able to remove ffmpeg-m2m to install ffmpeg-rpi4 4.4 earlier, so giving the newer ffmpeg-m2m-1:4.4-7.
Just an update on ffmpeg-m2m. The latest ffmpeg-m2m-1:4.4-7 can coexist with ffmpeg (which currently is ffmpeg-2:6.0-8 in the Unstable Repo). This is the good news.
fl@jfl-mnjro ~]$ sudo pacman -U /home/jfl/Downloads/ffmpeg-m2m-1_4.4-7-aarch64.pkg.tar.zst
[sudo] password for jfl:
loading packages...
resolving dependencies...
Packages (1) ffmpeg-m2m-1:4.4-7
Total Installed Size: 20.56 MiB
Net Upgrade Size: -8.24 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring [##########################] 100%
(1/1) checking package integrity [##########################] 100%
(1/1) loading package files [##########################] 100%
(1/1) checking for file conflicts [##########################] 100%
(1/1) checking available disk space [##########################] 100%
(1/1) upgrading ffmpeg-m2m [##########################] 100%
(1/1) Arming ConditionNeedsUpdate...
[jfl@jfl-mnjro ~]$
Install ffmpeg-6.0-8 on Manjaro-Arm-KDE which already have ffmpeg-m2m-1_4.4-7 installed.
[jfl@jfl-mnjro ~]$ sudo pacman -S ffmpeg
Packages (8) gperftools-2.10-3 highway-1.0.6-1 imath-3.1.9-1 libjxl-0.8.2-1
libopenmpt-0.7.2-1 openexr-3.1.10-1 portaudio-1:19.7.0-2
ffmpeg-2:6.0-8
Total Download Size: 17.25 MiB
Total Installed Size: 98.67 MiB
:: Retrieving packages...
openexr-3.1.10-1... 930.1 KiB 44.5 KiB/s 00:21 [##########################] 100%
libopenmpt-0.7.2... 801.9 KiB 26.1 KiB/s 00:31 [##########################] 100%
gperftools-2.10-... 637.6 KiB 53.9 KiB/s 00:12 [##########################] 100%
portaudio-1:19.7... 90.5 KiB 33.1 KiB/s 00:03 [##########################] 100%
libjxl-0.8.2-1-a... 1254.1 KiB 33.5 KiB/s 00:37 [##########################] 100%
highway-1.0.6-1-... 626.2 KiB 20.0 KiB/s 00:31 [##########################] 100%
ffmpeg-2:6.0-8-a... 8.6 MiB 762 KiB/s 00:12 [##########################] 100%
imath-3.1.9-1-aa... 3.5 MiB 29.2 KiB/s 02:03 [##########################] 100%
Total (8/8) 17.2 MiB 143 KiB/s 02:03 [##########################] 100%
error: failed retrieving file 'ffmpeg-2:6.0-8-aarch64.pkg.tar.xz' from bd.mirror.vanehost.com : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
(8/8) checking keys in keyring [##########################] 100%
(8/8) checking package integrity [##########################] 100%
(8/8) loading package files [##########################] 100%
(8/8) checking for file conflicts [##########################] 100%
(8/8) checking available disk space [##########################] 100%
(1/8) installing gperftools [##########################] 100%
Optional dependencies for gperftools
graphviz: pprof graph generation
perl: pprof and pprof-symbolize commands [installed]
(2/8) installing highway [##########################] 100%
(3/8) installing imath [##########################] 100%
Optional dependencies for imath
python: python bindings [installed]
boost-libs: python bindings [installed]
(4/8) installing openexr [##########################] 100%
(5/8) installing libjxl [##########################] 100%
Optional dependencies for libjxl
gdk-pixbuf2: for gdk-pixbuf loader [installed]
gimp: for gimp plugin
java-runtime: for JNI bindings
(6/8) installing portaudio [##########################] 100%
(7/8) installing libopenmpt [##########################] 100%
(8/8) installing ffmpeg [##########################] 100%
Optional dependencies for ffmpeg
avisynthplus: AviSynthPlus support
ladspa: LADSPA filters
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating the MIME type database...
(3/3) Probing GDK-Pixbuf loader modules...
[jfl@jfl-mnjro ~]$
But there are two issues so far:
Old issue of mpv-hwdec-0.35.1-4 still will not stream any video on the net but will play local video from disk.
Eventhough ffmpeg-2:6.0-8 is installed together with ffmpeg-m2m-1:4.4.-7, Chromium still will NOT launch and this round is with different error: missing âlibre2.so.10â but a newer âlibre2.so.11â is available though.
Any tips on how to get Chromium to launch?
[jfl@jfl-mnjro ~]$ chromium --incognito --ozone-platform-hint=wayland
/usr/lib/chromium/chromium: error while loading shared libraries: libre2.so.10: cannot open shared object file: No such file or directory
chrmium is broke in our testing and unstable branches. I installed chromium 116 snap here. It was reported 4 days ago but nothing has been done about it yet.
Thanks for the info.
Ha, found the magic key --hwdec=auto.
mpv --hwdec=auto Ahsoka_HEVC_x265-01.mkv
Using hardware decoding (drm)
AO: [pipewire] 4800Hz
VO: [gpu] 1920x1080 drm_prime [rpi4_10]
*CPU under 20%
auto
is pretty common ⌠its ⌠auto.
auto tries to automatically enable hardware decoding using the first available method. This still depends what VO you are using. For example, if you are not using --vo=gpu or --vo=vdpau, vdpau decoding will never be enabled. Also note that if the first found method doesnât actually work, it will always fall back to software decoding, instead of trying the next method (might matter on some Linux systems).
What it shows though is that
~/.config/mpv/mpv.conf
vo=gpu
hwdec=drm
Apparently works for you.
Wow!. I tested my really stout stream I got off the satellite that will not play using SW decodingâŚ
[ray@jellyfin]$ mpv --hwdec=auto nasa.ts
(+) Video --vid=1 (hevc 3840x2160 59.940fps)
(+) Audio --aid=1 (mp2 2ch 48000Hz)
Audio --aid=2 (aac 2ch 48000Hz)
AO: [pipewire] 48000Hz stereo 2ch s16p
Using hardware decoding (drm).
Subs --sid=1 (*) (eia_608)
VO: [gpu] 3840x2160 drm_prime[rpi4_8]
AV: 00:00:01 / 00:04:24 (0%) A-V: 0.000
htop:
MediaInfo:
General
Complete name : nasa.ts
Format : MPEG-TS
File size : 487 MiB
Duration : 4 min 21 s
Overall bit rate mode : Variable
Overall bit rate : 15.6 Mb/s
Frame rate : 59.940 FPS
Video
Menu ID : 104 (0x68)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L5.1@High
Codec ID : 36
Duration : 4 min 22 s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
On Manjaro-Arm-Gnome-linux-odroid-6.4.0-1 Unstable Branch editing this message on Chromium-115.0.5790.170 and /lib/libre2.so.10 and /usr/lib/libre2.so.10
May be it is only on Manjaro-Arm-KDE issue?
Edit: Wow, impressive result/performance âfmpeg-rpi-4.4.4-2-aarch64.pkg.tar.xz mpv-1:0.36.0-3-aarch64.pkg.tar.zstâ streaming 4K/60 video.
Wonder it will work on GT King Pro?
Hi @Darksky and @spikerguy,
Just performed a System Upgrade and now the same Chromium-115.0.5790.170 NO longer launch! âlibre2.so.10â is now missing! Not sure which package upgrade resulted on this. Chromium was NOT upgraded.
Luckily, made a backup or kept copies of âlibre2.so.10â and âlibre2.so.10.0.0â. Copy âlibre2.so.10â and âlibre2.so.10.0.0â over to /lib restore Chromium-115.0.5790.170 to working order.
Edit: Installed ffmpeg-rpi-4.4.4-2 mpv-1:0.36.0-3 on Manjaro-Arm-Gnome-linux-odroid-6.4.0-1.
Hi @Darksky,
Just successfully install your new ffmpeg-rpi-4.4.4-2 mpv-1:0.36.0-3. But unfortunately mpv-1:0.36.0-3 will not launch or start with the following error:
Missing liblua5.2.so.5.2:. Currently the install âliblua.soâ is âliblua5.4.soâ and âliblua.so.5.4.6â
jfl@jfl-gtkpro î° ď î° mpv --gpu-context=wayland --hwdec=auto https://www.youtube.com/watch?v=wZnVQT_iEYo
mpv: error while loading shared libraries: liblua5.2.so.5.2: cannot open shared object file: No such file or directory
âliblua5.2.so.5.2â available for download? Is it related to this "
lua52-5.2.4-5-aarch64.pkg.tar.xz"?
If it is, in âUnstable Repoâ it doesnât have âlua54-xxxxâ, how did âliblua5.4.soâ and âliblua.so5.4.6â got installed on Manjaro-Arm-Gnome?
Edit 1: Manually âtar -xvf lua52-5.2.4-5-aarch64.pkg.tar.xzâ and copy over the respective packages to Manjaro-Arm-Gnome-6.4.0-1. But âmpv-1:0.36.0-3â still refuse to works with another missing package:
mpv --gpu-context=wayland '/home/jfl/Videos/Big Buck Bunny 60fps 4K - Official Blender Foundation Short Film [aqz-KE-bpKQ].mp4'
mpv: error while loading shared libraries: libsndio.so.7: cannot open shared object file: No such file or directory
Any suggestions on how to resolves the issues to get ffmpeg-rpi and mpv-1:0.36.0-3 to work on GT King Pro?
sndio and lua52 are both in our repo. I guess they were picked up as being on my system. Need to add to depends.
[ray@jellyfin ~]$ pacman -Ss lua52 | grep installed
extra/lua52 5.2.4-5 [installed]
extra/lua52-socket 1:3.1.0-1 [installed]
[ray@jellyfin ~]$ pacman -Ss sndio | grep installed
extra/sndio 1.9.0-1 [installed]
After installing âsndioâ (manually copied over lua52 earlier), mpv-1:0.36.0-3 now works stream with vpu hw acceleration.
î î° jfl@jfl-gtkpro î° ď î° mpv --gpu-context=wayland --hwdec=auto https://www.youtube.com/watch?v=wZnVQT_iEYo
(+) Video --vid=1 (*) (h264 1920x1080 60.000fps)
(+) Audio --aid=1 --alang=eng (*) (opus 2ch 48000Hz)
Subs --sid=1 --slang=en 'English' (webvtt) (external)
Subs --sid=2 --slang=pt 'Portuguese' (webvtt) (external)
Subs --sid=3 --slang=ru 'Russian' (webvtt) (external)
File tags:
Uploader: Hardigun
Channel_URL: https://www.youtube.com/channel/UCiyqpG37FD1BgmP-y33Et6Q
[vo/gpu/wayland] GNOME's wayland compositor lacks support for the idle inhibit protocol. This means the screen can blank during playback.
Cannot load libcuda.so.1
[vaapi] libva: /usr/lib/dri/v4l2_request_drv_video.so init failed
[ffmpeg] AVHWDeviceContext: Cannot load libcuda.so.1
[ffmpeg] AVHWDeviceContext: Could not dynamically load CUDA
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
AO: [pulse] 48000Hz stereo 2ch float
Using hardware decoding (v4l2m2m).
VO: [gpu] 1920x1080 drm_prime[nv12]
AV: 00:03:25 / 00:04:45 (72%) A-V: 0.000 Dropped: 97 Cache: 79s/19MB
Exiting... (Quit)
Thank you for your patient and guidance.
jfl@jfl-gtkpro î° ď î° lsmod|grep v4l2
v4l2_mem2mem 32768 1 meson_vdec
videobuf2_v4l2 28672 2 meson_vdec,v4l2_mem2mem
videodev 253952 3 meson_vdec,videobuf2_v4l2,v4l2_mem2mem
videobuf2_common 61440 5 meson_vdec,videobuf2_dma_contig,videobuf2_v4l2,v4l2_mem2mem,videobuf2_memops
mc 65536 4 videodev,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
Your welcome and thank you for your persistence!!
Added:
You may want to install the lua52 package so you have a full package install. Might come in handy later on.
sudo pacman -S lua52 --overwrite "*"
No you need to compile it without lua installed on your system.
It still use luajit such is already installed in most systems. I faced exact same issue while maintaining mpv-hwdec pkg.
Impressive work btw.
I can follow the ffmpeg pkgbuild to update ffmpeg-aml to follow similar method.
Thanks for the great work on ffmpeg-rpi and mpv-1:0.36.0-3 to enable vpu hw acceleration for Rpi sbc but to my surprise also work on Amlogic S922X box! One of the complain that Arm64 Linux users on mainline kernel complain availability of vpu hw acceleration, now you and @spikerguy have given this to Manjaro-Arm users albeit limited video codecs support and some functions like forward and backward seek at times can cause issue.
I also noticed that you have a version of VLC multi-media player that is compiled for or with ffmpeg-rpi. Havenât tried it yet. I suppose VLC-ffmpeg-rpi will work on GT King Pro too?
Great, looking forward to your new ffmpeg-aml and do look into mpv-hwdec. The current mpv-hwdec-1:0.35.1-4 refuses to stream any video online. Previous mpv-hwdec-1:0.35.1-1 can stream online videos but it has dependencies issue which prevented System Update on Unstable Branch.
Manjaro-Arm-Team have done a great job for TV Box users. Based on experience Manjaro-Arm-Gnome and Manjaro-Arm-KDE Editions are lightest Gnome and KDE DE implementation in terms of RAM resources usage compared to other linux distro Gnome and KDE DE implementation out of the box.
An now with availability of vpu hw accelerated support for mpv makes Manjaro-Arm even better.
which your TV box is, does it cheaper?
Beelink GT King Pro, donât think is cheaper than Rpi-4. Cheaper version is Beelink GT King (older model not GT King II).
TV Box with Amlogic S905X3 with 4GB RAM and 64GB ROM are quite inexpensive (different manufacturer).
Edit: Preliminary findings on:
i) ffmpeg-rpi mpv-1:0.36.0-3 on Manjaro-Arm-Gnome-linux-odroid-6.4.0-1 and
ii) ffmpeg-m2m mpv-hwdec-1:0.35.1-4 on Manjaro-Arm-Gnome-linux-aml-6.1.42-1
in terms of CPU resource used (eyeballing on HTOP) when playing âBig Buck Bunny 60fps 4K - Official Blender Foundation Short Film [aqz-KE-bpKQ].mp4 â file size 303.0 MBâ downloaded onto local HDD.
This is not a direct apple to apple comparison as different DEs, Kernels and mpv versions being used and furthermore on Manjaro-Arm-Gnome I did not install the complete âlua52â package â not sure whether this has any performance impact.
A) No vpu hw acceleration
mpv --gpu-context=wayland '/run/media/jfl/12FC7360FC733CD3/Movies/Big Buck Bunny 60fps 4K - Official Blender Foundation Short Film [aqz-KE-bpKQ].mp4'
VO: [gpu] 1920x1080 yuv420p
B) With vpu hw acceleration
mpv --gpu-context=wayland --hwdec=v4l2m2m '/run/media/jfl/12FC7360FC733CD3/Movies/Big Buck Bunny 60fps 4K - Official Blender Foundation Short Film [aqz-KE-bpKQ].mp4'
Preliminary findings ffmpeg-m2m mpv-hwdec on Manjaro-Arm-KDE-linux-aml-6.1.42-1 uses less CPU Resources (by eyeballing HTOP) compared to ffmpeg-rpi mpv-1:0.36.0-3 on Manjaro-Arm-Gnome-linux-odroid-6.4.0-1. On both versions, with hw acceleration enabled the CPU resources used is significantly lower than without vpu hw accleration.
For completeness, mpv-hwdec-1:0.35.1-4 will not stream any video online whereas mpv-1:0.36.0-3 can stream video online.
Wonder whether other users had similar experience.
Edit 1: Manjaro-Arm-Gnome switch to linux-aml-6.1.42-1. Same outcome as above.
ok, back to ffmpeg-6 (jc-kynesim/rpi-ffmpeg), to save others APPs depes.
then install reposâs mpv, now firefox & mpv both H/W accel.
Read with interest. You mean you are able to use the stand Manjaro-Arm Repo mpv-1:0.36.0-1 and with the Manjaro Arm ffmpeg-6 you are able to have both Firefox and mpy vpu hw accelertion?
Did not understand how you got it done. Care to elaborate? Thanks.
No, build from âjc-kynesim/rpi-ffmpegâ and its v4l2 patched & 6 version.
@Rip2
Will leave to the experts. Beyound my skill set.
Is there any pre-build packages that can be downloaded?
