Moving from Arch to Manjaro
Hi there
I’m running an outdated Arch (with Xfce) on my lap-top (for a series of reasons it was impossible to keep it updated for several months). I’m considering installing Manjaro from scratch, meaning a totally new installation, destroying the (old) Arch.
2 questions:
1 - Is it possible to “insert” my present [home] in the new Manjaro? I did it already from this Arch to another machine running Mint and it worked… I just had to install all the similar packages before “inserting” my home. I would like to do the same and be in my “environment” without much work…
2 - My lap-top is a (old) Samsung New series9:
  • Intel(R) Core™ i5-3317U CPU @ 1.70GHz
  • 8Gb RAM
  • 125 Gb SDD
    Will I be able to install Manjaro with no major hardware problems?!?
Thanks for all your support
Slira
Hi @slira, and welcome!
  1. Considering Manjaro is a fork of Arch, I think it would be possible to do so. Even better and easier than Mint, as you mentioned.
  2. I suspect it would be fine. However, to get more than a guess you’d have to give more details than that. Like manufacturer and model of the laptop’s motherboard, network controller, etc.
Hope this helps!
Thank you [Mirdarthos] for the swift answer!
I’ll gather a list of hw and will post it shortly
You do that, but if it works in Arch, I have no doubt it will work in Manjaro. Anyway, someone can tell me if I’m wrong.
Hi there
using sudo lshw I get the follwoing; can anyone please check and let me know if Manjaro will install on the hw? Thanks in advance!
 description: Laptop
    product: 900X3C/900X3D/900X3E/900X4C/900X4D (System SKUNumber)
    vendor: SAMSUNG ELECTRONICS CO., LTD.
    version: 0.1
    serial: JA9K91GD100067
    width: 4294967295 bits
    capabilities: smbios-2.7 dmi-2.7 smp vsyscall32
  *-core
       description: Motherboard
       product: NP900X4C-A04PT
       physical id: 0
       version: FAB1
       serial: 123490EN400015
       slot: Part Component
     *-firmware
          description: BIOS
          vendor: Phoenix Technologies Ltd.
          physical id: 0
          version: P04ABK
          date: 01/10/2013
          capacity: 3008KiB
          capabilities: pci upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer int10video pc98 acpi usb biosbootspecification netboot uefi
     *-cpu
          description: CPU
          product: Intel(R) Core(TM) i5-3317U CPU @ 1.70GHz
          vendor: Intel Corp.
          physical id: 4
          bus info: cpu@0
          version: Intel(R) Core(TM) i5-3317U CPU @ 1.70GHz
          serial: To Be Filled By O.E.M.
          slot: CPU Socket - U3E1
          width: 64 bits
          clock: 100MHz
          capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave avx f16c rdrand lahf_lm cpuid_fault epb pti tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms xsaveopt dtherm ida arat pln pts cpufreq
          configuration: cores=2 enabledcores=2 threads=4
        *-cache:0
             description: L1 cache
             physical id: 6
             slot: L1-Cache
             capacity: 32KiB
             capabilities: internal write-through instruction
             configuration: level=1
        *-cache:1
             description: L2 cache
             physical id: 7
             slot: L2-Cache
             capacity: 256KiB
             capabilities: internal write-through unified
             configuration: level=2
        *-cache:2
             description: L3 cache
             physical id: 8
             slot: L3-Cache
             capacity: 3MiB
             capabilities: internal write-back unified
             configuration: level=3
     *-cache
          physical id: 5
          slot: L1-Cache
          capacity: 32KiB
          capabilities: internal write-through data
     *-memory
          description: System Memory
          physical id: 36
          slot: System board or motherboard
        *-bank:0
             description: SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
             product: AM1U16BC4P2-B19C
             vendor: Fujitsu
             physical id: 0
             serial: 70920100
             slot: ChannelA-DIMM0
             width: 64 bits
             clock: 1600MHz (0.6ns)
        *-bank:1
             description: DIMM [empty]
             physical id: 1
             slot: ChannelA-DIMM1
        *-bank:2
             vendor: Fujitsu
             physical id: 2
             serial: DD920100
             slot: ChannelB-DIMM0
             width: 64 bits
        *-bank:3
             physical id: 3
             slot: ChannelB-DIMM1
     *-pci
          description: Host bridge
          product: 3rd Gen Core processor DRAM Controller
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 09
          width: 32 bits
          clock: 33MHz
          configuration: driver=ivb_uncore
          resources: irq:0
        *-display
             description: VGA compatible controller
             product: 3rd Gen Core processor Graphics Controller
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 09
             width: 64 bits
             clock: 33MHz
             capabilities: msi pm vga_controller bus_master cap_list rom
             configuration: driver=i915 latency=0
             resources: irq:28 memory:f0000000-f03fffff memory:e0000000-efffffff ioport:3000(size=64) memory:c0000-dffff
        *-communication
             description: Communication controller
             product: 7 Series/C216 Chipset Family MEI Controller #1
             physical id: 16
             bus info: pci@0000:00:16.0
             version: 04
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi bus_master cap_list
             configuration: driver=mei_me latency=0
             resources: irq:34 memory:f0705000-f070500f
        *-multimedia
             description: Audio device
             product: 7 Series/C216 Chipset Family High Definition Audio Controller
             physical id: 1b
             bus info: pci@0000:00:1b.0
             version: 04
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi pciexpress bus_master cap_list
             configuration: driver=snd_hda_intel latency=0
             resources: irq:36 memory:f0700000-f0703fff
        *-pci:0
             description: PCI bridge
             product: 7 Series/C216 Chipset Family PCI Express Root Port 1
             physical id: 1c
             bus info: pci@0000:00:1c.0
             version: c4
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:24 memory:f0600000-f06fffff
           *-network
                description: Wireless interface
                product: Centrino Advanced-N 6235
                physical id: 0
                bus info: pci@0000:01:00.0
                logical name: wlan0
                version: 24
                serial: c8:f7:33:6b:20:a1
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=iwlwifi driverversion=5.6.3-arch1-1 firmware=18.168.6.1 6000g2b-6.ucode ip=192.168.1.72 latency=0 link=yes multicast=yes wireless=IEEE 802.11
                resources: irq:37 memory:f0600000-f0601fff
        *-pci:1
             product: 7 Series/C216 Chipset Family PCI Express Root Port 4
             physical id: 1c.3
             bus info: pci@0000:00:1c.3
             version: c4
             width: 32 bits
             clock: 33MHz
             resources: irq:25 ioport:2000(size=4096) ioport:f0400000(size=1048576)
           *-network
                description: Ethernet interface
                product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
                vendor: Realtek Semiconductor Co., Ltd.
                physical id: 0
                bus info: pci@0000:02:00.0
                logical name: eth0
                version: 06
                serial: 50:b7:c3:90:6a:aa
                capacity: 1Gbit/s
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
                configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.6.3-arch1-1 firmware=rtl8168e-3_0.0.4 03/27/12 latency=0 link=no multicast=yes port=MII
                resources: irq:19 ioport:2000(size=256) memory:f0404000-f0404fff memory:f0400000-f0403fff
        *-pci:2
             product: 7 Series/C210 Series Chipset Family PCI Express Root Port 5
             physical id: 1c.4
             bus info: pci@0000:00:1c.4
             version: c4
             width: 32 bits
             clock: 33MHz
             resources: irq:26 memory:f0500000-f05fffff
           *-usb
                description: USB controller
                product: uPD720202 USB 3.0 Host Controller
                vendor: Renesas Technology Corp.
                physical id: 0
                bus info: pci@0000:03:00.0
                version: 02
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi msix pciexpress xhci bus_master cap_list
                configuration: driver=xhci_hcd latency=0
                resources: irq:16 memory:f0500000-f0501fff
              *-usbhost:0
                   product: xHCI Host Controller
                   vendor: Linux 5.6.3-arch1-1 xhci-hcd
                   physical id: 0
                   bus info: usb@2
                   logical name: usb2
                   version: 5.06
                   capabilities: usb-2.00
                   configuration: driver=hub slots=2 speed=480Mbit/s
              *-usbhost:1
                   physical id: 1
                   bus info: usb@3
                   logical name: usb3
                   version: 5.06
                   capabilities: usb-3.00
                   configuration: driver=hub slots=2 speed=5000Mbit/s
        *-usb
             product: 7 Series/C216 Chipset Family USB Enhanced Host Controller #1
             physical id: 1d
             bus info: pci@0000:00:1d.0
             version: 04
             width: 32 bits
             clock: 33MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci-pci latency=0
             resources: irq:23 memory:f0709000-f07093ff
           *-usbhost
                product: EHCI Host Controller
                vendor: Linux 5.6.3-arch1-1 ehci_hcd
                physical id: 1
                bus info: usb@1
                logical name: usb1
                version: 5.06
                configuration: driver=hub slots=3 speed=480Mbit/s
              *-usb
                   description: USB hub
                   product: Integrated Rate Matching Hub
                   vendor: Intel Corp.
                   physical id: 1
                   bus info: usb@1:1
                   version: 0.00
                   configuration: driver=hub slots=6 speed=480Mbit/s
                 *-usb:0
                      description: Mouse
                      product: Wireless Receiver
                      vendor: Telink
                      physical id: 2
                      bus info: usb@1:1.2
                      version: 1.00
                      capabilities: usb-1.10
                      configuration: driver=usbhid maxpower=50mA speed=12Mbit/s
                 *-usb:1
                      description: Bluetooth wireless interface
                      vendor: Intel Corp.
                      physical id: 5
                      bus info: usb@1:1.5
                      version: 78.69
                      capabilities: bluetooth usb-2.00
                      configuration: driver=btusb speed=12Mbit/s
                 *-usb:2
                      description: Video
                      product: Webcam SC-13HDL11624N
                      vendor: Namuga
                      physical id: 6
                      bus info: usb@1:1.6
                      version: 0.21
                      configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
        *-isa
             description: ISA bridge
             product: HM75 Express Chipset LPC Controller
             physical id: 1f
             bus info: pci@0000:00:1f.0
             version: 04
             width: 32 bits
             clock: 33MHz
             capabilities: isa bus_master cap_list
             configuration: driver=lpc_ich latency=0
             resources: irq:0
        *-storage
             description: SATA controller
             product: 7 Series Chipset Family 6-port SATA Controller [AHCI mode]
             physical id: 1f.2
             bus info: pci@0000:00:1f.2
             version: 04
             width: 32 bits
             clock: 66MHz
             capabilities: storage msi pm ahci_1.0 bus_master cap_list
             configuration: driver=ahci latency=0
             resources: irq:27 ioport:3088(size=8) ioport:3094(size=4) ioport:3080(size=8) ioport:3090(size=4) ioport:3060(size=32) memory:f0708000-f07087ff
        *-serial
             description: SMBus
             product: 7 Series/C216 Chipset Family SMBus Controller
             physical id: 1f.3
             bus info: pci@0000:00:1f.3
             version: 04
             width: 64 bits
             clock: 33MHz
             configuration: driver=i801_smbus latency=0
             resources: irq:18 memory:f0704000-f07040ff ioport:efa0(size=32)
  *-battery
       product: Smart Battery
       vendor: Intel Corp.
       physical id: 1
       version: 2008
       serial: 1.0
       slot: Rear
  *-power UNCLAIMED
       description: TBD by ODM
       product: TBD by ODM
       vendor: TBD by ODM
       physical id: 2
       version: 1.0
       serial: TBD by ODM
       capacity: 32768mWh
It shouldn’t be a problem to keep your $HOME, but one can’t say 100% for sure, since Manjaro is not Arch.
(Please edit your output from above as code using the </> button.)
Please properly format your post, always select your console output and click the </> button to properly format it. Thanks.
upsssssss, sorry, I’m not used to post on forums…
No problem. You have to edit your post by selecting the text and then format with the </> tool, or replace “</>” by “```”.
So that it will look like this:
Bla
bla
blaa
got it! thanks, and sorry for wasting your time with such a thing…
More helpful would be the output of inxi -Fazy (inxi on Arch is only available in the aur, though - if that’s a problem.)
yeap… that would be a problem because the OS is so outdated I’m not able to install new packages (I risk destroying everything… dependencies will never work). That’s why I’m considering a new installation, from scratch. I’m very happy with Arch - rock-solid, great performance - but installation is (let’s put it like this) a lot of work!
Got it (and inxi is quite hungry).
I once kept my $HOME the other way around without issues, but then I didn’t have any DE installed, just a WM.
EDIT: Hardware-wise the only big difference that comes to mind is that there are fewer kernel iterations available on Manjaro, but if you go with the LTS there shouldn’t be any issues either.
Thanks again.
If and when I install I’ll post the result :wink:
Hi All
I finally installed Manjaro in this machine (a lapt-top Samsung S9).
What I did:
  • prepared a USB pen with the image
  • boot from there
  • started the installer and order to keep partitions
    (I have 4 partions, sda1-4 (boot, swap, OS and home) in my SSD)
  • “told” Manjaro to install in sda3
  • after installation and reboot I edited the etc/fstab in order to mount the (preserved) home
  • then I installed all missing packages (my applications that were not by default in the Manjaro installation)
  • another reboot and… TCHARAM!!! I was in my “environment”; all (really: all) my configurations, passwords, favourites, e.mail, etc. etc. were OK.
Bottom line: in my case migrating from an (outdated) Arch to an updated Manjaro was quick and easy.
Thanks for your support!
