So I’m currently running manjaro i3 on my dell inspiron 14 5000. I had been using
manjaro xfce on an external sd card for a while, with no issues. My hardware info is
below
Memory: RAM: total: 7.2 GiB used: 1.58 GiB (22.0%)
CPU: Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP cache: L2: 3 MiB
Speed: 1397 MHz min/max: 1400/2375 MHz Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati unloaded: modesetting,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.0-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.2.3
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: snd_rn_pci_acp3x
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.0-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Partition: ID-1: / size: 233.38 GiB used: 11.36 GiB (4.9%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
ISSUE
When I plug in my ac power the screen dims, after that I can increase
brightness, but then the laptop becomes unresponsive. Just on a side note, my
keyboard and screen stay lit. I have checked this forum thread https://forum.manjaro.org/t/system-freeze-upon-power-unplug/4671
Here is the result after typing cmd journalctl -xe -p3 -b-1
-- Journal begins at Sat 2021-11-06 22:12:14 GMT, ends at Fri 2021-11-12 10:01:01 GMT. --
Nov 11 22:17:46 manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20210730/dswload2-162)
Nov 11 22:17:46 manjaro kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
Nov 11 22:17:48 manjaro systemd[1]: Failed to start Light Display Manager.
░░ Subject: A start job for unit lightdm.service has failed
░░ Defined-By: systemd
░░ A start job for unit lightdm.service has finished with a failure.
░░ The job identifier is 797 and the job result is failed.
Nov 11 22:17:49 manjaro systemd-backlight[740]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
Nov 11 22:17:49 manjaro systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
░░ Subject: A start job for unit systemd-backlight@backlight:acpi_video0.service has failed
░░ A start job for unit systemd-backlight@backlight:acpi_video0.service has finished with a failure.
░░ The job identifier is 870 and the job result is failed.
I think it may be something to do with my integrated gpu, although I do not have a
dedicated one.
The title also mentions my issues with lightdm. Lightdm fails to launch most often on boot( i need to switch tty and startx manually ). The reason I mention this is
because I have a feeling they might be caused by the same thing.
