Hello,
Due to issues with my Precision 7740 laptop Dell ended up replacing it with a new 7750 instead. I had finally gotten the laptop configured the way I wanted. Luckily most of the configuration was done on hard drives I had added. So I just pulled those out and put them in the new laptop. After some tweaking of the BIOS configuration and resetting the rEFInd boot manager the new laptop is booting into Manjaro and mostly working.
I ran the hardware configuration to replace the video drivers, but I’m not finding drivers for all the devices.
Problems I’ve noticed so far:
- Screen Saver (Blank screen) doesn’t wake up. I didn’t check if another VT worked.
- On shutdown the laptop doesn’t power off
- Some USB sticks don’t work (Older ones) I have some USB 2.0 PNY 32GB that I just got in a 3 pack that none of them are recognized using the standard USB ports on the laptop, but the USB port on the front of the WD19DC docking station works for all sticks. The same thing happens in Windows.
- I’m not able to mount the windows partition since it seems to be encrypted… Last laptop I had purchased the recovery install stick and had reloaded windows and had loaded Ubuntu on the same HD. This one they did not provide the installation or drivers USB sticks. And I have not reinstalled.
- In the hardware manager there are numerous devices that don’t list drivers. I can provide the mhwd listing which was very long if necessary.
On my old HP Elitebook laptop I ran Gentoo, Arch, and Ubuntu, so I have some familiarity with Arch based distros. However I’m fairly new to the Manjaro distribution.
Thank you for any pointers on what additional tasks I should be doing to update the machine configuration.
The Dell Precision 7750 configuration looks like the following:
inxi --admin --verbosity=7 --filter --no-host System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 parameters: rw root=zfs:AUTO systemd.unit=default.target initrd=\initramfs-5.9-x86_64.img Console: tty 0 DM: GDM 3.38.2.1, LightDM 1.30.0 Distro: Manjaro Linux Machine: Type: Laptop System: Dell product: Precision 7750 v: N/A serial: <filter> Chassis: type: 10 serial: <filter> Mobo: Dell model: 03KR29 v: A00 serial: <filter> UEFI: Dell v: 1.5.1 date: 11/25/2020 Battery: ID-1: BAT0 charge: 95.0 Wh condition: 95.0/95.0 Wh (100%) volts: 12.9/11.4 model: BYD DELL CR72X0C type: Li-poly serial: <filter> status: Full Device-1: hidpp_battery_0 model: Logitech K350 serial: <filter> charge: 70% (should be ignored) rechargeable: yes status: Discharging Device-2: hidpp_battery_1 model: Logitech M570 serial: <filter> charge: 95% rechargeable: yes status: Discharging Device-3: hidpp_battery_2 model: Logitech MX Ergo Multi-Device Trackball serial: <filter> charge: 55% (should be ignored) rechargeable: yes status: Discharging Memory: RAM: total: 46.7 GiB used: 31.28 GiB (67.0%) Array-1: capacity: 128 GiB slots: 4 EC: Single-bit ECC max module size: 32 GiB note: est. Device-1: DIMM B size: 16 GiB speed: spec: 2667 MT/s actual: 2400 MT/s type: DDR4 detail: synchronous bus width: 64 bits total: 72 bits manufacturer: 80AD000080AD part-no: HMA82GS7CJR8N-VK serial: <filter> Device-2: DIMM A size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s type: DDR4 detail: synchronous bus width: 64 bits total: 72 bits manufacturer: 80AD000080AD part-no: HMA81GS7DJR8N-VK serial: <filter> Device-3: DIMM D size: 16 GiB speed: spec: 2667 MT/s actual: 2400 MT/s type: DDR4 detail: synchronous bus width: 64 bits total: 72 bits manufacturer: 80AD000080AD part-no: HMA82GS7CJR8N-VK serial: <filter> Device-4: DIMM C size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s type: DDR4 detail: synchronous bus width: 64 bits total: 72 bits manufacturer: 80AD000080AD part-no: HMA81GS7DJR8N-VK serial: <filter> CPU: Info: 8-Core model: Intel Xeon W-10885M socket: U3E1 bits: 64 type: MT MCP arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: C8 L1 cache: 512 KiB L2 cache: 16 MiB L3 cache: 15.6 MiB bogomips: 76816 Speed: 900 MHz min/max: 800/5300 MHz base/boost: 4400/5300 volts: 0.9 V ext-clock: 100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900 13: 900 14: 900 15: 900 16: 900 Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled Type: l1tf status: Not affected Type: mds status: Not affected Type: meltdown status: Not affected Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling Type: srbds status: Not affected Type: tsx_async_abort status: Not affected Graphics: Device-1: Intel vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:9bf6 Device-2: NVIDIA TU117GLM [Quadro T1000 Mobile] vendor: Dell driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1fb9 Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-11:6 chip ID: 0bda:5532 serial: <filter> Display: server: X.org 1.20.10 compositor: gnome-shell driver: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa tty: 148x39 Message: Advanced graphics data unavailable in console for root. Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:06c8 Device-2: Realtek USB Audio type: USB driver: snd-usb-audio bus ID: 1-5.3.4:8 chip ID: 0bda:402e serial: <filter> Sound Server: ALSA v: k5.9.16-1-MANJARO Network: Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3 chip ID: 8086:06f0 IF: wlo1 state: up mac: <filter> IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter> IP v4: <filter> type: secondary dynamic noprefixroute scope: global broadcast: <filter> IP v6: <filter> type: noprefixroute scope: link Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel port: efa0 bus ID: 00:1f.6 chip ID: 8086:0d4c IF: eno2 state: down mac: <filter> Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus ID: 4-2.4:5 chip ID: 0bda:8153 serial: <filter> IF: enp58s0u2u4 state: up speed: 100 Mbps duplex: full mac: <filter> IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter> IP v4: <filter> type: secondary dynamic noprefixroute scope: global broadcast: <filter> IP v6: <filter> type: noprefixroute scope: link WAN IP: <filter> RAID: Device-1: mpool type: zfs status: ONLINE size: 1.81 TiB free: 1.46 TiB allocated: 361 GiB Components: Online: N/A Drives: Local Storage: total: raw: 5.97 TiB usable: 7.78 TiB used: 1.62 TiB (20.8%) ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 970 EVO Plus 2TB size: 1.82 TiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7 temp: 41.9 C SMART: yes health: PASSED on: 50 hrs cycles: 135 read-units: 396,901 [203 GB] written-units: 2,387,346 [1.22 TB] ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Micron model: 2300 NVMe 512GB size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 23000020 temp: 30.9 C SMART: yes health: PASSED on: 8 hrs cycles: 155 read-units: 2,353,162 [1.20 TB] written-units: 2,725,595 [1.39 TB] ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Addlink model: M.2 PCIE G3x4 NVMe size: 1.86 TiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: ECFM13.1 temp: 26.9 C SMART: yes health: PASSED on: 117d 16h cycles: 359 read-units: 23,559,748 [12.0 TB] written-units: 33,229,499 [17.0 TB] ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: BUP Slim BK size: 1.82 TiB block size: physical: 4096 B logical: 512 B serial: <filter> rev: 0302 SMART Message: A mandatory SMART command failed. Various possible causes. Message: No Optical or Floppy data was found. Partition: ID-1: / raw size: N/A size: 1.43 TiB used: 23.78 GiB (1.6%) fs: zfs raid: mpool/ROOT/manjaro label: N/A uuid: N/A ID-2: /boot raw size: 11 GiB size: 10.76 GiB (97.86%) used: 156.4 MiB (1.4%) fs: ext4 block size: 4096 B dev: /dev/nvme2n1p3 maj-min: 259:3 label: N/A uuid: 99e87bfe-019d-4695-965c-b0dabdf36dc1 ID-3: /boot/efi raw size: 190 MiB size: 186 MiB (97.89%) used: 111 MiB (59.7%) fs: vfat block size: 512 B dev: /dev/nvme1n1p1 maj-min: 259:8 label: ESP uuid: 4AD5-9813 ID-4: /boot/efi1 raw size: 1024 MiB size: 1022 MiB (99.80%) used: 111.8 MiB (10.9%) fs: vfat block size: 512 B dev: /dev/nvme2n1p1 maj-min: 259:1 label: N/A uuid: E778-3CBF ID-5: /home raw size: N/A size: 1.72 TiB used: 326.07 GiB (18.5%) fs: zfs raid: mpool/DATA/home label: N/A uuid: N/A ID-6: /mpool raw size: N/A size: 1.4 TiB used: 128 KiB (0.0%) fs: zfs raid: mpool label: N/A uuid: N/A ID-7: /root raw size: N/A size: 1.4 TiB used: 177.1 MiB (0.0%) fs: zfs raid: mpool/DATA/home/root label: N/A uuid: N/A ID-8: /run/media/wsuetholz/Misc2TB raw size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.26 TiB (69.5%) fs: ntfs block size: 4096 B dev: /dev/sdb1 maj-min: 8:17 label: Misc2TB uuid: A4E83FF7E83FC5F8 ID-9: /var/cache/pacman raw size: N/A size: 1.41 TiB used: 8.04 GiB (0.6%) fs: zfs raid: mpool/ROOT/var/cache/pacman label: N/A uuid: N/A ID-10: /var/lib/docker raw size: N/A size: 1.4 TiB used: 128 KiB (0.0%) fs: zfs raid: mpool/ROOT/var/lib/docker label: N/A uuid: N/A ID-11: /var/lib/libvirt raw size: N/A size: 1.4 TiB used: 128 KiB (0.0%) fs: zfs raid: mpool/ROOT/var/lib/libvirt label: N/A uuid: N/A ID-12: /var/lib/snapd raw size: N/A size: 1.41 TiB used: 2.98 GiB (0.2%) fs: zfs raid: mpool/ROOT/var/lib/snapd label: N/A uuid: N/A Swap: Kernel: swappiness: 10 (default 60) cache pressure: 50 (default 100) ID-1: swap-1 type: partition size: 32 GiB used: 4.8 MiB (0.0%) priority: -2 dev: /dev/nvme2n1p2 maj-min: 259:2 label: N/A uuid: 7e6b48b2-6c2d-47d7-8bfa-6b887a899b97 Unmounted: ID-1: /dev/dm-0 maj-min: 254:0 mapped: pve-swap size: 7.25 GiB fs: N/A label: N/A uuid: f3ffffd8-5755-46ab-84fc-738e4efabb51 ID-2: /dev/dm-1 maj-min: 254:1 mapped: pve-root size: 14.5 GiB fs: N/A label: N/A uuid: 7101428c-6f7d-489e-88b8-1b4ccac26ea2 ID-3: /dev/nvme1n1p2 maj-min: 259:9 size: 128 MiB fs: N/A label: N/A uuid: N/A ID-4: /dev/nvme1n1p3 maj-min: 259:10 size: 474.31 GiB fs: bitlocker label: N/A uuid: N/A ID-5: /dev/nvme1n1p4 maj-min: 259:11 size: 990 MiB fs: ntfs label: WINRETOOLS uuid: 44CACAE5CACAD27A ID-6: /dev/nvme1n1p5 maj-min: 259:12 size: 1.34 GiB fs: ntfs label: DELLSUPPORT uuid: 3E6CB1656CB1189B USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 Device-1: 1-3:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b Hub: 1-5:3 info: Realtek Dell dock ports: 5 rev: 2.1 speed: 480 Mb/s chip ID: 0bda:5487 Hub: 1-5.3:5 info: Realtek Dell dock ports: 6 rev: 2.1 speed: 480 Mb/s chip ID: 0bda:5413 Device-1: 1-5.3.4:8 info: Realtek USB Audio type: Audio driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:402e serial: <filter> Device-2: 1-5.3.5:10 info: Dell Dell dock type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 413c:b06f Device-3: 1-5.5:7 info: Dell Dell dock type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 413c:b06e Device-4: 1-10:4 info: Broadcom 58200 type: Smart Card driver: N/A interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 0a5c:5843 serial: <filter> Device-5: 1-11:6 info: Realtek Integrated_Webcam_HD type: Video driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:5532 serial: <filter> Device-6: 1-14:9 info: Intel type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0026 Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003 Device-1: 2-1:4 info: Seagate RSS LLC Backup Plus Portable Drive type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s chip ID: 0bc2:ab24 serial: <filter> Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003 Hub: 4-2:2 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 0bda:0487 Hub: 4-2.3:3 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 5 Gb/s chip ID: 0bda:0413 Device-1: 4-2.4:5 info: Realtek RTL8153 Gigabit Ethernet Adapter type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s chip ID: 0bda:8153 serial: <filter> Sensors: System Temperatures: cpu: 72.0 C mobo: N/A Fan Speeds (RPM): cpu: 0 fan-2: 0 Info: Processes: 569 Uptime: 2h 13m wakeups: 429 Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 2053 pacman: 2010 lib: 449 flatpak: 35 snap: 8 Shell: Bash v: 5.1.0 running in: tty 0 inxi: 3.2.01
