So first of all, I am new to Linux and don’t have a large experience about it. I also dual booted manjora with windows for exactly those cases and for gaming.
The problem, when I installed manjora and everything was working, I made a update to different things I can’t really remember. It was just a lot and after the update I restarted my pc and there I was stuck at recovering Journal.
I researched and find out that it could maybe be vesa, but it wasn’t because it doesn’t even exist when I tried to deinstall it. Just to say it took me 1 and half hours to just open a tty, because alt+CTRL+f3 didn’t work. So you maybe see my knowledge in Linux.
Then I tried the fsck -a
command from the Arch wiki. But it said the my /dev/nvme1n1p6 is mounted
and gave the error e2fsck
I followed the instructions of what to do when the error code e2fsck
happens and find out the directory by the mount
command. It says /dev/nvme1n1p6 on / type ext4 (rw, noatime)
. I typed it in without the last bracket so the rw, noatime and it’s says unmount: /: target busy.
and a line under umount: type: no mount point specified
And for ext4
The same.
You cannot fsck
a mounted filesystem, and considering that it’s your root filesysem that needs checking, you cannot unmount it. In other words, you’ll need to boot up from the install medium in live mode and check the filesystem from there, without mounting anything.
That said however, just because the system gets stuck during the boot process doesn’t mean that the reason it gets stuck has anything to do with the verbose messages on the screen. But in this case, it might. So best is to check the root filesystem from within the live session of the installer.
Wait, kinda confused. So you saying I should boot up from mine install medium, so that would be my usb drive with manjora right?? And also does that mean I would reinstall manjora? I know it’s a pretty dumb question but I am kinda confused.
Correct, yes.
No, not at all. The install medium has a live mode, whereby you can use a Manjaro system for testing without needing to install anything. This live system runs off the USB (or CD/DVD) and has all the necessary tools on board for repairing your system.
P.S.: It’s Manjaro, not “Manjora”.
Sorry for miss typing, I am doing it on my phone.
So I am not sure if I am doing it right, because I am using it now on my usb, but I am not sure where exactly I should go to fix the problem. So into manjaro itself ore go to terminal. I know I am not smartest now.
Open up a terminal window. There you can issue the fsck
command.
sudo su -
fsck -C -t ext4 /dev/nvme1n1p6
Ok, sorry it took so long. So I did what you said and it gave me the same response I response when the problem happend:
fsck from until-Linux 2.37.2
e2fsck 1.46.4
/dev/nvme1n1p6: clean 295648/2883584 files, 3592623/11520000 blocks
But what is the problem? You’re not being very clear about that.
/dev/nvme1n1p6: clean, 295648/2883584 files, 3592623/11520000 blocks
This is what I see when I try booting into manjaro without usb. I am not sure if it is a process because the number went up. 3 hours ago I made a picture and it went up by 8 file and some blocks. I don’t know if it a process ore what, but if it takes longer I will just reinstall manjora because I didn’t have anything important on it.
That’s just the normal filesystem check at boot time. If you do not want to see that, then edit /etc/default/grub
, look for the line that says…
GRUB_CMDLINE_LINUX_DEFAULT="udev.log_priority=3"
… or something similar, and add the word “quiet” to that line, so that it looks more or less like this…
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
Then save the file and run…
sudo update-grub
… in a terminal window.
I think (…speculation, from what was said so far)
that this is simply the only and last message you see
before the system then fails to start the display manager.
It’s not an error - just a message, and not the cause of your problem.
That symptom is often related with graphics card drivers - but that is all I can say.
Yea I think that makes sense, I have property driver because I have a Nvidia 3070 and I think I will just reinstall manjaro. It’s the easiest way without spending to much time.
Ok I finally found the problem, it was the Nvidia drivers and when I reinstall manjaro, same thing happened again. I found the solution in this Reddit post. The code I should run pacman -S linux510 linux510-nvidia
Problem is, it should work, but it has an error and no idea how to fix it.
grub-probe: error: cannot find a GRUB drive for /dev/sdb1,
Check your device, map.
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.
Found Windows Boat Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfu,efi
Adding boot menu entry for UEFI Firmware Settings
/us/bin/grub-probe: warning: unknown device type nvme1n1.
Your card, using or needing that driver, might not be supported anymore.
Or not with this kernel version.
We don’t know anything about your hardware.
Or perhaps the “code you should run” is incorrect … wrong driver?
I think, the output you posted above is o.k.
At least it’s got nothing to do with your graphics card driver.
So I am using a 3070, with amd cpu and running it on a ssd.
that is very sparse info
please look (search) for “how to provide good information”
We don’t know what you don’t tell us
and effective help depends on information
else it stays in the realm of pure speculation.
First my system info:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=92091756-71bb-41b2-b117-274fd5a5c024 rw quiet apparmor=1
Console: pty pts/2 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
v: 1.0 serial: <filter> UEFI: American Megatrends LLC. v: 1.53
date: 12/30/2020
RAM: total: 31.28 GiB used: 2.99 GiB (9.6%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: 8 GiB speed: 3600 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Corsair part-no: CMK16GX4M2D3600C18
serial: N/A
Device-2: DIMM 1 size: 8 GiB speed: 3600 MT/s type: DDR4
serial: N/A
Device-3: DIMM 0 size: 8 GiB speed: 3600 MT/s type: DDR4
serial: N/A
Device-4: DIMM 1 size: 8 GiB speed: 3600 MT/s type: DDR4
serial: N/A
Info: model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2325 high: 3700 min/max: 2200/4650 boost: enabled
base/boost: 3700/4650 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 3700 9: 2200 10: 2200 11: 2200 12: 2200
bogomips: 88847
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
v: 470.63.01 alternate: nouveau bus-ID: 2d:00.0 chip-ID: 10de:2484
class-ID: 0300
Display: server: X.org 1.21.1.3 compositor: kwin_x11 driver:
loaded: nvidia tty: 281x73
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: TC Electronic GoXLRMini type: USB driver: snd-usb-audio
bus-ID: 1-2:3 chip-ID: 1220:8fe4 class-ID: 0102
Device-4: C-Media Schiit Modi 3 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2 chip-ID: 0d8c:0066
class-ID: 0300
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: f000 bus-ID: 26:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 28:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
Local Storage: total: 3.67 TiB used: 13.69 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR021 temp: 38.9 C scheme: GPT
SMART: yes health: PASSED on: 72d 21h cycles: 611
read-units: 59,496,407 [30.4 TB] written-units: 17,283,238 [8.84 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 233010WD temp: 37.9 C scheme: GPT
SMART: yes health: PASSED on: 10d 4h cycles: 94
read-units: 40,270 [20.6 GB] written-units: 143,896 [73.6 GB]
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: 0001 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 72d 19h cycles: 610
read: 9.09 TiB written: 4.94 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: A-Data
model: USB Flash Drive size: 28.91 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 43.95 GiB size: 42.95 GiB (97.74%) used: 12.95 GiB (30.1%)
fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p6 maj-min: 259:6 label: N/A
uuid: 92091756-71bb-41b2-b117-274fd5a5c024
used: 25.4 MiB (26.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:8 label: N/A uuid: 520E-80E6
ID-3: /home raw-size: 86.42 GiB size: 84.5 GiB (97.79%)
used: 734 MiB (0.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p3
maj-min: 259:3 label: N/A uuid: 4e5fb66e-76b2-43bc-a895-7f9ea8a3a58d
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p5 maj-min: 259:5 label: N/A
uuid: b749e743-3492-4ada-806c-3e693825accf
ID-1: /dev/nvme0n1p2 maj-min: 259:9 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:10 size: 930.9 GiB fs: ntfs label: N/A
uuid: B4EC13BEEC137A36
ID-3: /dev/nvme0n1p4 maj-min: 259:11 size: 505 MiB fs: ntfs label: N/A
uuid: 5262D05462D03E83
ID-4: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-5: /dev/nvme1n1p2 maj-min: 259:2 size: 785.01 GiB fs: ntfs
label: 2. SSd uuid: 9C94664294661F50
ID-6: /dev/nvme1n1p4 maj-min: 259:4 size: 512 MiB fs: vfat label: NO_LABEL
uuid: 5102-AD3A
ID-7: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-8: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: Disk drive
uuid: EA10F91A10F8EF07
ID-9: /dev/sdb1 maj-min: 8:17 size: 3.24 GiB fs: iso9660
ID-10: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 99C0-51B6
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 1-1:2 info: KBDFANS KBD67MKIIRGBV3 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 4b42:0100 class-ID: 0300
Device-2: 1-2:3 info: TC Electronic GoXLRMini type: Audio
driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s
Device-3: 1-4:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c84 class-ID: 0300 serial: <filter>
Hub-4: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: A-DATA ADATA USB Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 504mA
chip-ID: 125f:db8a class-ID: 0806 serial: <filter>
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: C-Media Schiit Modi 3 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0d8c:0066 class-ID: 0300
Device-2: 5-4:3 info: SINOWEALTH Wired Gaming Mouse type: Mouse,Keyboard
driver: glorious,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 480mA
chip-ID: 258a:0033 class-ID: 0301
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 33.1 C mobo: N/A
Processes: 325 Uptime: 50m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1226 lib: 338
flatpak: 0 Shell: Bash (su) v: 5.1.16 running-in: pty pts/2 inxi: 3.3.12
Also the error code: Warning: installing nvidia-utils (495.46-3) breaks dependency 'nvidia-utils=470.63.01' required by linux513-nvidia Add linux513-nvidia to remove A restart is required for the changes to take effect.
And then what I what i did that apparently solves the problem but i got a error code at the end:
resolving dependencies...
Packages (2) linux510-5.10.93-1 linux510-nvidia-495.46-10
Total Download Size: 115.25 MiB
Total Installed Size: 119.82 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
linux510-5.10.93-1-x86_64 73.9 MiB 36.0 MiB/s 00:02 [#########################################################################################################] 100%
linux510-nvidia-495.46-10-x86_64 41.3 MiB 38.6 MiB/s 00:01 [#########################################################################################################] 100%
Total (2/2) 115.2 MiB 36.6 MiB/s 00:03 [#########################################################################################################] 100%
(2/2) checking keys in keyring [#########################################################################################################] 100%
(2/2) checking package integrity [#########################################################################################################] 100%
(2/2) loading package files [#########################################################################################################] 100%
(2/2) checking for file conflicts [#########################################################################################################] 100%
(2/2) checking available disk space [#########################################################################################################] 100%
(1/2) installing linux510 [#########################################################################################################] 100%
Optional dependencies for linux510
crda: to set the correct wireless channels of your country [installed]
(2/2) installing linux510-nvidia [#########################################################################################################] 100%
In order to use nvidia module, reboot the system.
(1/6) Arming ConditionNeedsUpdate...
(2/6) Updating module dependencies...
(3/6) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.93-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
(4/6) Updating Kernel initcpios for Nvidia-DRM...
(5/6) Refreshing PackageKit...
(6/6) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
/usr/bin/grub-probe: warning: unknown device type nvme1n1.
done
good on you that it is solved - but there is no error code at the end
just a warning message
