as you can see there are no windows on my desktop and I cannot access them through alt and shift. I can see that the applications are running on the sidebar but even clicking on them doesn’t not do anything.
How do I fix that?
How do I fix that?
do you have maybe a second monitor plugged even if it is not switched on?
No,not at all
or maybe right click on the task manager - configure task manager - behaviour - show windows on all activities as opposed to just current activity
I cant open any windows,they are not visibale.
this is a difficult one, :- ) is this kde plasma ? do you have a taskbar widget in the panel ?
Yes its KDE plasma. Maybe there is a command to reset all settings thtough command line?
taskbar widget ? no. should i try add it?
edit: tried adding task manager to the panel. nothing,still all is invincible
