Hello there,
I’ve been experiencing some weird issues. Sometimes completely random mt mouse starts clicking on its own. It seems that its drawn to the upper right side of my screen.
I’ve tried to switch from kernel 6 to 5 and also changed my video drivers but this does not help.
The process just starts random and then also randomly stops again.
A video can be found here showing the behavior: https://youtu.be/eRTcLwHNouU
It looks like my keyboard and touch screen are still functioning correctly but that my mouse is just behaving weird.
Currently i’m guessing that my trackpad might be malfunctioning or there is something wrong with the driver. I have also been experiencing weird clicks from now and then (I think).
This is my system info:
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=132c0983-7600-47e3-b5a6-a1cb78ee220a rw quiet splash apparmor=1
security=apparmor resume=UUID=b125d531-c3f9-4f5e-bf7c-0644d0456280
udev.log_priority=3
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Google product: Dragonair v: rev4
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: HP model: Dragonair v: rev4 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.17.2 date: 07/18/2022
ID-1: BAT0 charge: 44.5 Wh (86.6%) condition: 51.4/61.2 Wh (84.0%)
volts: 12.2 min: 11.6 model: 333-1C- BC03060 type: Li-ion serial: <filter>
status: discharging cycles: 234
Device-1: hid-0018:27C6:0E02.0001-battery model: GDIX0000:00 27C6:0E02
serial: N/A charge: N/A status: N/A
RAM: total: 7.64 GiB used: 1.58 GiB (20.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1000 high: 1001 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1000 2: 1000 3: 1000
4: 1000 5: 1000 6: 1000 7: 1000 8: 1001 bogomips: 33615
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
type: USB driver: uvcvideo bus-ID: 1-7:2 chip-ID: 05c8:03e1 class-ID: 0e02
serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: N/A unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x818b built: 2019 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF-ID-1: manjaro state: unknown speed: N/A duplex: N/A mac: N/A
IP v6: <filter> type: noprefixroute scope: global
IF-ID-2: virbr0 state: down mac: <filter>
bus-ID: 1-10:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 116.48 GiB used: 88.09 GiB (75.6%)
ID-1: /dev/mmcblk1 maj-min: 179:0 vendor: SanDisk model: DA4128
size: 116.48 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: GPT
ID-1: / raw-size: 107.38 GiB size: 105.14 GiB (97.91%) used: 88.09 GiB
(83.8%) fs: ext4 dev: /dev/mmcblk1p2 maj-min: 179:2 label: N/A
uuid: 132c0983-7600-47e3-b5a6-a1cb78ee220a
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/mmcblk1p1 maj-min: 179:1 label: NO_LABEL
uuid: C899-878E
dev: /dev/mmcblk1p3 maj-min: 179:3 label: swap
uuid: b125d531-c3f9-4f5e-bf7c-0644d0456280
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-7:2 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 05c8:03e1 class-ID: 0e02
serial: <filter>
Device-2: 1-10:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 55.0 C pch: 55.0 C mobo: N/A
Processes: 307 Uptime: 0m wakeups: 315 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1537 libs: 301 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.22
