Mouse settings not functioning properly
I just installed Manjaro Cinnamon and I quickly noticed that the mouse settings are not working. Mouse acceleration is still present while being disabled and mouse sensitivity is through the roof even though it is at the lowest possible level.
Thanks in advance !
What is your mouse?
Logitech G102 Prodigy
This seems to be a programmable mouse, so it is likely using its internally configured settings. You may be able to configure it with piper.
https://wiki.archlinux.org/title/Mouse_buttons#User_tools
Yes this is adequate to solve the problem thanks a lot !
