Hello,
I just switched from Mac OS to Manjaro on a Huawei Matebook 16 and like it very well. The function keys except brightness control all worked from the box, for the brightness I just had to add a short line to the grub file. There now is only one problem:
After the laptop wakes up from sleep (e.g. if the lid is reopened) the Fn-key shows no response at all anymore, also no response in showkey
. So pressing a F1-F12 key always is sensed as a the F-key and not the volume/brightness function, irregardless if the fn-key is pressed or not. The small Fn-lock LED indicator is also not switching when the key is pressed alone (which normally enables Fn-lock). Also, pressing caps lock still switches caps lock on but the indicator LED is not switched on. All of this changes back to normal after restarting the laptop.
Journal of the time between lid close and lid open:
Nov 17 17:15:20 systemd-logind[633]: Lid closed.
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.3935] manager: sleep: sleep requested (sleeping: no enabled: yes)
Nov 17 17:15:20 ModemManager[668]: <info> [sleep-monitor] system is about to suspend
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.3938] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.3946] manager: NetworkManager state is now ASLEEP
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.3949] device (wlp1s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Nov 17 17:15:20 dbus-daemon[627]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=628 comm="/usr/bin/NetworkManager --no-daemon ")
Nov 17 17:15:20 systemd[1]: Starting Network Manager Script Dispatcher Service...
Nov 17 17:15:20 dbus-daemon[627]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Nov 17 17:15:20 systemd[1]: Started Network Manager Script Dispatcher Service.
Nov 17 17:15:20 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:20 kernel: kauditd_printk_skb: 14 callbacks suppressed
Nov 17 17:15:20 kernel: audit: type=1130 audit(1637165720.402:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:20 kernel: wlp1s0: deauthenticating from f4:06:8d:df:28:98 by local choice (Reason: 3=DEAUTH_LEAVING)
Nov 17 17:15:20 wpa_supplicant[927]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=f4:06:8d:df:28:98 reason=3 locally_generated=1
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.4835] device (wlp1s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Nov 17 17:15:20 avahi-daemon[625]: Withdrawing address record for fe80::9c45:2291:a9a3:7e0 on wlp1s0.
Nov 17 17:15:20 avahi-daemon[625]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::9c45:2291:a9a3:7e0.
Nov 17 17:15:20 avahi-daemon[625]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.5459] dhcp4 (wlp1s0): canceled DHCP transaction
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.5460] dhcp4 (wlp1s0): state changed bound -> terminated
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.5463] dhcp6 (wlp1s0): canceled DHCP transaction
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.5464] dhcp6 (wlp1s0): state changed bound -> terminated
Nov 17 17:15:20 avahi-daemon[625]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
Nov 17 17:15:20 avahi-daemon[625]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.2.162.
Nov 17 17:15:20 avahi-daemon[625]: Withdrawing address record for 192.168.2.162 on wlp1s0.
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.5494] device (wlp1s0): set-hw-addr: set MAC address to 8A:6E:CF:A9:DA:85 (scanning)
Nov 17 17:15:20 avahi-daemon[625]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.2.162.
Nov 17 17:15:20 avahi-daemon[625]: New relevant interface wlp1s0.IPv4 for mDNS.
Nov 17 17:15:20 avahi-daemon[625]: Registering new address record for 192.168.2.162 on wlp1s0.IPv4.
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.5585] device (wlp1s0): supplicant interface state: completed -> disconnected
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.5601] device (wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Nov 17 17:15:20 NetworkManager[628]: <info> [1637165720.5621] device (wlp1s0): set-hw-addr: reset MAC address to 08:5B:D6:07:D3:B1 (unmanage)
Nov 17 17:15:20 systemd[1]: Reached target Sleep.
Nov 17 17:15:20 systemd[1]: Starting System Suspend...
Nov 17 17:15:20 wpa_supplicant[927]: nl80211: deinit ifname=p2p-dev-wlp1s0 disabled_11b_rates=0
Nov 17 17:15:20 systemd-sleep[1795]: Entering sleep state 'suspend'...
Nov 17 17:15:20 kernel: PM: suspend entry (s2idle)
Nov 17 17:15:20 kernel: Filesystems sync: 0.007 seconds
Nov 17 17:15:20 wpa_supplicant[927]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
Nov 17 17:15:25 kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Nov 17 17:15:25 kernel: OOM killer disabled.
Nov 17 17:15:25 kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Nov 17 17:15:25 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Nov 17 17:15:25 kernel: ACPI: EC: interrupt blocked
Nov 17 17:15:25 kernel: ACPI: EC: interrupt unblocked
Nov 17 17:15:25 kernel: [drm] PCIE GART of 1024M enabled.
Nov 17 17:15:25 kernel: [drm] PTB located at 0x000000F400900000
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resuming...
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: dpm has been disabled
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: SMU is resumed successfully!
Nov 17 17:15:25 kernel: nvme nvme0: 16/0/0 default/read/poll queues
Nov 17 17:15:25 kernel: [drm] DMUB hardware initialized: version=0x01010019
Nov 17 17:15:25 kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Nov 17 17:15:25 kernel: [drm] JPEG decode initialized successfully.
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 1 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 4 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 5 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 6 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 7 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 8 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 9 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 10 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring kiq_2.1.0 uses VM inv eng 11 on hub 0
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 1
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 1
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 1
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 1
Nov 17 17:15:25 kernel: amdgpu 0000:03:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 1
Nov 17 17:15:25 kernel: OOM killer enabled.
Nov 17 17:15:25 kernel: Restarting tasks ... done.
Nov 17 17:15:25 systemd-logind[633]: Lid opened.
Nov 17 17:15:25 kernel: ata1: SATA link down (SStatus 0 SControl 300)
Nov 17 17:15:25 kernel: ata2: SATA link down (SStatus 0 SControl 300)
Nov 17 17:15:25 systemd-sleep[1795]: System returned from sleep state.
Nov 17 17:15:25 bluetoothd[970]: Controller resume with wake event 0x0
Nov 17 17:15:25 kernel: PM: suspend exit
Nov 17 17:15:25 systemd[1]: systemd-suspend.service: Deactivated successfully.
Nov 17 17:15:25 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:25 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:25 systemd[1]: Finished System Suspend.
Nov 17 17:15:25 systemd[1]: Stopped target Sleep.
Nov 17 17:15:25 systemd[1]: Reached target Suspend.
Nov 17 17:15:25 systemd[1]: Stopped target Suspend.
Nov 17 17:15:25 systemd-logind[633]: Operation 'sleep' finished.
Nov 17 17:15:25 kernel: audit: type=1130 audit(1637165725.616:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:25 kernel: audit: type=1131 audit(1637165725.616:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:25 ModemManager[668]: <info> [sleep-monitor] system is resuming
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.6260] manager: sleep: wake requested (sleeping: yes enabled: yes)
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.6265] device (wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.6291] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.6294] manager: NetworkManager state is now DISCONNECTED
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.7543] device (wlp1s0): supplicant interface state: internal-starting -> disconnected
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.7544] device (p2p-dev-wlp1s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.7552] Wi-Fi P2P device controlled by interface wlp1s0 created
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.7558] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.7561] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.7575] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Nov 17 17:15:25 NetworkManager[628]: <info> [1637165725.7594] device (p2p-dev-wlp1s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Nov 17 17:15:25 systemd[1]: Stopping User Manager for UID 963...
Nov 17 17:15:25 systemd[1023]: Stopped target Main User Target.
Nov 17 17:15:25 systemd[1023]: Stopping D-Bus User Message Bus...
Nov 17 17:15:25 systemd[1023]: Stopped D-Bus User Message Bus.
Nov 17 17:15:25 systemd[1023]: Stopped target Basic System.
Nov 17 17:15:25 systemd[1023]: Stopped target Paths.
Nov 17 17:15:25 systemd[1023]: Stopped target Sockets.
Nov 17 17:15:25 systemd[1023]: Stopped target Timers.
Nov 17 17:15:25 systemd[1023]: Closed D-Bus User Message Bus Socket.
Nov 17 17:15:25 systemd[1023]: Closed GnuPG network certificate management daemon.
Nov 17 17:15:25 systemd[1023]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Nov 17 17:15:25 systemd[1023]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Nov 17 17:15:25 systemd[1023]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Nov 17 17:15:25 systemd[1023]: Closed GnuPG cryptographic agent and passphrase cache.
Nov 17 17:15:25 systemd[1023]: Closed p11-kit server.
Nov 17 17:15:25 systemd[1023]: Closed Multimedia System.
Nov 17 17:15:25 systemd[1023]: Closed Sound System.
Nov 17 17:15:25 systemd[1023]: Removed slice User Application Slice.
Nov 17 17:15:25 systemd[1023]: Reached target Shutdown.
Nov 17 17:15:25 systemd[1023]: Finished Exit the Session.
Nov 17 17:15:25 systemd[1023]: Reached target Exit the Session.
Nov 17 17:15:25 systemd[1024]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Nov 17 17:15:25 systemd[1]: user@963.service: Deactivated successfully.
Nov 17 17:15:25 systemd[1]: Stopped User Manager for UID 963.
Nov 17 17:15:25 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:25 kernel: audit: type=1131 audit(1637165725.906:93): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:25 systemd[1]: Stopping User Runtime Directory /run/user/963...
Nov 17 17:15:25 systemd[1]: run-user-963.mount: Deactivated successfully.
Nov 17 17:15:25 systemd[1]: user-runtime-dir@963.service: Deactivated successfully.
Nov 17 17:15:25 systemd[1]: Stopped User Runtime Directory /run/user/963.
Nov 17 17:15:25 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:25 kernel: audit: type=1131 audit(1637165725.923:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 17 17:15:25 systemd[1]: Removed slice User Slice of UID 963.
Nov 17 17:15:25 systemd[1]: user-963.slice: Consumed 1.039s CPU time.
Nov 17 17:15:26 kernel: ata2: failed stop FIS RX (-16)
Nov 17 17:15:26 kernel: ata1: failed stop FIS RX (-16)
Nov 17 17:15:26 kernel: ata1: SATA link down (SStatus 0 SControl 300)
Nov 17 17:15:26 kernel: ata2: SATA link down (SStatus 0 SControl 300)
Nov 17 17:15:28 ModemManager[668]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:01:00.0': not supported by any plugin
Nov 17 17:15:29 wpa_supplicant[927]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4501] policy: auto-activating connection 'Goertz-HotSpot' (4ffb8b73-6947-4afa-b5a9-2c6c725d1dfd)
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4509] device (wlp1s0): Activation: starting connection 'Goertz-HotSpot' (4ffb8b73-6947-4afa-b5a9-2c6c725d1dfd)
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4510] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4515] manager: NetworkManager state is now CONNECTING
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4524] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4530] device (wlp1s0): Activation: (wifi) connection 'Goertz-HotSpot' requires no security. No secrets needed.
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4530] Config: added 'ssid' value 'Goertz-HotSpot'
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4531] Config: added 'scan_ssid' value '1'
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4531] Config: added 'bgscan' value 'simple:30:-70:86400'
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4531] Config: added 'key_mgmt' value 'NONE'
Nov 17 17:15:29 wpa_supplicant[927]: wlp1s0: SME: Trying to authenticate with f4:06:8d:df:28:98 (SSID='Goertz-HotSpot' freq=2452 MHz)
Nov 17 17:15:29 kernel: wlp1s0: authenticate with f4:06:8d:df:28:98
Nov 17 17:15:29 kernel: wlp1s0: send auth to f4:06:8d:df:28:98 (try 1/3)
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4704] device (wlp1s0): supplicant interface state: disconnected -> authenticating
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.4705] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> authenticating
Nov 17 17:15:29 wpa_supplicant[927]: wlp1s0: Trying to associate with f4:06:8d:df:28:98 (SSID='Goertz-HotSpot' freq=2452 MHz)
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.5552] device (wlp1s0): supplicant interface state: authenticating -> associating
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.5552] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
Nov 17 17:15:29 kernel: wlp1s0: authenticated
Nov 17 17:15:29 kernel: wlp1s0: associate with f4:06:8d:df:28:98 (try 1/3)
Nov 17 17:15:29 kernel: wlp1s0: RX AssocResp from f4:06:8d:df:28:98 (capab=0x421 status=0 aid=13)
Nov 17 17:15:29 wpa_supplicant[927]: wlp1s0: Associated with f4:06:8d:df:28:98
Nov 17 17:15:29 kernel: wlp1s0: associated
Nov 17 17:15:29 wpa_supplicant[927]: wlp1s0: CTRL-EVENT-CONNECTED - Connection to f4:06:8d:df:28:98 completed [id=0 id_str=]
Nov 17 17:15:29 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
Nov 17 17:15:29 wpa_supplicant[927]: wlp1s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.5840] device (wlp1s0): supplicant interface state: associating -> completed
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.5842] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Goertz-HotSpot"
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.5842] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> completed
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.5846] device (wlp1s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.5854] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Nov 17 17:15:29 avahi-daemon[625]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::9c45:2291:a9a3:7e0.
Nov 17 17:15:29 avahi-daemon[625]: New relevant interface wlp1s0.IPv6 for mDNS.
Nov 17 17:15:29 avahi-daemon[625]: Registering new address record for fe80::9c45:2291:a9a3:7e0 on wlp1s0.*.
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6071] dhcp4 (wlp1s0): state changed unknown -> bound, address=192.168.2.162
Nov 17 17:15:29 avahi-daemon[625]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.2.162.
Nov 17 17:15:29 avahi-daemon[625]: New relevant interface wlp1s0.IPv4 for mDNS.
Nov 17 17:15:29 avahi-daemon[625]: Registering new address record for 192.168.2.162 on wlp1s0.IPv4.
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6120] device (wlp1s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6138] device (wlp1s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6141] device (wlp1s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6147] manager: NetworkManager state is now CONNECTED_LOCAL
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6165] manager: NetworkManager state is now CONNECTED_SITE
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6171] policy: set 'XXXXX-HotSpot' (wlp1s0) as default for IPv4 routing and DNS
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6227] device (wlp1s0): Activation: successful, device activated.
Nov 17 17:15:29 NetworkManager[628]: <info> [1637165729.6939] manager: NetworkManager state is now CONNECTED_GLOBAL
Nov 17 17:15:29 wpa_supplicant[927]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-68 noise=9999 txrate=26000
Computer information:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c34ac7c8-4077-4590-9af9-92f419b4bdff rw quiet apparmor=1
security=apparmor udev.log_priority=3 acpi_backlight=vendor
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HUAWEI product: CREM-WXX9 v: M1010 serial: <filter>
Mobo: HUAWEI model: CREM-WXX9-PCB-B1 v: M1010 serial: <filter> UEFI: HUAWEI
v: 2.16 date: 09/13/2021
ID-1: BATT charge: 72.9 Wh (84.9%) condition: 85.9/83.1 Wh (103.3%)
volts: 12.4 min: 11.5 model: DYNAPACK HB9790T7ECW-32T0 type: Li-ion
serial: <filter> status: Discharging cycles: 1
RAM: total: 14.99 GiB used: 3.43 GiB (22.8%)
Array-1: capacity: 64 GiB slots: 2 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: 8 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Micron Technology part-no: 4ATF1G64HZ-3G2E1
serial: N/A
Device-2: DIMM 0 size: 8 GiB speed: 3200 MT/s type: DDR4
serial: N/A
Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB bogomips: 102245
Speed: 1681 MHz min/max: 1200/3200 MHz base/boost: 3200/4450 boost: enabled
volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz): 1: 1681 2: 3553 3: 3443
4: 1197 5: 1197 6: 1856 7: 2783 8: 1682 9: 1198 10: 1197 11: 1616 12: 2360
13: 1665 14: 3553 15: 3076 16: 3936
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean
vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Cezanne driver: amdgpu v: kernel bus-ID: 03:00.0
chip-ID: 1002:1638 class-ID: 0300
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 13d3:5476 class-ID: fe01 serial: <filter>
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2520x1680 s-dpi: 96 s-size: 666x444mm (26.2x17.5")
s-diag: 800mm (31.5")
Monitor-1: eDP res: 2520x1680 hz: 60 dpi: 189 size: 338x226mm (13.3x8.9")
diag: 407mm (16")
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio driver: snd_hda_intel v: kernel
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Local Storage: total: 476.94 GiB used: 37.83 GiB (7.9%)
model: PC SN730 SDBPNTY-512G size: 476.94 GiB block-size: physical: 512 B
rev: 11120000 temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 7 hrs cycles: 55 read-units: 636,644 [325 GB]
written-units: 655,014 [335 GB]
ID-1: / raw-size: 337.23 GiB size: 330.87 GiB (98.11%)
used: 37.79 GiB (11.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4 label: N/A uuid: c34ac7c8-4077-4590-9af9-92f419b4bdff
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 43 MiB (21.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM uuid: D098-610E
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 120 GiB fs: ntfs label: Windows
uuid: 2060991E6098FC2A
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 512 MiB fs: vfat label: WINPE
uuid: C299-D9BC
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 18 GiB fs: ntfs label: Onekey
uuid: 86E49BFDE49BEDA5
ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 1024 MiB fs: ntfs label: WinRE
uuid: 46449E02449DF541
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: IMC Networks HD Camera type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 13d3:5476
Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix Goodix Fingerprint Device
type: Communication,CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5125 class-ID: 0a00
serial: <filter>
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Processes: 359 Uptime: 17h 36m wakeups: 5301 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1334 pacman: 1326 lib: 371
flatpak: 0 snap: 8 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8
running-in: yakuake inxi: 3.3.08
I’m grateful for any help.
