Mouse logitecth anywhere 2 does not finish synchronizing
Good, because I have a mouse logitetch anywhere 2 bluetooth, which works perfectly in systemd and synchronizes instantly, however in openrc, it is impossible.
The bluetooth of my laptop works well, I can send files to the mobile and have it synchronized without problems, however when I try to synchronize the mouse, this tells me that it is synchronized ok, in fact the light of the mouse stays fixed as if it were paired, but it does not work…
I have read some cases similar to mine in arch, but without any solution on this, if I execute the command: bluetoothctl, if I open the information of the mouse, as if it was correctly synchronized, I do not understand …
The information that throws the command to me is the following one:
[NEW] Controller 00:C2:C6:F2:6F:24 BlueZ 5.45 [default]
[NEW] Device FC:29:C2:A2:83:03 MX Anywhere 2
[NEW] Primary Service
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service003f
00010000-0000-1000-8000-011f2000046d
Vendor specific
[NEW] Characteristic
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service003f/char0040
00010001-0000-1000-8000-011f2000046d
Vendor specific
[NEW] Descriptor
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service003f/char0040/desc0042
00002902-0000-1000-8000-00805f9b34fb
Client Characteristic Configuration
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service001b
0000180f-0000-1000-8000-00805f9b34fb
Battery Service
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service001b/char001c
00002a19-0000-1000-8000-00805f9b34fb
Battery Level
[NEW] Descriptor
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service001b/char001c/desc001e
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service000c
0000180a-0000-1000-8000-00805f9b34fb
Device Information
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service000c/char0019
00002a50-0000-1000-8000-00805f9b34fb
PnP ID
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service000c/char0017
00002a28-0000-1000-8000-00805f9b34fb
Software Revision String
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service000c/char0015
00002a26-0000-1000-8000-00805f9b34fb
Firmware Revision String
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service000c/char0013
00002a27-0000-1000-8000-00805f9b34fb
Hardware Revision String
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service000c/char0011
00002a25-0000-1000-8000-00805f9b34fb
Serial Number String
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service000c/char000f
00002a24-0000-1000-8000-00805f9b34fb
Model Number String
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service000c/char000d
00002a29-0000-1000-8000-00805f9b34fb
Manufacturer Name String
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service0008
00001801-0000-1000-8000-00805f9b34fb
Generic Attribute Profile
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service0008/char0009
00002a05-0000-1000-8000-00805f9b34fb
Service Changed
[NEW] Descriptor
/org/bluez/hci0/dev_FC_29_C2_A2_83_03/service0008/char0009/desc000b
Agent registered
thanks for help me
There is a “bluez-openrc” that has to be installed and added to startup with "sudo rc-update add bluetooth default"
Have you done this?
yes, bluez-openrc it is installed, and rc-status
Runlevel: default
acpid [ started ]
cronie [ started ]
dbus [ started ]
elogind [ started ]
NetworkManager [ started ]
netmount [ started ]
xdm [ started ]
bluetooth [ started ]
bumblebee [ started ]
local [ started ]
Dynamic Runlevel: hotplugged
Dynamic Runlevel: needed/wanted
xdm-setup [ started ]
modules-load [ started ]
Dynamic Runlevel: manual
I already tell you, that the bluetooth apparently works normally, including the mouse tells me it is paired, but it does not work. However in systemd without problem
