Mouse cursor randomly grows to huge scale
I’ve been experiencing a very bizarre issue for at least a month: At certain times my mouse cursor suddenly explodes in size and becomes huge for no reason, after a second of moving it around it goes back to its normal size. This seems to happen at random, typically if you move it too quickly between different windows or panels. Is the issue known and a workaround available?
KDE Plasma Version: 6.2.4
KDE Frameworks Version: 6.8.0
Qt Version: 6.8.1
Kernel Version: 6.12.4-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 3700X 8-Core Processor
Memory: 31.3 GiB of RAM
Graphics Processor: AMD Radeon RX 570 Series
If you jiggle it, it gets big? It’s a new Plasma feature I think.
KDE System Settings > Input & Output > Accessibility > Shake Cursor > Shake cursor to find it
That has to be one of the weirdest and more absurd features I’ve encountered: It actually seemed like a bug that caused the pointer to reset and not detect the resolution accordingly. I disabled it from that menu, thanks!
