frosty
13 September 2020 15:55
1
I am trying to change the mouse acceleration for my laptop trackpad. Using the command
xinput --set-prop 15 330 0.55
does what i want, but it resets after rebooting, so i tried creating a .conf file in the /etc/X11/xorg.conf.d directory following the arch wiki entry on mouse acceleration.
The content of 50-mouse-acceleration.conf is:
Section “InputClass”
Identifier “Touchpad”
MatchIsTouchpad “on”
Driver “libinput”
Option “AccelSpeed” “0.55”
EndSection
But after rebooting the mouse acceleration is reset back to the default.
Wollie
13 September 2020 16:30
2
Just in case you are using KDE Plasma as DE, open Manjaro Settings Manager, Hardware, Input Devices, Mouse and save your preferred setting there. These settings should survive a reboot.
frosty
13 September 2020 17:03
3
I am using GNOME DE, thanks anyway.
pobrn
13 September 2020 17:16
4
gnome-tweak-tools has “acceleration profiles” on the “Keyboard & Mouse” tab.
mbb
14 September 2020 21:09
5
Here’s mine of the reference:
[mbb@mbb-laptop ~]$ cat /etc/X11/xorg.conf.d/01-TackPoint-MousePad.conf
# Configuração do TrackPoint
Section "InputClass"
Identifier "mouse"
MatchProduct "PS/2 Generic Mouse"
Driver "libinput"
# Option "Device" "/dev/input/event17"
Option "AccelProfile" "flat"
Option "AccelSpeed" "1"
Option "HorizontalScrolling" "true"
Option "MiddleEmulation" "false"
Option "NaturalScrolling" "false"
Option "ScrollButton" "3"
Option "ScrollMethod" "button"
Option "SendEventsMode" "enabled"
EndSection
# Configuração do MousePad
Identifier "touchpad"
MatchProduct "SynPS/2 Synaptics TouchPad"
Driver "libinput"
# Option "Device" "/dev/input/event18"
Option "AccelSpeed" "0.9"
Option "ScrollMethod" "twofinger"
Option "Tapping" "false"
Option "DisableWhileTyping" "true"
EndSection
You can get the MatchProduct
through xinput
