I can not use the tmp folder (error messages), any other idea?
Oh câmon, help us help you.
What error messages?
The plasma said:
The file system does not respond on /tmp/sshfs-nas
Is it mounted?
mount -t fuse.sshfs
Open dolphin and configure a SFTP connection with the network wizard. That is the common way for causal users on plasma.
Yeah, but I do not see anything in that folder. I mean it looks like empty
oracle911@192.168.1.100:/mnt/rdisk on /tmp/sshfs-nas type fuse.sshfs (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000,default_permissions)
Well for me, it works. Whether on the terminal or in fstab. The problem might be /mnt/rdisk which indicates that a partition is mounted on the ubuntu server there. Is it mounted? Are the permissions set correctly?
oracle911@nas-video:/mnt/rdisk$ ls -l
total 112560
-rwxrwxrwx 1 oracle911 rodina 115173240 Mar 25 2021 Theta+Guardian+Node-2.2.4.AppImage
-rw-r--r-- 1 oracle911 oracle911 61399 Jan 25 11:51 UMS.conf
drwxrwxrwx 2 root root 16384 Jul 29 2020 lost+found
drwxrwx--- 10 oracle911 oracle911 4096 Feb 16 22:12 private
drwxrwxrwx 6 nobody nogroup 4096 Aug 16 2020 rodina
Edit: Maybe I found it:
oracle911@nas-video:/mnt$ ls -l
total 4
drw-rw-rwx 6 root root 4096 Jan 25 11:51 rdisk
No, other has rwx, so no issue.
What i use in cases ssh is already working:
mc
mc is able to connect via ssh
(and then shows the extern storage as if it was local)
If ssh already works, you do not need to configure anything wit mc. It will work out of the box.
rsync
if i have to copy lots of files i use rsync instead
because it is possible to resume a broken transfer where it was interrupted
MC, what is that?
A very versatile file manager that works everywhere where you have a console or a terminal - not just in the GUI.
I could not want to live without it, use it constantly.
OH, that thanks
Edit: I donât want install another application. So we are back few stepsâŚ
Edit2: On the (now defunct) old forum I asked the similar question and was answeredâŚ
PuTTY allow to establish SSH connection to access the remote server securely. You can perform function on the server through command line interface.
