Mounting lvm as /home
Hi all,
I switched from running an Ubuntu derivative to running Manjaro. I have an LVM created under Ubuntu called /dev/myhome/home what is the proper way to mount this as /home ?
Thanks! Kat
Use lvscan to scan your drive for logical volumes, and then add the proper volume designation to /etc/fstab.
Welcome to the forum, by the way. :wink:
AFAIK lvm is already active on installations and should have picked up your lv’s. Check with:
$ sudo lvs
