'mount -t cifs' doesn't work...
Hi guys,
I'm trying to mount a Windows share with 'mount - cifs' but I get 'command not found'. cifs-utils are installed and I am able to connect to this share with Dolphin.
Can't find out what is wrong. Please help...
terminal output is below...
p.s. obviously I use correct credentials....
[dima@dima-pc ~]$ sudo mount -t cifs //192.168.1.39/Music /mnt/BBMusic -o user=username,password=pass
[3] 1949
bash: 9: command not found
Is it maybe something in your password that is being parsed oddly on the command line?
To test, exclude the password option and it should ask for your password interactively.
Thank you very much. It worked!
It seems the problem is in & symbol. Have to change the password...
Actually no: you just have to properly quote or escape it to prevent bash interpreting:
[dima@dima-pc ~]$ sudo mount -t cifs //192.168.1.39/Music /mnt/BBMusic -o 'user=username,password=pass'
Note the single quotes around that option string.
Thank you very much!
You can also store your username and password in a file that you can later reference by the credentials parameter. I’ve previously found that this can contain characters that can’t be parsed without the use of quotes when trying to execute mount.cifs via your shell.
