Mount iso on Manjaro-Arm?
#1
Hello, I wanted to know how to mount an ISO on Manjaro, specifically for the ARM (using v 19 on rock64)
currently tried
(sudo) mount -o loop ‘file.iso’ /media/disk throws up
mount: /media/disk: unknown filesystem type ‘udf’.
and
ofit ?? shows unknown command
FuseISO after installation and typing in
(sudo) fuseiso -p file.iso /media/disk
causes cpu to hit 100% on one of the cores and so far hasn’t done anything
#2
Don’t mount it with loop.
It should be mauntable with:
sudo mount -t iso9660 file.iso /media/disk
#3
hello thanks for the reply,
I tried the above and got
'mount: /media/disk: unknown filesystem type ‘iso9660’
is it something to do with kernel module not being present? thanks
#4
install open-fuse-iso
and right click on iso file then in open with mount/unmount iso
or you can install gnome disk utility to mount iso
#5
Apologies, didn’t mention I’m using minimal for arm, that package is not in the repository from a pacman -Ss search
Search Results
extra/ fuse-common 3.4.1-1 [installed]
Common files for fuse2/3 packages
extra/ fuse2 2.9.9-1 [installed]
A library that makes it possible to implement a filesystem in a userspace program.
extra/ fuse3 3.4.1-1 [installed]
extra/ python-defusedxml 0.5.0-2
XML bomb protection for Python stdlib modules
extra/ python2-defusedxml 0.5.0-2
extra/ squashfuse 0.1.103-2
FUSE filesystem to mount squashfs archives
community/ benzene 20130630-1
A program for the efficient generation of all nonisomorphic fusenes and benzenoids with a given number of faces
community/ btfs 2.18-5
A bittorrent filesystem based on FUSE
community/ confuse 3.2.2-1
C-library for parsing configuration files
community/ cromfs 1.5.10.2-3
Compressed read-only filesystem based on FUSE
community/ curlftpfs 0.9.2-7
A filesystem for acessing FTP hosts based on FUSE and libcurl.
community/ diffuse 0.4.8-3
A graphical tool for merging and comparing text files
community/ disorderfs 0.5.5-1
FUSE filesystem that introduces non-determinism
community/ enblend-enfuse 4.2-4
Intelligent blend tool for overlapping picture
community/ exfat-utils 1.3.0-1 [installed]
Utilities for exFAT file system
community/ fuseiso 20070708-7 [installed]
FUSE module to mount ISO filesystem images
community/ hubicfuse 3.0.1-3
A fuse filesystem to access HubiC cloud storage
community/ ifuse 1.1.3-5
A fuse filesystem to access the contents of an iPhone or iPod Touch
community/ lxcfs 3.0.3-1
FUSE filesystem for LXC
community/ mtpfs 1.1-3
A FUSE filesystem that supports reading and writing from any MTP device
community/ perl-fuse 0.16.1-8
write filesystems in Perl using FUSE
community/ python-fuse 0.3.1-1
Python bindings for FUSE
community/ python-llfuse 1.3.5-1
A set of Python bindings for the low level FUSE API.
community/ python2-fuse 0.3.1-1
community/ python2-llfuse 1.3.5-1
community/ s3fs-fuse 1.84-1
FUSE-based file system backed by Amazon S3
community/ sshfs 3.5.1-1
FUSE client based on the SSH File Transfer Protocol
community/ unionfs-fuse 2.0-2
A user space unionfs implementation
Anything I can do to help let me know
#6
What kind of .iso is it?
An OS iso, DVD movie, Data CD/DVD?
#7
blu-ray movie iso
#8
Can’t help with that. Don’t know how they are set up.
Mounting ISO’s on ARM does not seem to make much sense to me either.
#9
Did you tried
sudo mount -t udf  file.iso /media/disk
It should not be necessary, but you can do at first
sudo modprobe udf
#10
Can’t you mount the disk with your GUI file manager of choice?
Is it an ISO that you created yourself?
Else try what xabbu suggested, I also think that BR are in UDF format.
#11
It should be supported in the kernel at least:
Unless Arch specifically disables it.
#12
$ zgrep -i udf /proc/config.gz
#13
Result on Pinebook at least:
CONFIG_UDF_FS=m
So should be there as a module.
#14
in rock64 it is
CONFIG_UDF_FS is not set
uname -a
Linux rock64 4.19.0-1.2-MANJARO-ARM #1 SMP PREEMPT Tue Jan 22 17:48:59 UTC 2019 aarch64 GNU/Linux
modprobe udf
Module udf not found in directory /lib/modules/4.19.0-1.2-MANJARO-ARM
#15
Yeah. The rock64 kernel is a little weird. For starters, it says it has no modules at all.
I haven’t had much time to look into it.
The kernel was a debian kernel that I frankensteined into building on our end.
I’m not a kernel developer, so I don’t know what needs to be done to fix it.
