The system is working fine on my machine, but I would like to know how to install the latest drivers for my video card (even if it is proprietary)
In this window, I noticed that there are 2 checkboxes (source open / installed)
In my case, only “video-linux” has the two boxes selected, the other two options “video-modesetting” and “video-table” have only the first box selected
I would like to know what is the difference between these selected boxes and the difference between these options, and most importantly for me, how do I install the best driver for my video card (my intention is to make my games run at the highest possible FPS and with the greatest stability )
All the listed drivers are open source, there are no proprietary Intel drivers. You already have the latest driver installed (video-linux) included in the kernel. If you run inxi -G you should see the driver listed as i915, that’s the Intel kernel module.
By default it uses the open source 8169 driver for the network card, but you can install the proprietary 8168 driver from Realtek if you want, but if you have no network issue don’t install it.
But yeah your information are weird… you show Intel then AMD, that’s weird. What are you doing?
