More general questions
Question 1: I have the nvidia 1050ti, does anyone know the exact drivers or what to download? I tried installing some NVIDIA download from Add/Remove packages but when I try and run Nvidia X Server Settings nothing happens
Question 2: How do I download things that arent on add/remove software? google for example
Output to inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=4dabba46-d73a-4342-96f5-859c2418cd86 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
  Type: Desktop System: Gigabyte product: B460MDS3H v: N/A serial: <filter>
  Mobo: Gigabyte model: B460M DS3H v: x.x serial: <filter>
  UEFI: American Megatrends v: F3 date: 05/27/2020
  RAM: total: 15.56 GiB used: 2.19 GiB (14.1%)
  Info: 6-Core model: Intel Core i5-10500 bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 3 microcode: EA
  cache: L2: 12 MiB bogomips: 74427
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 1178
  3: 835 4: 3106 5: 1997 6: 1046 7: 800 8: 800 9: 1140 10: 4394 11: 4175
  12: 3473
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss
  ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
  driver: nouveau v: kernel alternate: nvidia_drm,nvidia bus-ID: 01:00.0
  chip-ID: 10de:1c82 class-ID: 0300
  Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
  loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
  diag: 598mm (23.5")
  OpenGL: renderer: NV137 v: 4.3 Mesa 21.2.1 direct render: Yes
  Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
  alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a3f0
  class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
  class-ID: 0403
  Device-3: Corsair CORSAIR HS60 HAPTIC Gaming Headset type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:5 chip-ID: 1b1c:0a5f
  class-ID: 0300
  Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: no
  vendor: Gigabyte driver: r8169 v: kernel port: 4000 bus-ID: 03:00.0
  Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
  v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:818b class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Local Storage: total: 1.02 TiB used: 12.63 GiB (1.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS31120GNTD
  size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 61.3 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
  type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
  ID-1: / raw-size: 111.49 GiB size: 109.18 GiB (97.93%)
  used: 12.63 GiB (11.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 4dabba46-d73a-4342-96f5-859c2418cd86
  used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: 4D27-D28D
  ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: DATA
  uuid: 0C0E8D9D0E8D8086
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-3.1:4 info: SINOWEALTH Wired Gaming Mouse type: Mouse,Keyboard
  driver: glorious,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 480mA
  chip-ID: 258a:0036 class-ID: 0301
  Device-2: 1-3.2:6 info: Holtek USB Keyboard type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
  power: 100mA chip-ID: 04d9:a01b class-ID: 0300
  Device-3: 1-3.3:9 info: SHARKOON Mechanical Keyboard type: Keyboard
  power: 500mA chip-ID: 1ea7:0077 class-ID: 0301
  Hub-3: 1-4:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-4.3:7 info: Micro Star MSI Gaming Controller type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 1462:3fa4 class-ID: 0300 serial: <filter>
  Device-2: 1-6:5 info: Corsair CORSAIR HS60 HAPTIC Gaming Headset
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
  rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 1b1c:0a5f class-ID: 0300
  Hub-4: 1-9:8 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
  Hub-6: 2-3:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
  chip-ID: 05e3:0612 class-ID: 0900
  System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nouveau temp: 36.0 C
  Processes: 270 Uptime: 10m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1069 lib: 303 flatpak: 0 Shell: Bash
  v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
It is recommended to use mhwd (Manjaro HardWare Detection) for handling drivers, which has a GUI in Manjaro Settings Manager.
For Nvidia GPUs, proprietary drivers are usually recommended.
By default, pamac only looks for packages in Manjaro’s repositories.
You can enable access to AUR, Snap, Flatpak repositories from its settings. But do note those are not maintained by Manjaro.
Otherwise, it is still possible to download and install applications downloaded from the Internet – read their installation manuals on how. But do know that doing so is definitely not recommended, mostly for security sake, and that you should always prefer install packages from the repositories.
Okay, i’ve been trying to use run mhwd but nothing shows up, just like when running the nvidia thing
