Earlier this morning everything was working fine, then I left my computer idle for a few hours and when I came back my main display (DisplayPort) wasn’t working anymore. Luckily my second monitor (VGA with a HDMI adapter) is still working, then I started troubleshooting it and I noticed that they work at login screen, tty and even with another user. The problem is that I wasted a lot of time setting up my theme and development environment and lose it all everytime I left my computer turned on or Manjaro crashes would be really frustrating. I wanna know if I can fix it using my current user or easily export everything to another user.
After the bug, everytime I login at my current user, I receive this message:
Graphics Reset | A graphics reset event occurred
Xwayland Crash | Xwayland has crashed
Compositing has been suspendend | Another application has requested to suspend compositing.
inxi --admin --verbosity=7 --filter --width ✔
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f5d12cd7-1a1c-467f-95d6-ab39ba1e0bd2 rw quiet apparmor=1
security=apparmor resume=UUID=b0a123a1-898d-4f96-bd59-ad01f482e1b6
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop System: Gigabyte product: N/A v: N/A serial: <filter> Chassis:
type: 3 serial: <filter>
Mobo: Gigabyte model: 990FXA-UD3 serial: <filter> UEFI: American Megatrends
v: FC date: 02/05/2013
RAM: total: 15.59 GiB used: 2.28 GiB (14.6%)
Info: 6-Core model: AMD FX-6300 bits: 64 type: MCP arch: Bulldozer
family: 15 (21) model-id: 2 stepping: 0 microcode: 6000852 cache: L2: 2 MiB
bogomips: 42204
Speed: 1405 MHz min/max: 1400/3500 MHz boost: enabled Core speeds (MHz):
1: 1405 2: 1676 3: 1406 4: 1406 5: 1406 6: 1405
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht hw_pstate
ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor msr mtrr
nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm
svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean vme vmmcall wdt
xop xsave
disabled, RSB filling
Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 422x237mm (16.6x9.3")
s-diag: 484mm (19.1")
Monitor-1: DVI-D-0 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8")
diag: 508mm (20")
OpenGL: rende
rer: AMD Radeon RX 460 Graphics (POLARIS11 DRM 3.41.0
5.13.19-2-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aae0 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: b000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.5 TiB used: 13.89 GiB (0.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0102 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MQ01ABD050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 2J scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Blade
size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH22NS70 rev: EX00
dev-links: cdrom
ID-1: / raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 11.61 GiB (19.8%)
fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: f5d12cd7-1a1c-467f-95d6-ab39ba1e0bd2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: NO_LABEL
uuid: 93A2-6DD0
ID-3: /home raw-size: 385.25 GiB size: 378.14 GiB (98.15%)
used: 2.27 GiB (0.6%) fs: ext4 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 7387d0e4-61e5-4d9c-ab74-8eb187022e4b
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: partition size: 20.01 GiB used: 0 KiB (0.0%) priority: -3
dev: /dev/sdc4 maj-min: 8:36 label: N/A
uuid: b0a123a1-898d-4f96-bd59-ad01f482e1b6
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 30FA-F0CE
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 222.96 GiB fs: ntfs label: N/A
uuid: D626082A26080DE5
ID-4: /dev/sda4 maj-min: 8:4 size: 508 MiB fs: ntfs label: N/A
uuid: 20CEF77ACEF74696
ID-5: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: N/A
uuid: 1C6EBBEC6EBBBD38
ID-6: /dev/sdd1 maj-min: 8:49 size: 3.24 GiB fs: iso9660
ID-7: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C5CD-B119
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 1.1 speed: 12 Mb/s
Device-1: 7-2:2 info: Dell Keyboard and mouse dongle
type: Keyboard,HID,Mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 413c:2501 class-ID: 0301
Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 8-1:2 info: Logitech G402 Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Hub-9: 9-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-10: 10-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-11: 11-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 37.0 C mobo: 34.0 C gpu: amdgpu temp: 47.0 C
Fan Speeds (RPM): cpu: 872 fan-1: 2129 fan-3: 0 fan-4: 1101 fan-5: 0
gpu: amdgpu fan: 186
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.19 gpu: amdgpu watts: 9.06
Processes: 259 Uptime: 36m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1290 lib: 340
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.08
So what should I do?
