Thank you so much for the help!
Switching to a new user did bring back my monitor (just for that account)! It also may have fixed a wifi issue I was having (every time I login, it asks for the wifi password… it was also always asking for the kde wallet password everytime until I just turned that off). A new user account also did not include a notification about “another application using the compositor” or whatever.
Interestingly, signing back into my main account from the login screen made my whole screen freeze, so I had to hard restart my computer.
Once I got back into my main account everything reverted back (including the monitor not working again). I hope that narrows it down.
Looks like you don’t need xrandr --verbose, but I’ll paste it below just in case!
Screen 0: minimum 8 x 8, current 1680 x 1050, maximum 32767 x 32767
eDP1 connected primary 1680x1050+0+0 (0x183) normal (normal left inverted right x axis y axis) 290mm x 180mm
Identifier: 0x43
Timestamp: 228050
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff004d10cb1400000000
2d1d0104a51d12780ede50a3544c9926
0f505400000001010101010101010101
010101010101283c80a070b023403020
360020b410000018203080a070b02340
3020360020b410000018000000fe0058
47464a30804c513133344e3100000000
0002410332001200000a010a202000c0
BACKLIGHT: 46081
range: (0, 96000)
Backlight: 46081
range: (0, 96000)
scaling mode: Full aspect
supported: Full, Center, Full aspect
Colorspace: Default
supported: Default, RGB_Wide_Gamut_Fixed_Point, RGB_Wide_Gamut_Floating_Point, opRGB, DCI-P3_RGB_D65, BT2020_RGB, BT601_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, BT2020_CYCC, BT2020_YCC
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
panel orientation: Normal
supported: Normal, Upside Down, Left Side Up, Right Side Up
link-status: Good
supported: Good, Bad
non-desktop: 0
range: (0, 1)
1920x1200 (0x4d) 154.000MHz -HSync -VSync +preferred
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 74.04KHz
v: height 1200 start 1203 end 1209 total 1235 clock 59.95Hz
1920x1200 (0x180) 154.000MHz +HSync -VSync
1920x1200 (0x181) 123.200MHz -HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 59.23KHz
v: height 1200 start 1203 end 1209 total 1235 clock 47.96Hz
1920x1080 (0x182) 138.500MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.59KHz
v: height 1080 start 1083 end 1088 total 1111 clock 59.93Hz
1680x1050 (0x183) 147.136MHz -HSync +VSync *current
h: width 1680 start 1784 end 1968 total 2256 skew 0 clock 65.22KHz
v: height 1050 start 1051 end 1054 total 1087 clock 60.00Hz
1680x1050 (0x184) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1680x1050 (0x185) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1400x1050 (0x186) 122.000MHz +HSync +VSync
h: width 1400 start 1488 end 1640 total 1880 skew 0 clock 64.89KHz
v: height 1050 start 1052 end 1064 total 1082 clock 59.98Hz
1600x900 (0x187) 118.250MHz -HSync +VSync
h: width 1600 start 1696 end 1856 total 2112 skew 0 clock 55.99KHz
v: height 900 start 903 end 908 total 934 clock 59.95Hz
1600x900 (0x188) 97.500MHz +HSync -VSync
h: width 1600 start 1648 end 1680 total 1760 skew 0 clock 55.40KHz
v: height 900 start 903 end 908 total 926 clock 59.82Hz
1280x1024 (0x189) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1400x900 (0x18a) 104.234MHz -HSync +VSync
h: width 1400 start 1480 end 1632 total 1864 skew 0 clock 55.92KHz
v: height 900 start 901 end 904 total 932 clock 60.00Hz
1400x900 (0x18b) 103.500MHz -HSync +VSync
h: width 1400 start 1480 end 1624 total 1848 skew 0 clock 56.01KHz
v: height 900 start 903 end 913 total 934 clock 59.96Hz
1400x900 (0x18c) 86.500MHz +HSync -VSync
h: width 1400 start 1448 end 1480 total 1560 skew 0 clock 55.45KHz
v: height 900 start 903 end 913 total 926 clock 59.88Hz
1280x960 (0x18d) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1368x768 (0x18e) 85.250MHz -HSync +VSync
h: width 1368 start 1440 end 1576 total 1784 skew 0 clock 47.79KHz
v: height 768 start 771 end 781 total 798 clock 59.88Hz
1368x768 (0x18f) 72.250MHz +HSync -VSync
h: width 1368 start 1416 end 1448 total 1528 skew 0 clock 47.28KHz
v: height 768 start 771 end 781 total 790 clock 59.85Hz
1280x800 (0x190) 83.500MHz -HSync +VSync
h: width 1280 start 1352 end 1480 total 1680 skew 0 clock 49.70KHz
v: height 800 start 803 end 809 total 831 clock 59.81Hz
1280x800 (0x191) 83.462MHz -HSync +VSync
h: width 1280 start 1344 end 1480 total 1680 skew 0 clock 49.68KHz
v: height 800 start 801 end 804 total 828 clock 60.00Hz
1280x800 (0x192) 71.000MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 49.31KHz
v: height 800 start 803 end 809 total 823 clock 59.91Hz
1280x720 (0x193) 74.500MHz -HSync +VSync
h: width 1280 start 1344 end 1472 total 1664 skew 0 clock 44.77KHz
v: height 720 start 723 end 728 total 748 clock 59.86Hz
1280x720 (0x194) 63.750MHz +HSync -VSync
h: width 1280 start 1328 end 1360 total 1440 skew 0 clock 44.27KHz
v: height 720 start 723 end 728 total 741 clock 59.74Hz
1024x768 (0x195) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
1024x576 (0x196) 46.500MHz -HSync +VSync
h: width 1024 start 1064 end 1160 total 1296 skew 0 clock 35.88KHz
v: height 576 start 579 end 584 total 599 clock 59.90Hz
1024x576 (0x197) 42.000MHz +HSync -VSync
h: width 1024 start 1072 end 1104 total 1184 skew 0 clock 35.47KHz
v: height 576 start 579 end 584 total 593 clock 59.82Hz
960x600 (0x198) 45.978MHz -HSync +VSync
h: width 960 start 1000 end 1096 total 1232 skew 0 clock 37.32KHz
v: height 600 start 601 end 604 total 622 clock 60.00Hz
960x540 (0x199) 40.750MHz -HSync +VSync
h: width 960 start 992 end 1088 total 1216 skew 0 clock 33.51KHz
v: height 540 start 543 end 548 total 562 clock 59.63Hz
960x540 (0x19a) 37.250MHz +HSync -VSync
h: width 960 start 1008 end 1040 total 1120 skew 0 clock 33.26KHz
v: height 540 start 543 end 548 total 556 clock 59.82Hz
800x600 (0x19b) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x19c) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
864x486 (0x19d) 32.500MHz -HSync +VSync
h: width 864 start 888 end 968 total 1072 skew 0 clock 30.32KHz
v: height 486 start 489 end 494 total 506 clock 59.92Hz
864x486 (0x19e) 30.500MHz +HSync -VSync
h: width 864 start 912 end 944 total 1024 skew 0 clock 29.79KHz
v: height 486 start 489 end 494 total 500 clock 59.57Hz
640x480 (0x19f) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x405 (0x1a0) 22.500MHz -HSync +VSync
h: width 720 start 744 end 808 total 896 skew 0 clock 25.11KHz
v: height 405 start 408 end 413 total 422 clock 59.51Hz
720x405 (0x1a1) 21.750MHz +HSync -VSync
h: width 720 start 768 end 800 total 880 skew 0 clock 24.72KHz
v: height 405 start 408 end 413 total 419 clock 58.99Hz
640x360 (0x1a2) 18.000MHz -HSync +VSync
h: width 640 start 664 end 720 total 800 skew 0 clock 22.50KHz
v: height 360 start 363 end 368 total 376 clock 59.84Hz
640x360 (0x1a3) 17.750MHz +HSync -VSync
h: width 640 start 688 end 720 total 800 skew 0 clock 22.19KHz
v: height 360 start 363 end 368 total 374 clock 59.32Hz
DP1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x44
Timestamp: 228050
Subpixel: unknown
Clones:
CRTCs: 0 1 2
filter:
HDCP Content Type: HDCP Type0
supported: HDCP Type0, HDCP Type1
Content Protection: Undesired
supported: Undesired, Desired, Enabled
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
supported: force-dvi, off, auto, on
link-status: Good
non-desktop: 0
range: (0, 1)
DP2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x45
Timestamp: 228050
Subpixel: unknown
Clones:
CRTCs: 0 1 2
filter:
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
DP3 disconnected (normal left inverted right x axis y axis)
Identifier: 0x46
Timestamp: 228050
Subpixel: unknown
Clones:
CRTCs: 0 1 2
filter:
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
link-status: Bad
non-desktop: 0
range: (0, 1)
DP3-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x47
Timestamp: 228050
Subpixel: unknown
Clones: DP3-2 DP3-3
CRTCs: 0 1 2
filter:
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
DP3-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x48
Timestamp: 228050
Subpixel: unknown
Clones: DP3-1 DP3-3
CRTCs: 0 1 2
filter:
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
DP3-3 connected (normal left inverted right x axis y axis)
Identifier: 0x49
Timestamp: 228050
Subpixel: unknown
Clones: DP3-1 DP3-2
CRTCs: 0 1 2
filter:
EDID:
00ffffffffffff00593a051001010101
0018010380341d782a2ac5a4564f9e28
0f5054a5ce0001010101010101010101
010101010101023a801871382d40582c
450009252100001e6419004041002630
18883600092521000018000000fc0045
323431692d42310a20202020000000fd
00384c1f500f000a20202020202001b1
02032671490504900203070601202609
0707150750830100006c030c00100000
1ec001010101023a801871382d40582c
450009252100001e011d007251d01e20
6e28550009252100001e8c0ad08a20e0
2d10103e96008725110000188c0aa014
51f01600267c43000925210000980000
000000000000000000000000000000fb
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
1920x1080 (0x4e) 148.500MHz +HSync +VSync +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x1a4) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080 (0x1a5) 74.250MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 27.00KHz
v: height 1080 start 1084 end 1089 total 1125 clock 24.00Hz
1920x1080 (0x1a6) 74.176MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
1280x720 (0x1a7) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x1a8) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x1a9) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x1aa) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
800x600 (0x1ab) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x1ac) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
720x480 (0x1ad) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x1ae) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x1af) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x1b0) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
720x400 (0x1b1) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
DP4 disconnected (normal left inverted right x axis y axis)
Identifier: 0x4a
Timestamp: 228050
Subpixel: unknown
Clones:
CRTCs: 0 1 2
filter:
Colorspace: Default
max bpc: 12
range: (6, 12)
audio: auto
link-status: Good
non-desktop: 0
range: (0, 1)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x4b
Timestamp: 228050
Subpixel: no subpixels
Clones:
CRTCs: 3
filter:
non-desktop: 0
supported: 0, 1
