Xerox WorkCentre 3025. Problem with scanner
Hi all,
I have a Xerox WorkCentre 3025 in my home network connected by WiFi. I installed Xerox WorkCentre 3025 printer driver for CUPS and it works fine.
But, I cannot connect scanner via network.
The scanimage -L returns the integrated web cam only.
There is my /etc/sane.d/dll.conf file:
# dll.conf - Configuration file for the SANE dynamic backend loader
# Backends can also be enabled by configuration snippets under the dll.d/
# directory -- third party backends can drop their configuration file in
# this in this directory, named after the backend.
# The next line enables the network backend; comment it out if you don't
# need to use a remote SANE scanner over the network -- see sane-net(5)
# and saned(8) for details.
net
xerox_mfp
And I added to the end of the /etc/sane.d/xerox_mfp.conf the following string
network
tcp 192.168.0.109 9100
Thank you
Hello,
I gather you installed http://aur.archlinux.org/packages/cups-xerox-workcentre-3025
but you might also have to do some of the steps described here Solved: Re: Xerox Workcentre 3225 : scanner xerox driver d... - Customer Support Forum
Thank you, Bogdan
I have installed cups-xerox-workcentre-3025 ver. 1.0.25-3.
Unfortunately Ubuntu recipes do not work for Manjaro.
When I changed port from 9100 to 9400 scanimage -L returns my scanner
device ``xerox_mfp:tcp 192.168.0.109 9400' is a Xerox WorkCentre 3025 multi-function peripheral
But scanimage -T --device-name 'xerox_mfp:tcp 192.168.0.109 9400'
fails with error
Not a JPEG file: starts with 0x00 0x00
but the linked article keeps the 9100 port …
but regardless
is an issue i did not see for 2 years and was related to SANE backend … How did you installed sane and is you system updated.
i know the tutorial is for ubuntu, but you take only what is useful; otherwise disregard.
Bogdan thank you again
I have resolved this problem.
I just installed the sane-airscan backend from the official repository (extra).
scanimage -L
device `airscan:w1:Xerox WorkCentre 3025 (XRX9C934E41B807)' is a WSD Xerox WorkCentre 3025 (XRX9C934E41B807) ip=192.168.0.109, 192.168.3.1
