Monitor only shows very low and improper resolution
When installing manjaro, both of my top monitors show their proper resolution and refresh rate but my bottom main monitor will only show 480p. This monitor is supposed to be in 1440p @ 144hz. My GPU is the RX 6900XT, a relatively new card that might cause this. I have installed manjaro before with this same monitor using my GTX 1080 and didn’t have any issues with this. Was hoping I can find out what I could do to fix this issue so I could fully transition to manjaro as my main OS.
Much thanks to any help. Here is the output of the inxi command.
  Kernel: 5.11.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=74596f23-932f-41fa-9eb6-72d5cca2dd9d ro quiet apparmor=1
  Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
  Mobo: ASUSTeK model: ROG STRIX Z390-E GAMING v: Rev 1.xx serial: <filter>
  UEFI: American Megatrends v: 1802 date: 12/01/2020
  RAM: total: 62.73 GiB used: 2.62 GiB (4.2%)
  Info: 8-Core model: Intel Core i7-9700K bits: 64 type: MCP arch: Kaby Lake
  note: check family: 6 model-id: 9E (158) stepping: C (12) microcode: DE
  L2 cache: 12 MiB bogomips: 57616
  Speed: 800 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp
  hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep
  smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
  v: kernel bus ID: 03:00.0 chip ID: 1002:73bf class ID: 0300
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1560 s-dpi: 96 s-size: 1016x412mm (40.0x16.2")
  s-diag: 1096mm (43.2")
  Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8")
  diag: 609mm (24")
  Monitor-2: DisplayPort-1 res: 640x480 hz: 60
  Monitor-3: HDMI-A-0 res: 1920x1080 dpi: 93 size: 527x296mm (20.7x11.7")
  diag: 604mm (23.8")
  OpenGL:
  renderer: AMD SIENNA_CICHLID (DRM 3.40.0 5.11.1-1-MANJARO LLVM 11.1.0)
  v: 4.6 Mesa 20.3.4 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
  chip ID: 8086:a348 class ID: 0403
  Device-2: AMD driver: snd_hda_intel v: kernel bus ID: 03:00.1
  chip ID: 1002:ab28 class ID: 0403
  Device-3: Logitech HD Pro Webcam C920 type: USB
  driver: snd-usb-audio,uvcvideo bus ID: 1-9.2:11 chip ID: 046d:082d
  class ID: 0102 serial: <filter>
  Device-4: Focusrite-Novation Scarlett Solo (3rd Gen.) type: USB
  driver: snd-usb-audio bus ID: 1-1:2 chip ID: 1235:8211 class ID: 0102
  serial: <filter>
  Device-5: Valve Valve VR Radio type: USB driver: cdc_acm,hid-generic,usbhid
  bus ID: 1-10.3.3:19 chip ID: 28de:2102 class ID: 0102 serial: <filter>
  Device-6: Valve Valve VR Radio & HMD Mic type: USB
  driver: hid-generic,snd-usb-audio,usbhid
  Sound Server: ALSA v: k5.11.1-1-MANJARO
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
  bus ID: 00:14.3 chip ID: 8086:a370 class ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
  port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc class ID: 0200
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus ID: 1-14:16 chip ID: 8087:0aaa class ID: e001
  Message: Required tool hciconfig not installed. Check --recommends
  Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4020
  bus ID: 00:17.0 chip ID: 8086.2822 rev: 10
  Local Storage: total: 2.83 TiB used: 8.93 GiB (0.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BP240G4
  size: 223.57 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 0410 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 EVO 250GB
  size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  rotation: SSD serial: <filter> rev: BB0Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
  size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 3B6Q scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
  size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: 0001 scheme: GPT
  ID-5: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: Ultra USB 3.0
  size: 114.56 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1.00 scheme: MBR
  ID-1: / raw size: 223.27 GiB size: 218.77 GiB (97.98%) used: 8.93 GiB (4.1%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 74596f23-932f-41fa-9eb6-72d5cca2dd9d
  ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 0045-89F8
  ID-1: /dev/sdb1 maj-min: 8:17 size: 232.88 GiB fs: ntfs label: SSD 1
  uuid: 38EEEF26EEEEDB60
  ID-2: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-3: /dev/sdc2 maj-min: 8:34 size: 465.75 GiB fs: ntfs label: SSD 2
  uuid: AEB2BC1EB2BBE8CB
  ID-4: /dev/sdd1 maj-min: 8:49 size: 1024 KiB fs: <superuser required>
  ID-5: /dev/sdd2 maj-min: 8:50 size: 15 MiB fs: <superuser required>
  ID-6: /dev/sdd3 maj-min: 8:51 size: 1.53 TiB fs: ntfs label: Storage
  uuid: 4C0E96FD0E96DEF0
  ID-7: /dev/sdd4 maj-min: 8:52 size: 3.91 GiB fs: swap label: N/A
  uuid: 92a84f44-0a0d-4252-ab06-0e7310f7123e
  ID-8: /dev/sdd5 maj-min: 8:53 size: 512 MiB fs: ext4 label: N/A
  uuid: de7db975-2e56-45ac-8e2c-b81ba5ee9cc1
  ID-9: /dev/sde1 maj-min: 8:65 size: 3 GiB fs: iso9660
  label: MANJARO_KDE_2021 uuid: 2021-01-03-09-07-36-00
  ID-10: /dev/sde2 maj-min: 8:66 size: 4 MiB fs: vfat label: MISO_EFI
  uuid: 7B2D-7571
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
  Device-1: 1-1:2 info: Focusrite-Novation Scarlett Solo (3rd Gen.)
  type: Audio driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s
  chip ID: 1235:8211 class ID: 0102 serial: <filter>
  Device-2: 1-2:3 info: Cyber Power System CP1500 AVR UPS type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  chip ID: 0764:0501 class ID: 0300 serial: <filter>
  Hub-2: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  chip ID: 05e3:0610 class ID: 0900
  Device-1: 1-6.3:6 info: SINOWEALTH Wired Gaming Mouse type: Mouse,Keyboard
  driver: glorious,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
  chip ID: 258a:0033 class ID: 0301
  Device-2: 1-6.4:9 info: ASUSTek AURA MOTHERBOARD type: HID
  chip ID: 0b05:18a3 class ID: 0300 serial: <filter>
  Hub-3: 1-8:5 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 1-8.1:8 info: Valve Watchman Dongle type: HID
  chip ID: 28de:2101 class ID: 0300 serial: <filter>
  Device-2: 1-8.3:12 info: Valve Watchman Dongle type: HID
  Device-3: 1-8.4:15 info: Valve Watchman Dongle type: HID
  Hub-4: 1-9:7 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
  Device-1: 1-9.2:11 info: Logitech HD Pro Webcam C920 type: Video,Audio
  chip ID: 046d:082d class ID: 0102 serial: <filter>
  Hub-5: 1-10:10 info: Valve ports: 3 rev: 2.0 speed: 480 Mb/s
  chip ID: 28de:2613 class ID: 0900
  Hub-6: 1-10.3:14 info: Microchip (formerly SMSC) Hub ports: 5 rev: 2.1
  speed: 480 Mb/s chip ID: 0424:2744 class ID: 0900
  Device-1: 1-10.3.1:17 info: Valve Index HMD type: HID
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  chip ID: 28de:2300 class ID: 0300 serial: <filter>
  Device-2: 1-10.3.2:18 info: Valve Valve VR Radio
  type: HID,Abstract (modem),CDC-Data driver: cdc_acm,hid-generic,usbhid
  interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 28de:2102 class ID: 0a00
  serial: <filter>
  Device-3: 1-10.3.3:19 info: Valve Valve VR Radio & HMD Mic type: HID,Audio
  driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s chip ID: 28de:2102 class ID: 0102 serial: <filter>
  Device-4: 1-10.3.5:20 info: Microchip (formerly SMSC) Hub Controller
  type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
  chip ID: 0424:2740 class ID: 0000
  Device-5: 1-13:13 info: qmkbuilder KBD75 type: Keyboard,HID
  driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
  chip ID: 4b42:6061 class ID: 0300
  Device-6: 1-14:16 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  Hub-7: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
  speed: 10 Gb/s chip ID: 1d6b:0003 class ID: 0900
  Device-1: 2-7:2 info: SanDisk Ultra USB 3.0 type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s chip ID: 0781:5595
  class ID: 0806 serial: <filter>
  Hub-8: 2-8:3 info: Genesys Logic USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
  chip ID: 05e3:0626 class ID: 0900
  Hub-9: 2-9:4 info: Genesys Logic Hub ports: 3 rev: 3.0 speed: 5 Gb/s
  chip ID: 05e3:0612 class ID: 0900
  Hub-10: 2-10:5 info: Microchip (formerly SMSC) Hub ports: 4 rev: 3.2
  speed: 5 Gb/s chip ID: 0424:5744 class ID: 0900
  Hub-11: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 3-1:2 info: VIA Labs USB 2.0 BILLBOARD type: Billboard driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 2109:0103 class ID: 1100
  serial: <filter>
  Device-2: 3-2:3 info: Cooler Master ARES type: Keyboard,HID
  chip ID: 2516:014d class ID: 0300
  Hub-12: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1
  System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 52.0 C
  mem: 56.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 244 Uptime: 10m wakeups: 0 Init: systemd v: 247 Compilers:
  gcc: N/A Packages: pacman: 1229 lib: 377 flatpak: 0 Shell: Bash v: 5.1.0
  running in: konsole inxi: 3.3.01 ```
Have you tried different kernels?
Yes. I tried 5.11 and it didn’t change anything
5.11 is the one you use right now (seen in the inxi), so that is not a different one.
I was on 5.9 and then tried using 5.11 before making this post
With this being a very new gpu, one of the first things that I was thinking of was that maybe the latest kernel would treat me better, but it treats me the same.
