I am not sure if I have the right place but well here goes.
My problem is, If I leave my monitor off and start my computer. It never starts lightdm or starts X or logs into cinnamon. When I turn the monitor on it says no signal on display port 1. I can switch to a tty and the screen recognises that as a valid signal.
My current solution is to turn the monitor on then start my computer.
[andrew@lydia ~]$ inxi -v7azy
Kernel: 6.0.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=3d95ef5a-5ecd-4dd5-9cdc-554f5d4a5749 rw quiet apparmor=1
Desktop: Cinnamon v: 5.4.12 tk: GTK v: 3.24.34 wm: Mutter vt: 7 dm: LightDM
v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2803
date: 04/27/2022
ID-1: hidpp_battery_0 charge: 47% condition: N/A volts: 3.8 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A
serial: <filter> status: discharging
RAM: total: 15.53 GiB used: 2.57 GiB (16.6%)
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 1x32 MiB
Speed (MHz): avg: 2441 high: 3700 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3700 2: 2200
3: 2200 4: 2200 5: 2200 6: 3596 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 bogomips: 88843
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: XFX Pine driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 0a:00.0
chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: DP-1 mapped: DisplayPort-0 model: ASUS VG24V serial: <filter>
built: 2020 res: 1920x1080 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: AMD Radeon RX 5600 XT (navi10
LLVM 14.0.6 DRM 3.48 6.0.6-1-MANJARO) direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
bus-ID: 3-2:2 gen: 4 chip-ID: 0951:16a4 speed: 16 GT/s class-ID: 0300
serial: <filter> lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX 7.1 Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k6.0.6-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.59 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.63 TiB used: 180.44 GiB (4.9%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 type: SSD serial: <filter> rev: P9CR40A temp: 38.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Addlink model: M.2 PCIE G3x4 NVMe
lanes: 4 type: SSD serial: <filter> rev: ECFM22.6 temp: 27.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDXPS480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 030 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 054 scheme: GPT
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS124 F rev: CL9N
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 40.04 GiB size: 39.11 GiB (97.69%) used: 17.62 GiB (45.0%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2 label: N/A
uuid: 3d95ef5a-5ecd-4dd5-9cdc-554f5d4a5749
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: DAE1-EB95
ID-3: /home raw-size: 436.6 GiB size: 428.68 GiB (98.19%)
used: 162.82 GiB (38.0%) fs: ext4 dev: /dev/nvme1n1p3 maj-min: 259:3
label: N/A uuid: b80eb4e0-289a-4311-a203-883aa2a78121
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: Recovery
uuid: A0B08E9DB08E7A14
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 6496-402E
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 446.5 GiB fs: ntfs label: N/A
uuid: FEF09DACF09D6C21
ID-5: /dev/sdb1 maj-min: 8:17 size: 735.61 GiB fs: ext4 label: Linuxbackups
uuid: 3e7a0b2e-8be8-46fe-81e5-d8de37d43bdc
ID-6: /dev/sdb2 maj-min: 8:18 size: 195.9 GiB fs: ext4 label: timeshift
uuid: 465a5e4a-df0b-4f95-b32f-0dd1d4fd21b1
ID-7: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ntfs
label: WinAudiobooks uuid: 4C208754763E95F4
ID-8: /dev/sdc2 maj-min: 8:34 size: 465.72 GiB fs: ntfs label: WinBackups
uuid: 7A4C4DCA2B95C85D
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-3: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-1:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Kingston HyperX 7.1 Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0951:16a4 class-ID: 0300
serial: <filter>
Device-2: 3-3:3 info: Logitech Cordless Mouse Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
Device-3: 3-4:4 info: CannonKeys Instant65 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: ca04:1565 class-ID: 0300
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 37.4 C mobo: N/A gpu: amdgpu temp: 49.0 C
mem: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 327 Uptime: 4m wakeups: 2 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1620 libs: 487 tools: pamac,yay Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.23
