When I boot my machine, the monitor remains blank - “no signal” through the entire boot.
It only turns on once Manjaro is fully loaded an the login screen is ready.
This wasn’t the case during Manjaro install - I was able to navigate bios and grub to boot my live usb. Through the whole OS config - lots of software installs and restarts, this problem came up. Hard to say what change made it happen and I’m sure I didn’t notice the first time it happened.
I tried switching to proprietary nvidia drivers, ditching nouveau using the mhwd tool
In nvidia-settings, my monitor appears to be the default monitor for all displaying.
That’s a hardware / firmware issue: Did this start happening after you upgraded your firmware or changed your hardware?
Your only recourse is contact your hardware / firmware manufacturer because there is nothing you can do from a Manjaro perspective to alleviate this problem…
