After turning my PC on from sleep mode the monitor doesn’t get a signal from my PC, so I have to manually press the reset button to restart the entire PC, which isn’t exactly the best. Any way I could fix this?
Result from inxi:
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1cd7eaa8-8ca7-4f6a-b662-3a376d33c921 rw quiet splash apparmor=1
Desktop: GNOME v: 47.2 tk: GTK v: 3.24.43 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASRock model: 970A-G/3.1 serial: N/A
uuid: 03000200-0400-0500-0006-000700080009 UEFI-[Legacy]: American Megatrends
v: P1.20 date: 01/12/2016
System RAM: total: 24 GiB available: 23.44 GiB used: 1.69 GiB (7.2%)
Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
Device-1: A1_DIMM0 type: DDR3 detail: synchronous unbuffered (unregistered)
size: 4 GiB speed: spec: 1600 MT/s actual: 800 MT/s volts: N/A width (bits):
data: 64 total: 64 manufacturer: Crucial part-no: CT51264BD186DJ.C16
serial: <filter>
Device-2: A1_DIMM1 type: DDR3 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: spec: 1600 MT/s actual: 800 MT/s volts: N/A width (bits):
data: 64 total: 64 manufacturer: Patriot part-no: PSD38G1600L2
serial: <filter>
Device-3: A1_DIMM2 type: DDR3 detail: synchronous unbuffered (unregistered)
data: 64 total: 64 manufacturer: Crucial part-no: CT51264BD160BJ.M8F
serial: <filter>
Device-4: A1_DIMM3 type: DDR3 detail: synchronous unbuffered (unregistered)
serial: <filter>
Slot: 1 type: PCI status: in use length: short volts: 3.3 bus-ID: N/A
Slot: 17 type: PCIe gen: 1 status: in use length: short volts: 3.3
bus-ID: 00:0f.0
Slot: 18 type: PCIe gen: 2 status: in use length: long volts: 3.3
bus-ID: 00:02.0 children: 1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1
class-ID: 0403 type: audio
Slot: 19 type: PCIe gen: 3 status: in use length: short volts: 3.3
bus-ID: 00:0f.1
Slot: 20 type: PCIe gen: 4 status: in use length: long volts: 3.3
bus-ID: 00:0b.0
Info: model: AMD FX-8120 socket: AM3 bits: 64 type: MCP arch: Bulldozer
level: v2 built: 2011 process: GF 32nm family: 0x15 (21) model-id: 1
stepping: 2 microcode: 0x600063E
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
L1: 384 KiB desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1400 min/max: 1400/3100 boost: enabled
base/boost: 3100/3100 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.3 V ext-clock: 200 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 49620
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid flushbyasid fma4 fpu fxsr fxsr_opt ht hw_pstate ibpb
ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor msr mtrr
nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
svm svm_lock syscall topoext tsc tsc_scale vmcb_clean vme vmmcall wdt xop
xsave
Device-1: NVIDIA TU106 [GeForce GTX 1650] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2 speed: 5 GT/s ports:
active: HDMI-A-1 empty: DP-1,DVI-D-1 bus-ID: 01:00.0 chip-ID: 10de:1f0a
class-ID: 0300
Display: unspecified server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
compositor: gnome-shell driver: gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Asus VE247 serial: <filter>
built: 2010 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 chroma: red: x: 0.643
y: 0.337 green: x: 0.314 y: 0.631 blue: x: 0.157 y: 0.059 white: x: 0.314
y: 0.329 size: 530x300mm (20.87x11.81") diag: 609mm (24") ratio: 16:9
modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960,
1366x768, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
720x480, 640x480, 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.8-arch1.1 glx-v: 1.4
direct-render: yes renderer: NV166 device-ID: 10de:1f0a memory: 3.9 GiB
unified: no
Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-3: Kingston HyperX Cloud Stinger Wireless
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0951:16da class-ID: 0300
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) with:
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.1 TiB used: 49.65 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
fw-rev: T0707A0L temp: 36.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000NM0011
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: PA07 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000NM0011
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: <unknown>
tech: HDD rpm: 7200 serial: <filter> fw-rev: PA07 scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS model: BW-12B1ST rev: 1.03
dev-links: cdrom
ID-1: / raw-size: 476.84 GiB size: 468.28 GiB (98.21%)
used: 49.65 GiB (10.6%) fs: ext4 block-size: 4096 B dev: /dev/sdb3
maj-min: 8:19 label: N/A uuid: 1cd7eaa8-8ca7-4f6a-b662-3a376d33c921
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 50 MiB fs: ntfs
label: System Reserved uuid: 6ECABCA0CABC664D
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 476.07 GiB fs: ntfs label: N/A
uuid: 6A1ADBE31ADBA9F9
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 840 MiB fs: ntfs label: N/A
uuid: 24540D23540CF8F6
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-5: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs
label: VirtualBox/Extra Stuff uuid: 8058ACF058ACE65E
ID-6: /dev/sdb1 maj-min: 8:17 size: 1.1 TiB fs: ntfs label: Games
uuid: 50E2BB70E2BB58C4
ID-7: /dev/sdb2 maj-min: 8:18 size: 256 GiB fs: ext4 label: kubuntu_2404
uuid: 807d02a6-31d5-4b1a-a660-4783adecbc74
Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Device-1: 1-2:2 info: Razer USA DeathAdder V2 Mini type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:008c class-ID: 0300
Device-2: 1-4:3 info: Kingston HyperX Cloud Stinger Wireless
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-4: 4-0:1 info: full speed or root hub ports: 4 rev: 2.0
Hub-5: 5-0:1 info: full speed or root hub ports: 5 rev: 1.1
Hub-6: 6-0:1 info: full speed or root hub ports: 2 rev: 1.1
Hub-7: 7-0:1 info: full speed or root hub ports: 4 rev: 1.1
Hub-8: 8-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-9: 8-2:2 info: Genesys Logic Logitech G110 Hub ports: 4 rev: 2.0
chip-ID: 05e3:0607 class-ID: 0900
Device-1: 8-2.1:3 info: Logitech Gaming Keyboard G110 G-keys
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c22b class-ID: 0300
Device-2: 8-2.3:4 info: Logitech Gaming Keyboard G110 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c22a class-ID: 0300
Hub-10: 9-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-11: 10-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-12: 11-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 36.8 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1336 pm: pacman pkgs: 1330 libs: 384
tools: gnome-software,pamac,yay pm: flatpak pkgs: 6
1: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
2: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
3: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 269
1: cpu: 33.3% command: ps pid: 2892 mem: 3.62 MiB (0.0%)
2: cpu: 14.5% command: brave pid: 2164 mem: 359.1 MiB (1.4%)
3: cpu: 10.7% command: brave pid: 2202 mem: 170.4 MiB (0.7%)
4: cpu: 10.1% command: gnome-shell pid: 1538 mem: 267.7 MiB (1.1%)
5: cpu: 8.2% command: brave pid: 2503 mem: 255.8 MiB (1.0%)
Memory top: 5 of 269
1: mem: 359.1 MiB (1.4%) command: brave pid: 2164 cpu: 14.5%
2: mem: 267.7 MiB (1.1%) command: gnome-shell pid: 1538 cpu: 10.1%
3: mem: 255.8 MiB (1.0%) command: brave pid: 2503 cpu: 8.2%
4: mem: 210.8 MiB (0.8%) command: brave pid: 2724 cpu: 7.8%
5: mem: 170.4 MiB (0.7%) command: brave pid: 2202 cpu: 10.7%
Processes: 269 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.35 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: N/A Shell: Sudo (sudo) v: 1.9.16p2 default: Bash v: 5.2.37
running-in: alacritty inxi: 3.3.36
[blink42@xavierManjaroGNOME ~]$
Mod note: I’ve edited this for you to put the ``` on separate lines above and below the pasted output.
