Hello all! I have a super frustrating problem that I have no been able to solve, and having gone through the forum, it seems others have had this issue as well, however either their solution did not solve my issues or their problems are equally unsolved!
Every time I boot my computer up, my main monitor (2K HDMI Samsung) fails to show an image. It wakes up, like its a black screen but the monitor is clearly lit. My second monitor, a 1080p (Displayport to) HDMI samsung monitor, works fine with waking and having an image, and it displays my second window (no taskbar, etc) so its like the computer knows I have two monitors plugged in. It isnt until i unplug my main monitor and plug it back in, that kde will reshuffle itself around and display to both monitors properly.
This is an extremely annoying problem, one that i have no idea how to solve and has proven not to be easily fixed by checking the wiki or googling, and I sort of feel like a burden on the discord group so im hoping someone will help me out here, because this does seem to be a bigger issue. I’ve tried some solutions, from as simple as disabling and reenabling my main monitor in the settings, to booting the computer with only one of the two monitors plugged in, to changing my drivers from 455 to 440, from free to proprietary, etc… Nothing works. I made an account of this forum to post this question… so this is my last attempt ahaha.
Thanks a lot! Cheers!
KDE Plasma Version: 5.20.4
KDE Frameworks Version: 5.76.0
Qt Version: 5.15.2
Kernel Version: 5.9.11-3-MANJARO
OS Type: 64-bit
Processors: 4 × Intel® Core™ i5-4690K CPU @ 3.50GHz
Memory: 23.4 GiB of RAM
Graphics Processor: GeForce GTX 1070/PCIe/SSE2
Hey, thanks alot for the reply! Here is the printout of xrandr as soon as i log in (and put my password into my keychain thing (another problem of mine))
Screen 0: minimum 8 x 8, current 4480 x 1440, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
2560x1440 144.00*+ 120.00 99.95 59.95
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 connected 1920x1080+2560+180 (normal left inverted right x axis y axis) 598mm x 336mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
Here is it is right after i unplug and plug my monitor in again:
[sal@eden-s ~]$ xrandr
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x800 59.81
1152x864 75.00
720x576 50.00
720x480 59.94
wow thats so funny! Yeah going into tty and back to graphic desktop makes my monitor wake up with an image. I guess it accomplishes the same “refresh” type thing without needing to physically unplug and replug? this is a good temporary solution, but what can i do so this no longer happens?
Im thinking of doing a fresh install if there are no solutions, hopefully that will solve this along with other small problems i have with the way my system behaves.
I had that problem myself and I’ve seen it happen to other users. It has nothing to do with multimonitor. It just happens and suddenly goes away and it can come back in the future. I have never seen a definite solution for this. Reinstalling the system will solve it for now, but it doesn’t guarantee you that it won’t happen again. Personally, I don’t think it’s worth the hassle.
