Hi, I recently installed Manjaro and have been loving it. Unfortunately, I have been experiencing the problem that the monitor backlight of my laptop is completely deactivated after a suspend and I am forced to reboot. Thank you in advance for any tips!
What happens if you press CTRL+ALT+F2 and then CTRL+ALT+F1?
Nothing happens, unfortunately. I can, however, faintly see the login box and CTRL+ALT+DEL works. When I connect an external monitor, then I am able to log back in, but the laptop screen is still black. I have included some information below:
[holden@holden-20h1004tus ~]$ inxi -Fazy
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=5976b650-7fe7-4c78-83aa-f6d5d2569953 rw quiet apparmor=1
security=apparmor resume=UUID=8c366820-5313-4522-a7f0-1beec511d9b6
udev.log_priority=3
Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20H1004TUS v: ThinkPad E470
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20H1004TUS v: SDK0J40697 WIN serial: <filter>
UEFI [Legacy]: LENOVO v: R0DET81W (1.81 ) date: 04/27/2017
ID-1: BAT0 charge: 34.0 Wh condition: 34.2/45.0 Wh (76%) volts: 12.3/11.1
model: LGC 01AV412 type: Li-poly serial: <filter> status: Not charging
Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: DE
L2 cache: 4096 KiB
bogomips: 23209
Speed: 700 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Lenovo driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:134d
Device-3: Realtek Integrated Camera type: USB driver: uvcvideo bus ID: 1-7:5
chip ID: 0bda:58db serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1104 s-dpi: 96 s-size: 1016x292mm (40.0x11.5")
s-diag: 1057mm (41.6")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.9.11-3-MANJARO
vendor: Lenovo driver: r8169 v: kernel port: c000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: c000
bus ID: 05:00.0 chip ID: 8086:24fd
IF: wlp5s0 state: up mac: <filter>
Local Storage: total: 238.47 GiB used: 9.90 GiB (4.2%)
ID-1: /dev/sda vendor: SanDisk model: SD8TB8U256G1001 size: 238.47 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 3101 scheme: MBR
ID-1: / raw size: 229.67 GiB size: 225.06 GiB (97.99%) used: 9.90 GiB (4.4%)
fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2
System Temperatures: cpu: 46.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 243 Uptime: 7m Memory: 7.24 GiB used: 1.03 GiB (14.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1087 lib: 325
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
[holden@holden-20h1004tus ~]$ sudo dmesg -l emerg,alert,crit,err,warn
[ 0.123176] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.123176] #3
[ 0.126689] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.740202] ata1.00: supports DRM functions and may not be fully accessible
[ 0.747433] ata1.00: supports DRM functions and may not be fully accessible
[ 1.048905] usb: port power management may be unreliable
[ 1.876770] nvidia: loading out-of-tree module taints kernel.
[ 1.876783] nvidia: module license 'NVIDIA' taints kernel.
[ 1.876783] Disabling lock debugging due to kernel taint
[ 2.135706] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.45.01 Thu Nov 5 23:03:56 UTC 2020
[ 2.625966] acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 2.626091] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
[ 3.233608] r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 3.599238] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 6.217586] ACPI Warning: \_SB.PCI0.RP01.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200717/nsarguments-59)
[ 7.787955] kauditd_printk_skb: 45 callbacks suppressed
[ 14.019569] kauditd_printk_skb: 2 callbacks suppressed
[ 194.001659] kauditd_printk_skb: 19 callbacks suppressed
[ 242.078897] smpboot: Scheduler frequency invariance went wobbly, disabling!
[ 242.339987] iwlwifi 0000:05:00.0: RF_KILL bit toggled to enable radio.
[ 242.653536] ata1.00: supports DRM functions and may not be fully accessible
[ 242.659222] ata1.00: supports DRM functions and may not be fully accessible
[ 252.956231] kauditd_printk_skb: 2 callbacks suppressed
[holden@holden-20h1004tus ~]$ sudo systemd-analyze blame
1.355s tlp.service
1.190s apparmor.service
1.169s lvm2-monitor.service
1.073s dev-sda1.device
835ms systemd-random-seed.service
662ms systemd-modules-load.service
646ms systemd-udevd.service
623ms snapd.service
497ms systemd-logind.service
478ms systemd-journald.service
432ms upower.service
237ms polkit.service
185ms systemd-backlight@backlight:intel_backlight.service
120ms systemd-journal-flush.service
110ms systemd-udev-trigger.service
106ms avahi-daemon.service
101ms udisks2.service
100ms NetworkManager.service
95ms user@1000.service
92ms systemd-rfkill.service
81ms systemd-tmpfiles-clean.service
71ms lightdm.service
52ms ModemManager.service
37ms wpa_supplicant.service
32ms systemd-tmpfiles-setup.service
32ms dev-disk-by\x2duuid-8c366820\x2d5313\x2d4522\x2da7f0\x2d1beec511d9b6.swap
30ms systemd-tmpfiles-setup-dev.service
30ms accounts-daemon.service
27ms snapd.apparmor.service
24ms colord.service
22ms bluetooth.service
21ms linux-module-cleanup.service
21ms ufw.service
18ms systemd-sysctl.service
17ms systemd-user-sessions.service
13ms dev-hugepages.mount
12ms user-runtime-dir@1000.service
12ms dev-mqueue.mount
12ms systemd-remount-fs.service
11ms sys-kernel-debug.mount
11ms systemd-update-utmp.service
10ms sys-kernel-tracing.mount
9ms kmod-static-nodes.service
8ms modprobe@drm.service
6ms rtkit-daemon.service
4ms sys-fs-fuse-connections.mount
3ms snapd.socket
2ms tmp.mount
2ms sys-kernel-config.mount
There seems to be an error here, but I am not sure if it is related:
[holden@holden-20h1004tus ~]$ sudo bootctl
Couldn't find EFI system partition. It is recommended to mount it to /boot or /efi.
Alternatively, use --esp-path= to specify path to mount point.
Not booted with EFI
Have you tried kernel 5.4?
