Hello.
I’m having trouble creating a new monero wallet. I installed the app trezor suite (appimage) and added udev rules. The app detects the trezor safe 3, but it is not detected by Monero gui.
device not found: Trezor
trezord.service - Trezor Bridge
Loaded: loaded (/usr/lib/systemd/system/trezord.service; enabled; preset: disabled)
Active: failed (Result: exit-code) since Sun 2024-08-11 14:27:36 CEST; 24min ago
Duration: 53ms
Invocation: 5188c4da9bdc43c28fcdcaab6f6a773c
Main PID: 79191 (code=exited, status=1/FAILURE)
Mem peak: 9.6M
CPU: 12ms
sie 11 14:27:36 laptop systemd[1]: Started Trezor Bridge.
sie 11 14:27:36 laptop trezord[79191]: 2024/08/11 14:27:36 trezord v2.0.27 is starting.
sie 11 14:27:36 laptop trezord[79191]: 2024/08/11 14:27:36 https: listen tcp 127.0.0.1:21325: bind: addr>
sie 11 14:27:36 laptop systemd[1]: trezord.service: Main process exited, code=exited, status=1/FAILURE
sie 11 14:27:36 laptop systemd[1]: trezord.service: Failed with result 'exit-code'.
Thank you in advance for your help.
