Module not found: nvidia nvidia_drm nvidia_uvm nvidia_modeset
After the last update I got an error about kernel modules and tried to rebuild it once more.
mkinitcpio -P
[zephyrusg14 ~]# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux72.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-7.2-x86_64 -g /boot/initramfs-7.2-x86_64.img
==> Starting build: '7.2.11-3-MANJARO'
  -> Running build hook: [systemd]
  -> Running build hook: [microcode]
  -> Running build hook: [kms]
  -> Running build hook: [sd-vconsole]
==> ERROR: module not found: 'nvidia'
==> ERROR: module not found: 'nvidia_drm'
==> ERROR: module not found: 'nvidia_uvm'
==> ERROR: module not found: 'nvidia_modeset'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-7.2-x86_64.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
[zephyrusg14 ~]#
same for LTS 6.18.57-3
lsmod | grep nvidia
[zephyrusg14 ~]# lsmod | grep nvidia
nvidia_drm            172032  10
nvidia_uvm           2478080  4
nvidia_modeset       1998848  6 nvidia_drm
nvidia              18755584  118 nvidia_uvm,nvidia_modeset
drm_ttm_helper         20480  2 amdgpu,nvidia_drm
drm_display_helper    303104  2 amdgpu,nvidia_drm
video                  81920  4 asus_wmi,amdgpu,asus_nb_wmi,nvidia_modeset
aead                   16384  5 ccm,nvidia,xfrm_algo,mac80211,aesni_intel
[zephyrusg14 ~]#
inxi -zv8
[zephyrusg14 ~]# LANG=C inxi -zv8
  Kernel: 7.2.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    clocksource: hpet avail: acpi_pm parameters: initrd=\amd-ucode.img
    initrd=\initramfs-7.2-x86_64.img
    root=UUID=2ea1cc94-7d9e-497b-977c-1746ae5f4e6f rw rootflags=subvol=/@
    nvidia_drm.modeset=1 quiet loglevel=3 rd.udev.log_priority=3
    vt.global_cursor_default=0
  Desktop: GNOME v: 51.1 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 51.1 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QC_GA401QC
    v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: GA401QC v: 1.0 serial: <filter>
    uuid: e4db5459-5a89-d34d-882c-55da21ae906a Firmware: UEFI vendor: American
    Megatrends LLC. v: GA401QC.416 date: 11/14/2025
  ID-1: BAT0 charge: 58.2 Wh (100%) condition: 58.2/76 Wh (76.6%) volts: 15.83
    min: 15.83 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A charging:
    status: not charging control: start: N/A end: 100% cycles: N/A
  System RAM: total: 32 GiB available: 30.75 GiB used: 8.76 GiB (28.5%)
    (unregistered) size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A2G44AM0-CWE serial: N/A
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF3200C20S4/16G serial: <filter>
  Message: No PCI Slot data found.
  Info: model: AMD Ryzen 7 5800HS with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500012
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 403 min/max: 403/3201 boost: enabled
    base/boost: 3200/4450 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 403 2: 403 3: 403 4: 403 5: 403
    6: 403 7: 403 8: 403 9: 403 10: 403 11: 403 12: 403 13: 403 14: 403
    15: 403 16: 403 bogomips: 102211
    vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
    affected
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
    driver: nvidia v: 615.78.08 non-free: 550-6xx.xx+
    status: current (as of 2026-07) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: HDMI-A-1 off: eDP-1 empty: none bus-ID: 04:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 43.0 C
  Display: unspecified server: Xwayland v: 24.1.14 compositor: gnome-shell
    driver: X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau,radeon
    alternate: fbdev,nv,vesa dri: radeonsi gpu: amdgpu display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
  Monitor-1: HDMI-1 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 108
    size: 600x330mm (23.62x12.99") diag: 685mm (26.96") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: amd mesa v: 26.2.5-arch1.1
    renoir ACO DRM 3.64 7.2.11-2-MANJARO) device-ID: 1002:1638 memory: 500 MiB
    unified: yes
  API: Vulkan v: 1.4.363 layers: 8 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 26.2.5-arch1.1
    device-ID: 1002:1638 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia v: 615.78.08
    device-ID: 10de:25a2 surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo
    gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
  Device-1: NVIDIA GA107 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:2291 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Audio Coprocessor vendor: ASUSTeK
    driver: N/A pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 04:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-4: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
    bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-5: SteelSeries ApS Arctis Nova 7 WOW Edition
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 1038:227a class-ID: 0300
  API: ALSA v: k7.2.11-2-MANJARO status: kernel-api
  Server-3: PipeWire v: 1.6.9 status: n/a (root, process) with:
  Device-1: MEDIATEK MT7921 802.11ax PCIe Wireless Network Adapter [Filogic
    330] vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF-ID-1: br-153747543cd5 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-3: veth012cba6 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-4: veth0740f74 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-5: veth3ae75a2 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-6: veth73fbe1f state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-7: vetha343e53 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  IF-ID-8: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
  IF-ID-9: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
  Info: services: NetworkManager, nginx, sshd, systemd-timesyncd,
    wpa_supplicant
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 13d3:3563
  Local Storage: total: 476.94 GiB used: 181.25 GiB (38.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
    lanes: 4 tech: SSD serial: <filter> fw-rev: 003C temp: 32.9 C scheme: GPT
  SMART: yes health: PASSED on: 4y 57d 6h cycles: 816
    read-units: 93,523,538 [47.8 TB] written-units: 74,502,159 [38.1 TB]
  ID-1: / raw-size: 474.98 GiB size: 474.98 GiB (100.00%)
    used: 180.92 GiB (38.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: 2ea1cc94-7d9e-497b-977c-1746ae5f4e6f
  ID-2: /boot raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
    used: 339.8 MiB (17.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 1DF6-CACC
  ID-3: /home raw-size: 474.98 GiB size: 474.98 GiB (100.00%)
  ID-4: /var/cache raw-size: 474.98 GiB size: 474.98 GiB (100.00%)
  ID-5: /var/log raw-size: 474.98 GiB size: 474.98 GiB (100.00%)
  ID-1: swap-1 type: zram size: 8 GiB used: 4 KiB (0.0%) priority: 100
    comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 dev: /dev/zram0
  Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Hub-3: 1-1.1:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Device-1: 1-1.1.1:5 info: Logitech Logi Bolt Receiver
    type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 98mA chip-ID: 046d:c548 class-ID: 0300
  Device-2: 1-3:3 info: ASUSTek N-KEY Device type: keyboard
    driver: asus,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
  Hub-4: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-5: 2-1:2 info: Realtek Hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-6: 2-1.1:3 info: Realtek Hub ports: 4 rev: 3.0
  Hub-7: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: SteelSeries ApS Arctis Nova 7 WOW Edition
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 6
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Device-2: 3-3:3 info: Shenzhen Goodix FingerPrint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:521d class-ID: ff00
  Device-3: 3-4:4 info: IMC Networks Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 45.9 C mobo: 40.0 C gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): cpu: 2300
  Packages: 1466 pm: pacman pkgs: 1442 libs: 398
    tools: gnome-software,pamac,yay pm: flatpak pkgs: 24
    1: https://mirror.yandex.ru/mirrors/manjaro/unstable/$repo/$arch
    2: https://mirror.truenetwork.ru/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 498
  1: cpu: 5.5% command: firefox pid: 236153 mem: 306.9 MiB (0.9%)
  2: cpu: 3.7% command: firefox pid: 182675 mem: 375.8 MiB (1.1%)
  3: cpu: 1.9% command: lm-studio pid: 203732 mem: 400.2 MiB (1.2%)
  4: cpu: 1.7% command: exe pid: 204134 mem: 426.4 MiB (1.3%)
  5: cpu: 1.4% command: pamac-manager pid: 207143 mem: 1834.7 MiB (5.8%)
  Memory top: 5 of 498
  1: mem: 3017.0 MiB (9.5%) command: llama-server pid: 204490 cpu: 0.9%
  2: mem: 1834.7 MiB (5.8%) command: pamac-manager pid: 207143 cpu: 1.4%
  3: mem: 1006.1 MiB (3.1%) command: firefox pid: 11975 cpu: 1.0%
  4: mem: 426.4 MiB (1.3%) command: exe pid: 204134 cpu: 1.7%
  5: mem: 415.1 MiB (1.3%) command: gnome-shell pid: 4972 cpu: 1.3%
  Processes: 498 Power: uptime: 1d 19h 22m states: freeze,mem,disk
    suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.17 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: gcc: 16.2.1 Shell: Bash (sudo) v: 5.3.20
    running-in: ptyxis-agent inxi: 3.3.41
mhwd -li
[zephyrusg14 ~]# mhwd -li
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
video-hybrid-amd-nvidia-prime            2026.03.05               false            PCI
[zephyrusg14 ~]#
Could it be because a version mismatch?
modules
[zephyrusg14 ~]# LANG=C pacman -Qo /usr/lib/modules/7.2.11-3-MANJARO/*
/usr/lib/modules/7.2.11-3-MANJARO/build/ is owned by linux72-headers 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/kernel/ is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/kernelbase is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.alias is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.alias.bin is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.builtin is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.builtin.alias.bin is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.builtin.bin is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.builtin.modinfo is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.dep is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.dep.bin is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.devname is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.order is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.softdep is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.symbols is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.symbols.bin is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/modules.weakdep is owned by linux72 7.2.11-3
/usr/lib/modules/7.2.11-3-MANJARO/pkgbase is owned by linux72 7.2.11-3
error: No package owns /usr/lib/modules/7.2.11-3-MANJARO/updates
/usr/lib/modules/7.2.11-3-MANJARO/vmlinuz is owned by linux72 7.2.11-3
[zephyrusg14 ~]# LANG=C pacman -Qo /usr/lib/modules/7.2.11-2-MANJARO/*
/usr/lib/modules/7.2.11-2-MANJARO/extramodules/ is owned by linux72-nvidia-open 615.78.08-4
[zephyrusg14 ~]# find /usr/lib/modules/$(uname -r) -iname 'nvidia*'
/usr/lib/modules/7.2.11-2-MANJARO/extramodules/nvidia-drm.ko.zst
/usr/lib/modules/7.2.11-2-MANJARO/extramodules/nvidia.ko.zst
/usr/lib/modules/7.2.11-2-MANJARO/extramodules/nvidia-modeset.ko.zst
/usr/lib/modules/7.2.11-2-MANJARO/extramodules/nvidia-peermem.ko.zst
/usr/lib/modules/7.2.11-2-MANJARO/extramodules/nvidia-uvm.ko.zst
[zephyrusg14 ~]#
Downgrade (7.2.11-2) works without errors
mkinitcpio -P
==> Starting build: '7.2.11-2-MANJARO'
  -> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
[zephyrusg14 ~]#
In general, it could. In this case, you apparently haven’t rebooted after updating to linux72 7.2.11-2 / linux72-nvidia-open 615.78.08-4 to linux72 7.2.11-3 / linux72-nvidia-open 615.78.08-5. The 7.2.11-2-MANJARO and 7.2.11-3-MANJARO/updates folder will be gone after rebooting.
Maybe now is a good time to reboot and then try updating again.
linux618 6.18.57-3, linux72 7.2.11-3 & linux73 7.3.0rc7-3 were just Rust 1.99 rebuilds.
I can neither reproduce it with nvidia-open-dkms nor linux618-nvidia-open / linux72-nvidia-open.
This was a problem with mirrors.
I didn’t get linux72-nvidia-open 615.78.08-5 last time.
Everything is working now, thank you!
Aha! So it was a just a mismatch then.
You’re welcome. You barely caught me, I was about to go have dinner before I saw your reply in the Unstable Update thread. I can never resist helping someone solve a problem. :smile:
