The install of the kernel module for virtualbox for kernel 5.16.2 failed on my machine. The dkms install returns a build error. It seems? to be an authorization issue??
The following packages will be installed:
linux516
linux516-headers
Starting
resolving dependencies...
Packages (2) linux516-5.16.2-1 linux516-headers-5.16.2-1
Total Download Size: 140.69 MiB
Total Installed Size: 256.74 MiB
:: Retrieving packages...
linux516-5.16.2-1-x86_64 downloading...
linux516-headers-5.16.2-1-x86_64 downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing linux516...
Optional dependencies for linux516
crda: to set the correct wireless channels of your country [installed]
installing linux516-headers...
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Install DKMS modules
==> dkms install --no-depmod vboxhost/6.1.30_OSE -k 5.16.2-1-MANJARO
Error! Bad return status for module build on kernel: 5.16.2-1-MANJARO (x86_64)
Consult /var/lib/dkms/vboxhost/6.1.30_OSE/build/make.log for more information.
==> WARNING: `dkms install --no-depmod vboxhost/6.1.30_OSE -k 5.16.2-1-MANJARO' exited 10
(4/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux516.preset: 'default'
-> -k /boot/vmlinuz-5.16-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.16-x86_64.img
==> Starting build: 5.16.2-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.16-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux516.preset: 'fallback'
-> -k /boot/vmlinuz-5.16-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.16-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.16-x86_64-fallback.img
==> Image generation successful <cut>
and below output of the terminal with my user account shows that make and uname are installed.
❯ cat /var/lib/dkms/vboxhost/6.1.30_OSE/build/make.log
DKMS make.log for vboxhost-6.1.30_OSE for kernel 5.16.2-1-MANJARO (x86_64)
Mon Jan 24 14:01:55 CET 2022
make: Entering directory '/usr/lib/modules/5.16.2-1-MANJARO/build'
make: uname: No such file or directory
make: make: No such file or directory
make: *** [Makefile:1846: /var/lib/dkms/vboxhost/6.1.30_OSE/build] Error 127
make: Leaving directory '/usr/lib/modules/5.16.2-1-MANJARO/build'
❯ uname
Linux
❯ make
make: *** No targets specified and no makefile found. Stop.
This happened with previous new kernels too and was worked around. Now help to solve this better is appreciated. Thanks! [update: I have selected the “solution” below, because it does the job (thanks!!) ]
