Hello,
I used following article: VirtualBox - Manjaro
My Kernel:
mhwd-kernel -li
Currently running: 5.16.11-arch1-1-surface (linux516)
Command used:
sudo pacman -Syu virtualbox linux516-virtualbox-host-modules
I did both sudo vboxreload and system reboot
Error:
Unloading modules:
Loading modules: modprobe: FATAL: Module vboxnetadp not found in directory /lib/modules/5.16.11-arch1-1-surface
modprobe: FATAL: Module vboxnetflt not found in directory /lib/modules/5.16.11-arch1-1-surface
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/5.16.11-arch1-1-surface
