Modprobe: FATAL: Module fuse not found
ntfs
mount
#1
Hi there I want Mount my external hard drive in my rpi3
But I get this message:
saeb@saeb-pi  ~  sudo mount /dev/sda1 ~/Mount/sda1
[sudo] password for saeb:
modprobe: FATAL: Module fuse not found in directory /lib/modules/4.14.66-1-MANJARO-ARM
fuse: device not found, try 'modprobe fuse' first
Let me try modprobe fuse
This message comes:
✘ saeb@saeb-pi  ~  sudo modprobe fuse
I updated my Manjaro right now and reboot that but before and after uodate I have that issue,
I installed ntfs-3g and fuse3
#2
ity/btfs 2.18-4
    A bittorrent filesystem based on FUSE
 saeb@saeb-pi  ~  lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda           8:0    0 931.5G  0 disk
└─sda1        8:1    0 931.5G  0 part
sdb           8:16   0 465.8G  0 disk
└─sdb1        8:17   0 465.8G  0 part
mmcblk0     179:0    0  29.8G  0 disk
├─mmcblk0p1 179:1    0    94M  0 part
└─mmcblk0p2 179:2    0  29.7G  0 part /
 saeb@saeb-pi  ~ 
#4
Like I said, I did that
#5
is this service working from systemctl ?
sys-module-fuse.device loaded active plugged /sys/module/fuse
#6
#7
polkit-agent-helper-1: pam_authenticate failed: Authentication failure
==== AUTHENTICATION FAILED ====
Failed to enable unit: Access denied
✘ saeb@saeb-pi  ~  sudo !!
✘ saeb@saeb-pi  ~  sudo systemctl enable sys-fs-fuse-connections.mount
The unit files have no installation config (WantedBy, RequiredBy, Also, Alias
settings in the [Install] section, and DefaultInstance for template units).
This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
  1. A unit may be statically enabled by being symlinked from another unit’s
    .wants/ or .requires/ directory.
  2. A unit’s purpose may be to act as a helper for some other unit which has
    a requirement dependency on it.
  3. A unit may be started when needed via activation (socket, path, timer,
    D-Bus, udev, scripted systemctl call, …).
  4. In case of template units, the unit is meant to be enabled with some
    instance name specified.
    saeb@saeb-pi  ~ 
#8
Thanks, but it didn’t help. I have latest version of manjaro-arm kernel and reboot didint help
#9
Do you have the kernel headers installed?
They might be needed for fuse.
#11
saeb@saeb-pi  ~  pacman -Ss linux-raspberrypi-headers
core/linux-raspberrypi-headers 4.14.76-1 [installed]
    Header files and scripts for building modules for linux kernel - Raspberry Pi
 saeb@saeb-pi  ~ 
Can I install linux418 for my rpi3?
#12
Is the OS recently installed or did you use an older install?
#13
The rpi3 18.10 images are using 4.18 and will be on 4.19 if they update.
You seem to have used a rpi2 image.
#15
Filesystem created: Sat Sep 1 15:39:40 2018
So I just need install for rpi3 image,
I’ll try that. Thx
