I have been trying to generate a private on a relatively fresh manjaro install. The process gets stuck at the infamous “Generate enough entropy” message.
Whatever I try, the prime key generation hangs for ever; I let it run for a few hours once just to make sure.
There are a lot of posts and tutorials about this. Many suggesting havegd
, rng-tools
or using commands like find
or cat /dev/urandom
(which by the way forced me to do a hard reboot; I do not recommend).
I did not try havegd
because the ArchWiki page recommends (havegd page) using rng-tools
. I tried the ArchWiki (rng-tools page) testing commands for rngd
rngtest -c 1000 </dev/random
ends up with two failures which is fine according to the wiki pagedd if=/dev/random of=/dev/null bs=1024 count=1 iflag=fullblock
outputs exactly what the wiki page suggests for a successful testsudo rngd -f
on the other hand fails to initializepkcs11
Initializing available sources
[hwrng ]: Initialized
[rdrand]: Enabling RDSEED rng support
[rdrand]: Initialized
[jitter]: JITTER timeout set to 5 sec
[jitter]: Initializing AES buffer
[jitter]: Unable to obtain AES key, disabling JITTER source
[jitter]: Initialization Failed
[pkcs11]: PKCS11 Engine /usr/lib64/opensc-pkcs11.so Error: No such file or directory
[pkcs11]: Initialization Failed
[rtlsdr]: Initialization Failed
I checked with pacman
, all related pkcs
packages seem to be installed:
core/libp11-kit 0.25.0-1 [installed]
Loads and enumerates PKCS#11 modules (library)
core/p11-kit 0.25.0-1 [installed]
core/p11-kit-docs 0.25.0-1
Loads and enumerates PKCS#11 modules (documentation)
extra/gnupg-pkcs11-scd 0.10.0-2 [installed]
Smart-card daemon to enable the use of PKCS#11 tokens with GnuPG
extra/haskell-rsa 2.4.1-207
Implementation of RSA, using the padding schemes of PKCS#1 v2.1.
extra/libp11 0.4.12-2 [installed]
A library implementing a small layer on top of the PKCS11 API
extra/pkcs11-helper 1.29.0-2 [installed]
A library that simplifies the interaction with PKCS11 providers for end-user
applications using a simple API and optional OpenSSL engine
extra/python-python-pkcs11 0.7.0-6
PKCS#11/Cryptoki support for Python
extra/softhsm 2.6.1-4
Software PKCS#11 store
extra/tpm2-pkcs11 1.9.0-1
PKCS#11 interface for Trusted Platform Module 2.0 hardware
multilib/lib32-p11-kit 0.25.0-1
Loads and enumerates PKCS#11 modules (32-bit library)
I tried running a gpg key generation while:
- running
rngd -f
in another terminal, - starting the rngd systemd service,
- running commands like
cat /dev/urandom
Out of despair, I tried installing havegd
, but the systemd service fails to start with the following error:
Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6)
My kernel version is indeed 6.1.44-1-MANJARO (64-bit)
Finally, what comes up in every post I read is to run cat /proc/sys/kernel/random/entropy_avail
to see how much entropy is available on your system. Since the start of my many attempts to raise tht number, the output is invariably (and dishearteningly) 256
Based on what I understood from the wikis and posts, it is not only about successfully generating a key but generating qualitative entropy so the generated keys are secure.
So I am not looking for a shortcut, but a “good” solution as the archWiki states for example that running rngd -o /dev/random -r /dev/urandom
is pointless, and I came across this advice a lot. I tried it anyway, and guess what ? Still 256
, and gpg (or gpg2 btw) still hanging for ever.
Thanks in advance for any advice, I most definitely need some help at this point.
PS: Sorry for the esthetics, I cannot include links.
