Mod + 0 commands do not work in i3
Mod+0 shows me all the options at the bottom, but "r" for reboot does nothing. The same happens with all, l,e,u,s.
I do not know what caused this. I have i3 on my laptop too. It works there but not on my desktop.
Which command is called in i3 config? Does the command I3 shall call avaliable?
# Set shut down, restart and locking features
bindsym $mod+0 mode "$mode_system"
set $mode_system (l)ock, (e)xit, switch_(u)ser, (s)uspend, (h)ibernate, (r)eboot, (Shift+s)hutdown
mode "$mode_system" {
    bindsym l exec --no-startup-id i3exit lock, mode "default"
    bindsym s exec --no-startup-id i3exit suspend, mode "default"
    bindsym u exec --no-startup-id i3exit switch_user, mode "default"
    bindsym e exec --no-startup-id i3exit logout, mode "default"
    bindsym h exec --no-startup-id i3exit hibernate, mode "default"
    bindsym r exec --no-startup-id i3exit reboot, mode "default"
    bindsym Shift+s exec --no-startup-id i3exit shutdown, mode "default"
    # exit system mode: "Enter" or "Escape"
    bindsym Return mode "default"
    bindsym Escape mode "default"
work for me (PC).
~/.config/i3
