Mobile is not charging via USB in Gnome and KDE
After the recent update, my mobile is not getting charged. The USB charging is not working. I tried in Manjaro Gnome and KDE. While the same cable and mobile charge in fedora and ubuntu in the same laptop. Can anyone give a solution?
Use tplui to adjust the settings for powersave.
sudo pacman -Syu tlpui
Then run
tlpui
That worked fine. I disabled USB auto suspend and now it works well. Thank you
