Thanks. I’ve replied to the issue at github.
I’m suspecting some issue with the lck file which is not properly deleted on logout.
I had the exact same issue with MEGASync - appeared to be clashing with pamac.
I have resolved the issue by checking “Hide tray icon when no update available” in pamac Preferences.
To be on the safe side, I also increased the autostart delay for MEGASync by setting X-GNOME-Autostart-Delay=90 in ~/.config/autostart/megasync.desktop
Hope this helps someone…
This sounds similar to an issue with MEGASync. Have you tried this?
Replace the Exec line in ~/.config/autostart/mntray.desktop with Exec=sh -c “sleep 3 && mntray”
Credit to @Zesko if this works
The startup delay should indeed help.
We did a lot of testing with @lakotamm. Ultimately it seems to be some gnome quirks…
There are a couple of ways to mitigate the issue via enabling certain extensions also, but the best for the moment is just to delay the startup as you described.
I started experiencing this issue after the 2021-03-08 Stable Update. Just confirming that the startup delay suggested above by @smadgal / @Zesko does indeed work for me.
I started working on porting the app to Vala/GTK using XApp.StatusIcon. Let’s see how it goes…
Installed mntray
yesterday on an up-to-date Stable gnome installation and after rebooting a few times today, I experienced this problem.
Solved it by following @smadgal 's suggestion and this exact modification.
For newbies like me
Backup ~/.config/autostart/mntray.desktop
cp -b ~/.config/autostart/mntray.desktop ~
Modify ~/.config/autostart/mntray.desktop
nano ~/.config/autostart/mntray.desktop
Replace the line Exec=
with the following:
Exec=bash -c "sleep 5 && /usr/bin/mntray"
Save Ctrl+O
, Enter
and Exit Ctrl+X
Try rebooting and then logging out. Check if mntray appears without fail and if everything works well, you could delete the backup file mntray.desktop
that’s in your home folder.
EDIT: Removed sudo
from the commands, because I realized we don’t need it and there’s no reason to risk unintended mistakes by applying changes with administrative privileges.
